12-02-2012, 11:54 PM
#61 |
Oddometer: 1,216
12-03-2012, 12:12 AM
#62 | |
Oddometer: 1,216
12-03-2012, 03:27 AM
#63 |
Oddometer: 517
I was thinking about putting something like this over the blue foam filters for the deep crossings to avoid water splashing in.
BMW R100'91/R80'93/R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920 R100GS'91 (sold) |
12-03-2012, 03:41 AM
#64 | |
Oddometer: 517
I'm thinking of buying a second tank and weld some tubes through that can be connected to the airboxcover.
12-03-2012, 08:11 PM
#65 |
Oddometer: 1,216
12-03-2012, 09:53 PM
#66 |
Oddometer: 23
Didn't the BMW military sidecar rigs have the air filter inside the fuel tank with the air intake coming out of the top of the tank, I remember the top filter cover looking like a helmet????? A person could use a can big enough to hold the round BMW filters and add water drain holes outside of the filter area to drain the water out the bottom. You would lose some fuel volume but you would have the area were the airfilter use to sit to make an additional fuel tank or mount the battery in that position and then build the extra fuel tank were the battery use to sit. This would also be a good area to run the trans and rear end vents to keep them out of the water.
![]() Seems like BMW had a good idea 60 years ago. |
12-04-2012, 01:22 AM
#67 |
Oddometer: 1,026
If you used a police fuel tank, the radio/toolbox compartment in the top of the fuel tank would be ideal for mounting e air filter
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
12-17-2012, 06:19 PM
#68 | |
Shit for brains
Oddometer: 5,013
12-18-2012, 04:20 AM
#69 | |
Oddometer: 517
I made a spring shaped thingy on the inside to keep them about 2" from the intake. But I still need to try them.
12-18-2012, 05:32 AM
#70 |
unconditional love
Oddometer: 5,708
Here`s what you need; fitted to early Dakar Rally BMW`s.
David Hunn: R100GS Ray Peake special. http://www.advrider.com/forums/showt...uild+australia |
12-18-2012, 06:30 AM
#71 | |
Shit for brains
Oddometer: 5,013
01-10-2013, 08:33 AM
#72 |
Oddometer: 3
Prutser,
Just a thought regarding water getting into the airbox. Had you considered fitting (or fabricating) an airbox similar to the one supplied by Moorespeed. ![]() You could fit a tube/pipe to where the air filter locates, then run your 'snorkel' to a higher point, then implement an air filter higher up. Or alternatively fabricate a cylindrical enclosure, into which the air filter sits, that is then welded to the top of the airbox, then run a 'snorkel' to a higher point on the bike. |
01-10-2013, 08:46 AM
#73 | |
More tacos than you
Oddometer: 5,201
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
01-10-2013, 03:50 PM
#74 | |
Oddometer: 517
The filter and airbox is something for later, first i need to get through that tank. Fitting a filter in the tank is another option. Than i could remove the airbox and make another fuel tank on top of the gearbox. The weight would be lower on the bike and I might be able to store more fuel in the extra tank than i would loose by building an airbox in the main tank. Lots of things to think about but first i would like to fix the carb vent's and than work my way up.
01-10-2013, 04:07 PM
#75 |
Shit for brains
Oddometer: 5,013
Ok, you guys are way more advanced on this subject so no laughing at my simple idea. I notice the rooney is still using the filter and airbox top with the clips, but got rid of the horns and came out the top. Can we not just seal around the base where the horns meet the top of the airbox and run flexible tubing off the ends of the horns and up to a filter near the steering neck?
