View Results: Have you ridden Pachaug Trail before?
Yes 123 25.73%
No 123 25.73%
I have not but I want to! 237 49.58%
I am scared to ride it.... 10 2.09%
Multiple Choice Poll. Voters: 478. You may not vote on this poll
Old 12-11-2012, 02:13 PM   #7696
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,242
Originally Posted by rutard View Post
Anyone know if it's possible to get a WR450-F ('06) plated in CT?
sent you a private message
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 12-11-2012, 03:29 PM   #7697
akarob
Green Cantern
akarob's Avatar
Oddometer: 6,499
If you have a Certificate of Origin that says "off road use only", you can apply for a "composite registration". You'll need to install the required safety items because they will need to inspect it. But yes, you can register off road bikes.
akarob is offline   Reply With Quote
Old 12-11-2012, 04:16 PM   #7698
CallMeBuzz
Bad as can
CallMeBuzz's Avatar
Oddometer: 508
With the C.O. or M.S.O. it's easier than you would think. Feel free to P.M. me also. We did four MX bikes with the same kit.
"The motorcycle goes where the eyes go."
CallMeBuzz is offline   Reply With Quote
Old 12-11-2012, 04:20 PM   #7699
rutard
Magnanimous Madcap
rutard's Avatar
Oddometer: 320
Thanks for the replies!
Looks like I've gotta delve into the paperwork side of things (sales tax, title, etc.), but it sounds like it may be more trouble than finding one that already has a plate.
rutard is offline   Reply With Quote
Old 12-11-2012, 04:49 PM   #7700
CallMeBuzz
Bad as can
CallMeBuzz's Avatar
Oddometer: 508
I did my CRF with no mso or title, ended up with a bonded title. The bond only cost $100 through my insurance co. I have a friend with a lighting kit completely independent of the bikes electrical system. We also have a universal chain guard and other do dads needed for the inspection. Totally worth the hassle for the right bike.
Old 12-11-2012, 06:10 PM   #7701
Ken F
Ken F's Avatar
Oddometer: 232
Originally Posted by Rusty Rocket View Post
I make my own seal drivers with an old fork seal from the fork I'm replacing them in.
I take a razor knife and skin off the outside rubber material, remove the "lip" so it doesn't interfere with the lip of the new seal, then, with a hacksaw, I cut a very short section out of the seal, about 1/4".
You now have a seal that looks like a letter "C" with a smaller opening. you can then twist and distort the seal onto the fork. Do it inverted to the other seal so the flatter side contacts the new seal. Then with a mallet, you can tap the new seal in. Keep it turning to get it even. The fact that you skinned off the rubber from the sides, keeps it so it doesn't stick in the fork tube.
You ought to see the seal driver I built from pipe parts for conventional forks. but you can do the same with a seal and you don't have to cut it for a job on conventional forks, just skin off the outside rubber material and slide it on.
I did make one from PVC pipe but didn't work so well
Ken F is offline   Reply With Quote
Old 12-11-2012, 06:33 PM   #7702
alcontrast
at least I'm trying
alcontrast's Avatar
Oddometer: 1,340
I designed a beautiful seal driver for my F650 out of 2" schedule 80 PVC pipe but I had the shop where I work put the pipe on a lathe and turn 3/4" of the end down to the perfect diameter for my seals. It was too big without doing so.
If you're looking for stock sized PVC to potentially be used as a driver don't forget to check PVC couplings and plastic electrical conduit as well since the electrical conduit comes in different sizes than PVC pipe for water, etc.
When in doubt, gas it. It will either fix the problem, or at the very least end the suspense.
07 650GS / 05 DRZ400S / 72 CB350 (that hasn't run since shortly after I bought it)
alcontrast is offline   Reply With Quote
Old 12-11-2012, 06:44 PM   #7703
MATPOC
MATPOC's Avatar
Oddometer: 433
I use all of above (PVC is simply awesome) but in some cases I purchased proper drivers.
I also use PVC plumbing pipe or electrical conduit to modify spring rate by cutting off section of spring and installing PVC spacer, just pulled apart my race bike fork that was done in 1999 and PVC spacer is still in tact.
MATPOC is offline   Reply With Quote
Old 12-11-2012, 06:53 PM   #7704
Ken F
Ken F's Avatar
Oddometer: 232
I think it was a male adapter I used.didn't have a lathe used a file.I sent you pm,s last week don't know if you are getting them or anyone else either
Old 12-12-2012, 04:03 AM   #7705
nobody
motomaniac
nobody's Avatar
Oddometer: 1,325
My drivers are cast gold!Beat that suckers!
Everything happens for a reason!
nobody is offline   Reply With Quote
Old 12-12-2012, 05:19 AM   #7706
MATPOC
MATPOC's Avatar
Oddometer: 433
we all know cast gold it the best: soft heavy metal that does not corrode! wish I thought of that before I sent in all of my scrap to one of those TV ad places
Old 12-12-2012, 01:15 PM   #7707
Rusty Rocket
Life behind "Bars"
Oddometer: 6,242
That's fine for conventional forks, but upside down forks, need a split design. That's why I cut a small piece out of the old seal for my KTM. I made a nice driver for my DR650 out of plastic pipe stock. I had to put it an the lathe and do some customizing.
Old 12-12-2012, 06:54 PM   #7708
bomber1965
Duel
bomber1965's Avatar
Oddometer: 2,192
Everyone's got their own Pachaug.....an Italian version.
bomber1965 is offline   Reply With Quote
Old 12-13-2012, 03:55 AM   #7709
sledstorm1
sledstorm1's Avatar
Oddometer: 604
That place reminds me of our loop in Windsor, It has maybe 5 rocks in it, all loam, sand and hills. 5 miles of work out bliss. We would do it forward and backwards.. Now ABB wants to build 3200 homes and a shopping center... So they threw us out...:(
To those who understand, no explaination is necessary
Too those who don't, none is possible...
sledstorm1 screwed with this post 12-13-2012 at 05:20 AM
sledstorm1 is offline   Reply With Quote
Old 12-13-2012, 04:49 AM   #7710
nobody
motomaniac
nobody's Avatar
Oddometer: 1,325
[QUOTE=sledstorm1;20239009.. Now ABB wants to build 3200 homes and a shopping center... So they threw us out...:([/QUOTE]
Isn't that just plain fucked up?like there aren't enough furniture and matressess stores .Casino coming near you as well...what a bright future!One day people will just say enough is enough
Times are GMT -7.   It's 11:58 PM.
