| View Results: Have you ridden Pachaug Trail before? | |||
| Yes |
124 | 25.41% |
| No |
126 | 25.82% |
| I have not but I want to! |
243 | 49.80% |
| I am scared to ride it.... |
10 | 2.05% |
| Multiple Choice Poll. Voters: 488. You may not vote on this poll | |||
12-09-2012, 01:10 PM
#7681 | |
Oddometer: 247
12-09-2012, 01:18 PM
#7682 |
Oddometer: 247
I did pull forks off bike but am not comfortable pulling them apart.I did replace seals in my old Cr forks before.I made a tool worked good enough to get them in but wasn't fun.after reading info problem may have been user error. Lol
12-09-2012, 08:41 PM
#7683 |
Oddometer: 451
post pictures, some forks have rebound and compression split between the two legs, i.e. left fork has rebound adjuster, right leg compression. Older forks will usually have compression at the bottom, rebound on top
12-10-2012, 06:40 AM
#7684 |
Life behind "Bars"
Oddometer: 6,352
I make my own seal drivers with an old fork seal from the fork I'm replacing them in.
I take a razor knife and skin off the outside rubber material, remove the "lip" so it doesn't interfere with the lip of the new seal, then, with a hacksaw, I cut a very short section out of the seal, about 1/4". You now have a seal that looks like a letter "C" with a smaller opening. you can then twist and distort the seal onto the fork. Do it inverted to the other seal so the flatter side contacts the new seal. Then with a mallet, you can tap the new seal in. Keep it turning to get it even. The fact that you skinned off the rubber from the sides, keeps it so it doesn't stick in the fork tube. You ought to see the seal driver I built from pipe parts for conventional forks. but you can do the same with a seal and you don't have to cut it for a job on conventional forks, just skin off the outside rubber material and slide it on.
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
12-10-2012, 01:26 PM
#7685 | |
Slicker than an M59
Oddometer: 1,435
Here's another one for you...
Darius '06 KTM 400 EXC If it wasn't for all the rocks, roots, trees, hills, mud, ruts, logs, sand, and lack of tar, I'd be a damn good off-road rider! Darius on Dirt |
12-10-2012, 02:44 PM
#7686 | |
Oddometer: 247
12-10-2012, 03:07 PM
#7687 |
Duel
Oddometer: 2,287
51 seems quite large for a 200cc, you'd find 51's on a roadrace liter bike.
Just throw a ruler against them, I'm guessing they are 45's.....
12-11-2012, 05:04 AM
#7688 |
Green Cantern
Oddometer: 6,571
Those KTMs came with amazingly good forks. Nutmeggah has a whole 51mm front end. I was considering putting it on my CR500. I'm going to keep it stock though.
950/990 CRASH BAR BAGS, FENDER BAGS, and more. Made with pride. Pachaug Map '08 KTM 450 xcr-w, '10 KTM 990 Adventure '85 Honda CR500 NETRA #24519 |
12-11-2012, 09:23 AM
#7689 |
Specialized
Just found out the auditor for ISO that my company hired helped build or built the Pachaug trail back in the 70s.
12-11-2012, 10:01 AM
#7690 |
Green Cantern
Oddometer: 6,571
I'd buy him a coffee.
12-11-2012, 11:03 AM
#7691 |
Dumba$s Jarhead
Oddometer: 2,950
I would kick him in the shins
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone. There is no diagnostic computer for the female mind... The Simpsons 2013 |
12-11-2012, 12:23 PM
#7692 |
Oddometer: 247
I found the compression under cap on bottom. I was afraid to pull it out at first. I dumped some oil in a glass it looks nasty lite brown.did see some rust on rod too.don't know how to post up pictures here.
12-11-2012, 12:47 PM
#7693 |
Oddometer: 247
Didn't find metric ruler but was about 2 and 1/8 at the top is over 50mm.I also have part of old triple tree guy gave me that was much smaller.
12-11-2012, 12:50 PM
#7694 |
Oddometer: 247
12-11-2012, 02:04 PM
#7695 |
Magnanimous Madcap
Oddometer: 322
Anyone know if it's possible to get a WR450-F ('06) plated in CT?
