Old 08-09-2008, 10:37 PM   #1
andmoon OP
andmoon's Avatar
Oddometer: 3,187
Whay does my lawn mower's idle rise and fall?
Riding mower. with Brigs 5xxcc single. The idle now rises and falls like it is running out of gas. I changed the air and fuel filter to no avail. My bikes are finally running sweeet so the freakin mower starts acting up?
POVERTY SUCKS
andmoon is offline   Reply With Quote
Old 08-09-2008, 11:35 PM   #2
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,288
The carb needs cleaning or rebuilding, should be a 30 minute job if you can get to all the screws OK.
What happens is the idle circuit is messed up, so it will not idle but when the RPM's fall too much the governor opens up the throttle so it roars into life, which makes the governor move back to idle and the process repeats itself again, about 30-40 times a minute.
GreaseMonkey is offline   Reply With Quote
Old 08-10-2008, 03:57 AM   #3
Inane Cathode
Cheated Anion
Inane Cathode's Avatar
Oddometer: 4,601
How old is it?
If it has a wind vane type governer they tend to do that.
_______
Pokey The Wunderbus
The VEEP Project
Inane Cathode is offline   Reply With Quote
Old 08-10-2008, 08:59 PM   #4
Yad
yet another dave
Yad's Avatar
Oddometer: 360
i don't know anything about the larger Briggs, but at least on their smaller engines the carb is mounted directly to the gas tank, with a thin rubber-like diaphragm between them. If anyone used carb cleaner to clean this (like I did) it can make that diaphragm just a little too floppy and you'll get that rise and fall effect. Fortunately those diaphragms are relatively cheap.
Yad is offline   Reply With Quote
Old 08-11-2008, 06:46 AM   #5
andmoon OP
andmoon's Avatar
Oddometer: 3,187
Thanks,
Marvel mystery oil carb clean attempt "1.
Sea foam attempt # 2.
fook it, I'll take the fooker apart....#3.
POVERTY SUCKS
Old 08-11-2008, 06:47 AM   #6
andmoon OP
andmoon's Avatar
Oddometer: 3,187
Originally Posted by Inane Cathode
How old is it?
1 year old...no clue as to opt. hours as i do not count.
1 oil change old.
POVERTY SUCKS
Old 08-11-2008, 09:29 AM   #7
GreaseMonkey
Preshrunk & Cottony
Oddometer: 5,288
OK, here is a trick you can try-
Take the air cleaner off all the way to the carb body. Start the engine and rev it up at high throttle. When it is roaring away block the air off completely with your palm. Hold it there until the engine almost dies then remove it in time for the engine to catch and roar back to life again.
Do this about 5 times and see if that makes a difference.
What happens is by blocking it off you create a strong vacuum which pulls gas through a lot of air passages and hopefully sucks out any junk stuck in there. It doesn't work all the time but suprisingly often enough (enough times that I used to have a large rubber ball glued to a chopstick that I would use to block off individual carbs on a multi cylinder bike).
Now the bad news is with briggs motors your problems are usually caused by that flexible gasket as metioned by Yad, but since you mentioned it is only a year old you may get lucky this way.
Old 08-11-2008, 01:34 PM   #8
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,100
Yeah, and nowadays the engines are set to run so lean that they will react to just the slightest bit of something being out of spec.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 08-12-2008, 02:15 PM   #9
KneeKicker
KneeKicker's Avatar
Oddometer: 2,627
Thanks,
Mine did a similar thing. I Sea foamed it and it ran great after it smoked like bitch for 10 minutes.
Matter of fact I'm due for a foaming again.
everything looks cool on motorcycle
"I got so drunk last night I woke this morning and someone had shit my pants" Ron White
KneeKicker is offline   Reply With Quote
Old 08-12-2008, 05:30 PM   #10
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,241
Try it with the gas cap loose. Maybe there is a blockage in the cap vent.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 08-12-2008, 11:09 PM   #11
Inane Cathode
Cheated Anion
Oddometer: 4,601
1 oil change old.
Wow i was WAAAAAY off. Theres no way yours has a wind vane governer.
My only guess is that its running lean. Go fix that :P
_______
Pokey The Wunderbus
The VEEP Project
Old 08-13-2008, 03:59 PM   #12
Mista Vern
Mista Vern's Avatar
Oddometer: 16,100
1 oil change old.
That's the problem - no way to adjust the new carbs. I curse the engineers/bean counters who devised such waste.
Emily Bronte
Old 08-13-2008, 09:37 PM   #13
Inane Cathode
Cheated Anion
Oddometer: 4,601
Theres no adjustment at all? No blank caps over mixture screws or anything?
_______
Pokey The Wunderbus
The VEEP Project
Old 08-14-2008, 02:53 PM   #14
Mista Vern
Mista Vern's Avatar
Oddometer: 16,100
Nada. I thought I was going nuts not finding them, but in fact there are none. I might try that Seafoam idea and see if that make a difference - the tiller runs fine under load but all the other times it cycles revs up and down.
Emily Bronte
Old 08-14-2008, 07:15 PM   #15
Solo Gato
Solo Gato's Avatar
Oddometer: 773
1 oil change old.
That's the problem - no way to adjust the new carbs. I curse the engineers/bean counters who devsised such waste.
EPA bastages forced this, but worse some small engines now have plastic camshafts too-
admitting there is a "machine" in your house that your wife knows how to use and you don't deserves a kick in the balls. Joe
Solo Gato is offline   Reply With Quote
Times are GMT -7.   It's 04:12 AM.
