Old 08-04-2008, 02:28 PM   #1
longwaytim OP
longwaytim's Avatar
Oddometer: 511
extra fuel container travel safety..?
Hey all,
I have a 4 l , (1 1/4) gallon small plastic gas can that I bought to carry extra fuel in. How do these things travel on a motorcycle? I see it all the time but not sure if I tighten the lid tigh, or?? Just not sure how the vent so the fuel doesn't expand too much. Thanks,
longwaytim screwed with this post 08-04-2008 at 02:47 PM
longwaytim is offline   Reply With Quote
Old 08-04-2008, 04:32 PM   #2
vOOdsy
vOOdsy's Avatar
Oddometer: 774
Two thing i do (1) Do not overfill the container as it allows rooms for expansion and (2) Open the container at least once during the day to vent the container.
The best currency in the world is a smile
vOOdsy is offline   Reply With Quote
Old 08-04-2008, 04:50 PM   #3
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 430
I leave an inch or so from the top and tighten the cap well. So far no problems in three seasons. My gas cans are 1.25 US Ga, straped to the Kytech rack on the XR650R. Many riders in my area do the same for rough trail riding.
Here is a question for Kolpin users:
Has anyone snapped, cracked or severely damaged the factory Kolpin mounting bracket? I am thinking about side mounting but fear the effects of lowsiding or droping the wrong way on a rock garden.
Eduardo
XR650R
KTM300
Simplicity is the ultimate sophistication.
EduardoMas is offline   Reply With Quote
Old 08-04-2008, 05:24 PM   #4
longwaytim OP
longwaytim's Avatar
Oddometer: 511
That's pretty much what I thought but I wanted to check before I travelled with it.
Thanks all!
Old 08-12-2008, 07:32 PM   #5
longwaytim OP
longwaytim's Avatar
Oddometer: 511
Is it legal to carry extra fuel container?
One other question, my neighbor saw my fual can safely strapped to the back rack on my GSA & seemed to think it is illegal to carry fuel that way, is he right??
Old 08-12-2008, 08:02 PM   #6
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
It probably is illegal somewhere.
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Old 08-13-2008, 06:11 AM   #7
DriveShaft
Oddometer: 4,493
Hey all,
Venting cans is definitely not safe, and not legal. keep it sealed tight. That's what makes it a gas can, and not...just a can.
DriveShaft is offline   Reply With Quote
Old 08-13-2008, 07:06 AM   #8
longwaytim OP
longwaytim's Avatar
Oddometer: 511
has anyone ever heard of it being illegal to carry extra fuel? I thought as long as it is strapped down safely it's ok? Hell, it's designed to transport fuel... I'm taking it anyway but I'd like to know if it's leagal or not anyway.
Cheers!
Old 08-13-2008, 07:35 AM   #9
BuellDualSport
BuellDualSport's Avatar
Oddometer: 891
Depends
Each State has it own highway laws.
Go to your States's web site and do a search.
Good Luck
BuellDualSport is offline   Reply With Quote
Old 08-13-2008, 07:39 AM   #10
ruh roh
hey Yall
ruh roh's Avatar
Oddometer: 296
i carried mine recently, and apparently change of altitude made it expand and loosened the top. It spilled in my bags. I put it in double zip-lock bags on the way home (1200 miles) and not a drop spilled.
If the world didnt suck , we d all fall off.
ruh roh is offline   Reply With Quote
Old 08-13-2008, 07:56 AM   #11
MrDude_1
Loser says Duc?
Oddometer: 35
uh, NOT venting a can is what can make a dangerous situation. By venting we're mearly saying loosen the cap, then retighten.
MrDude_1 is offline   Reply With Quote
Old 08-13-2008, 08:47 PM   #12
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,590
Dangerous? Exact gasoline vapor pressure varies according to formulation which varies from place to place and from season to season. Using EPA data, however, shows a typical rise of about 7 PSI as temperatures go from 40F to 100F. Somehow I don't see a 7 PSI rise as being all that dangerous in any DOT approved fuel container that is filled to the maximum allowed 90% of total volume.
// marc
marchyman is offline   Reply With Quote
Old 08-13-2008, 09:11 PM   #13
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,081
marchyman is on target. You can vent a plastic gas container literally hundreds of times per day if you want - if its full of gas, after you vent it more gas will vaporize until the vapor at the top of the can reaches the vapor pressure of that particular blend of gas at that temperature and reaches equilibrium with the liquid portion. If you don't vent it, the container (if the typical poly plastic) will swell to a certain size at which point it contains the pressure at equilibrium between the liquid and vapor. When the temp drops, the container will shrink - sometimes to the point of partially collapsing the sides. You can let air in if you want, but the ultimate result will be an equilibrium between the vapor pressure of the gasoline, ambient atmoshperic pressure, and flexibilty of the container.
Stick with approved gasoline containers and stow them where spills won't get into your other stuff and you will be safe.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 08-13-2008, 09:21 PM   #14
boxertwin
Oddometer: 1,022
Gracias.
Marchy and Mark,
Thank you for this. It is very helpful.
Now, does the fridge light really turn off when I shut the door?
"If there's one thing I'm grateful for in life it's my sunny disposition." -Harry Pierce, MI-5
boxertwin is offline   Reply With Quote
Old 08-14-2008, 01:08 AM   #15
Demoni
Demoni's Avatar
Oddometer: 92
Only one way to find out
Great explanation Marc & Mark even a moron like me was able to make sense of it.
Demoni is offline   Reply With Quote
Times are GMT -7.   It's 07:21 AM.
