Old 08-03-2008, 10:46 PM   #1
ThreeNose OP
Adventure Rider
Oddometer: 43
VW Side-Bike hack
I know that trike conversions from VWs are doable and pretty popular. Has anyone taken a VW and set it up to look like a bike and sidecar - like the Zeus Side-Bike?
Is this a good idea or a dumb one?
ThreeNose is offline   Reply With Quote
Old 08-04-2008, 05:14 AM   #2
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
The roads around here are about impassable in some areas from all the trikes that look like VW's slowing down to wave at each other.
So- you want to put a Bug body on a 3-wheeled 2-track vehicle?
Accoding to an ancient text I keep on the desk here, the most efficacious way to get rid of ideas like this is by driving a "spike" into the subjects head at a specified location which I won't reveal until I get there.
Get comfortable while I figure out what a good spike might be...
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 08-04-2008, 06:05 AM   #3
ThreeNose OP
Adventure Rider
Oddometer: 43
Sidecar and Bike body on a VW bug frame
I was thinking more like putting the bike body and sidecar on a VW frame. The sidecar would hide the engine.
Like these guys - but cheap:
Zeus: http://www.side-bike.de/Side-Bike/Modelle/zeus.html
Video at: http://www.dailymotion.com/relevance...-side-bike_ads
ThreeNose screwed with this post 08-04-2008 at 09:06 AM
Old 08-04-2008, 06:21 AM   #4
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,920
Nice wheelie bar!
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole."
1981 R80G/S
1991 R100 GSPD
FIRST TIME RIFF RAFF - Go Jonah!
TEXASYETI is offline   Reply With Quote
Old 08-04-2008, 12:15 PM   #5
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,802
To get the sidecar ant not off-set three wheeler effect you need to have the side car wheel lead the rear wheel by 8-10 inches. So that complicates things considerably.
Also I don't think a cut down V-W pan is the best way forward. Some thing with muti tubes is and not likely to include the word cheap in the final product.
Old 08-04-2008, 04:58 PM   #6
ThreeNose OP
Adventure Rider
Oddometer: 43
Two track Three wheeler
So how important is it to offset the to rear wheels? I believe that I have seen sidecars with the sidecar wheel and rear wheel in-line together.
It would make sense that there is more stability with the sidecar wheel offset forward a bit. But does it matter with the track as wide as a VW bug?
I can weld a bit and figgured the most difficult part would be figuring out the front streering. Maybe I can weld a long diagonal support out of rectangular steel, like on many VW trike designs - but offest to the driver's side.
The advantages as I see it are:
1) Cheap parts - entire running car for 500 US dollars
2) Rear and sidecar wheel come aligned
3) Two wheel drive vw one wheel drive
4) Easy to find engine parts
5) Car tires and wheels in the rear
6) Easy to work on drivetrain
7) Lots of aftermarket support
8) Power vs motorcycle engine
9) Unique hack
ThreeNose screwed with this post 08-05-2008 at 05:39 AM
Old 08-06-2008, 08:10 AM   #7
bk brkr baker
Oddometer: 5,802
The unit in the pic has the chair wheel leading the rear. It will be harder to turn to the right with no lead.
Old 08-06-2008, 09:13 AM   #8
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
You got that right, he can't even keep it in his lane!
To answer the original question reminds of the saying "The problem with most good ideas is they just boil down to a lot of hard work"
GreaseMonkey is offline   Reply With Quote
Old 08-07-2008, 12:51 AM   #9
ThreeNose OP
Adventure Rider
Oddometer: 43
two track three wheel car hack conversion
So the turning issues sounds pretty imporant and after some reading, it seems that if I did my origional conversion with the chair and rear wheel without any lead, I'll lift the rear tire on turns on the chair side.
Damn.
Plus I found this image
It's a diesel Ford Escort. Not exactly what I had in mind - but not really interested in driving that around as much as the Side-Bike. Perhapse going cheap on this project is going to be disappointing.
The wheels are still turning.
Old 08-07-2008, 06:55 AM   #10
BeemerChef
Wandering Homeless
BeemerChef's Avatar
Oddometer: 3,323
Hi Uncle Ernie! Long time no see... on my part anyhow...
Hope is well with you.
(sorry for the intrusion...)
Be well... Ara & Spirit
BeemerChef is offline   Reply With Quote
Old 08-07-2008, 06:59 AM   #11
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,269
it sounds like you might have little or no actual experience with sidecars? You might consider finding a cheap, used sidecar already put together and taking a sidecar class(not necessarily in that order) to get a little seat time before designing one on your own. It would really help you get some perspective on what is required and desirable in a sidecar rig and how they work. Book learning alone is not a good basis for design.
" I need to stop talking and start drinking" ...Mom
RedMenace is offline   Reply With Quote
Old 08-07-2008, 07:27 AM   #12
ThreeNose OP
Adventure Rider
Oddometer: 43
Hack N00b
You are probably right, but it has been difficult finding a used chair and I figured that I would just use your experience to help design a really cool setup.
I've seen a few car/chair hybrids on the web, and it's starting to look like the squeeze just might not be worth the juice. But the thought of throwing together a my very own easy to do setup with power disc brakes, car wheels, car tires, running gear that is easy to find parts for, possible two wheel drive and wheel standing power (not that I need or really want that) for less than the price of a Ural - is pretty appealing. The easy to do and less than the price of Ural is starting to look unlikely.
Old 08-07-2008, 12:28 PM   #13
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,766
Here's one you can "pick up" for free. It looks like a good project starter.
http://www.advrider.com/forums/showthread.php?t=350988
New desert racing frontiers
It will be Devilish !
HogWild is offline   Reply With Quote
Old 08-07-2008, 01:01 PM   #14
claude
Sidecar Jockey
Oddometer: 3,849
If you think about it almost any front wheel drive car , engine and tranny, could be used to make a rear engine hack. Left front car wheel becomes the rear bike wheel and right front car wheel gets moved forward and is turned by a chain or gilmer belt. Rigid suspenion on th ehack sure woudl make it easy.
The sidecar wheel on the yellow rig is run by a gilmer toothed belt.
One could also possibly lock the differential and use an unpowered sidecar wheel.
If we look at how much power some of the youngsters are getting out of these 'tuner cars' today this whole concept can get pretty exciting. Twin turbos, intercoolers etc etc...yow.
I better shut up now...LOL.
Claude
http://freedomsidecars.com/
Old 08-07-2008, 01:01 PM   #15
ThreeNose OP
Adventure Rider
Oddometer: 43
Yah - I've been wondering about the Sunken sidecar of doom. If it were just driving distance from here.
Times are GMT -7.   It's 10:32 AM.
