Old 01-10-2013, 09:34 PM   #76
Phreaky Phil
Oddometer: 1,804
Originally Posted by hardwaregrrl View Post
Ok, you guys are way more advanced on this subject so no laughing at my simple idea. I notice the rooney is still using the filter and airbox top with the clips, but got rid of the horns and came out the top. Can we not just seal around the base where the horns meet the top of the airbox and run flexible tubing off the ends of the horns and up to a filter near the steering neck?
There is a lot of space under the right side of the tank there, where all the electrcal junk is and the coils are. If that stuff was moved a duct could be made so the intake is level with the top of the back bone of the frame and has a flexible duct to the existing filter setup ?? It wouldnt be quite as high as the Rooney setup but would be close.
Phreaky Phil is offline   Reply With Quote
Old 02-09-2013, 01:40 PM   #77
Prutser
Prutser's Avatar
Oddometer: 989
FD & gearbox vent
The gearbox and finaldrive vents I made for my R80ST don't solve the problems I had with the oil getting milky.
Each time I took the hoses off water came dripping out.
The warm air coming out of the FD or gearbox condensates in the hoses and runs back into the fd or gearbox.
In other threads I asked others about it, but nobody had that problem.
I even asked a Dutch boxer guru about the gearbox breather he sells. He told me that there is always condensation in the hose and the oil still turns milky. (it must be the dutch wet conditions)
Because of the deep river crossings I sometimes have to do I still like to keep the hoses.
I made some double hoses with one side connected to the air intake.
Now there is some constant airflow through the breather hoses and I hope this will take away the condensation.
To test the airflow I kept a lighter in front of one hose and blew along the opening of the other hose.
By doing this I could see the flame being sucked towards the hose.
I hope this system will not suck out all my gearbox oil
If this works the next thing will be to fix the carb vents.
If someone has detailed pics of modified carb vents and could post them that would be great.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 02-09-2013, 01:54 PM   #78
igormortis
igormortis's Avatar
Oddometer: 1,351
Great work, Bas. I'm waiting anxiously to see what you come up with for the carbs.
*edit: How about using clear hose to see what's going on?
igormortis screwed with this post 02-09-2013 at 02:09 PM
igormortis is online now   Reply With Quote
Old 02-09-2013, 02:33 PM   #79
Prutser
Prutser's Avatar
Oddometer: 989
Didn't think about that. But would be a great option for a testing period.
I will change them for clear ones.
Thnx Igor.
Ride Report 2012
Old 02-23-2013, 07:25 PM   #80
ed mocz
Bristol WI
ed mocz's Avatar
Oddometer: 204
How about using one of these? Or as someone stated in FWD forum "use a condom and a zip tie".
http://www.tmrcustoms.com/store/inde...oducts_id=1075
Or this, it's cheaper: http://www.lowrangeoffroad.com/index...er-bellow.html
1978 BMW R100/7 A holy union/cheap bike challenge combo.
ed mocz screwed with this post 02-23-2013 at 08:00 PM Reason: added info
ed mocz is offline   Reply With Quote
Old 02-23-2013, 08:25 PM   #81
Phreaky Phil
Oddometer: 1,804
I looked at the ones on ATV rear diffs some years ago. Never got around to pricing one up.
Old 02-24-2013, 08:58 AM   #82
ed mocz
Bristol WI
ed mocz's Avatar
Oddometer: 204
One more with a breather cap. The FWD groups have this same discussion. Haven't done this mod yet, but will before I'm in the creek.
http://www.toyota120.com/html/rear_diff_breather.html
Old 02-26-2013, 11:30 AM   #83
Prutser
Prutser's Avatar
Oddometer: 989
Carb vent.
They still need to be tested but this might solve my problem of water flowing into my float bowls through the vent holes.
Ride Report 2012
Old 02-26-2013, 11:35 AM   #84
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,238
Bling indeed. I gather you had the Bling cover machined up. Looks very stealth
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 02-26-2013, 11:47 AM   #85
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,493
What about the drain tube in the bowl?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 02-26-2013, 11:56 AM   #86
Prutser
Prutser's Avatar
Oddometer: 989
I sealed those last summer.
Ride Report 2012
Old 02-26-2013, 11:59 AM   #87
igormortis
igormortis's Avatar
Oddometer: 1,351
Wow. Nice work! Need anyone else to do some testing for you?
Old 02-26-2013, 10:50 PM   #88
Phreaky Phil
Oddometer: 1,804
That looks great. I assume the vents are accessible behind the Bing/Bling cover. Do the little brass plugs holding the cover on come off easy. I assume you have taped threads into the carb to screw the cover on ? Is the vent into the bowl that you have plugged a vent or overflow ?
Thanks Phil
Old 02-27-2013, 08:02 AM   #89
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,856
Some good ideas...keep them coming
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 02-27-2013, 08:11 AM   #90
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,486
nice!
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Times are GMT -7.   It's 09:37 AM.
