Old 08-21-2008, 01:56 PM   #1
DrLewall OP
The Human GPS
DrLewall's Avatar
Oddometer: 33,595
XR street legal kit?
Does anyone know if there just happens to be a "kit" available to make a XR dirt bike street leagal? I am sure it can be done but don't want to spend the rest of my life chasing down parts..would rather have it all right here, ready to bolt on, knowatimean?
DrLewall is offline   Reply With Quote
Old 08-21-2008, 02:12 PM   #2
lewismedlock
lewismedlock's Avatar
Oddometer: 13,419
http://www.advrider.com/forums/showt...eet+legal+kits
See the third post.
The search function is your friend.
Good luck.
lewismedlock is offline   Reply With Quote
Old 08-21-2008, 02:58 PM   #3
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,275
I have three street legal XRs, 2 600Rs and a 650R. I wouldn't use anything but a Baja Designs dual sport kit, they are the best. The last one I was able to completely install in just under 3 hours. They run about $500. If you go this route, have your stator rewound by them also. It will make it so you can have a head light brighter than 35w. Have fun and go for it.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 08-21-2008, 03:12 PM   #4
mcma111
mcma111's Avatar
Oddometer: 12,403
+1 On Baja Designs
My 92 XR600 has had a Baja Designs kit on it since day 1. Stator wound by Ricky Stator. As good as OEM.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-21-2008, 05:18 PM   #5
DrLewall OP
The Human GPS
DrLewall's Avatar
Oddometer: 33,595
tried the search feature and came up NO MATCHES FOUND..me and search features tend to butt heads..anyway tnx for the info..I really want a 650 but if I can make my XR400 street legal, it'll be cheaper than buying a new bike..but if I can't get the right kit, then I'll have to fork over some bigger bucks for a new ride..worth a try anyway..tnx agn!
Old 08-21-2008, 06:01 PM   #6
guns_equal_freedom
Oddometer: 5,573
There's a kit for an XR400R.
https://www.bajadesigns.com/NET/Cate...tegoryCode=361
Call them up and see if it fits your bike.
guns_equal_freedom is offline   Reply With Quote
Old 08-29-2008, 08:58 PM   #7
Death Dealer
Death Dealer's Avatar
Oddometer: 365
www.vancouversupermoto.com
minimalist perfection
2010 GasGas 300 EC Nambotin Replica
2006 XR 650R Supermoto
2006 CFL
1982 Yamaha Maxim - sold
Death Dealer is offline   Reply With Quote
Old 09-07-2008, 09:32 AM   #8
diesel1959
diesel1959's Avatar
Oddometer: 168
I have got a Baja Designs DS kit on my '97 XR400R and I'm very pleased with it. I bought a RickyStator upgraded stator and the BD kit. The BD kit is all LED except for the headlight, which is a PIAA 85W/85W headlight = very bright. Here are some pics:
(I've since added bags and a windscreen, but you get the idea--everything is tucked in nice and tight and has no problems on the trail or the street.)
diesel1959 is offline   Reply With Quote
Old 09-07-2008, 11:08 AM   #9
yater
yater's Avatar
Oddometer: 8,517
I've used baja kits on two bikes....an xr250r and a dirt model dr350. They've been great...bolt and go.
Here's the xr. I chose to go with the mx rear fender and the under-tail brake light and plate mount. This way, I would run the motobillet rear rack. I also think it looks much better than the bulky above-fender mount.
yater is offline   Reply With Quote
Old 09-07-2008, 11:53 AM   #10
SwitchThrottle
Bring da amber lamps
SwitchThrottle's Avatar
Oddometer: 1,054
With a little ingenuity and the right parts, you can make a kit for a hell of a lot less than a BD kit. My bike came to me with a plate, so all I added was turn signal switch ($20), wired in some signals ($15) and a banjo bolt switch replacement for a rear brake light ($15). Add some wire, soldering, and make a couple mounting brackets and you’re in business. All for about $60 A buddy of mine has a KTM400exc (e-start so has a battery), and he built his own kit for under $100, and his has a fuse block (radio shack I think), and a horn (taken from a totaled Subaru).
2008 Husky sm450r (13k+ miles)
2003 Honda xr400r (street titled) For sale, but not posted anywhere.
Riding a motorcycle is fun. Riding a supermoto is inexplicable.
SwitchThrottle is offline   Reply With Quote
Old 09-07-2008, 12:27 PM   #11
yater
yater's Avatar
Oddometer: 8,517
Around here, you need a high/low beam switch, high beam indicator, high/low headlight, regulator/rectifier/battery (to run the lights without engine power), horn, clear light on license plate, brake switch, and tail/brake lights. If you're a tech geek, you can wire something together. We did a homemade kit on a drze once...it was a pita and not nearly as solid as the kit. YMMV.
Old 09-07-2008, 12:53 PM   #12
SwitchThrottle
Oddometer: 1,054
I looked at the BD kit, and it is a good kit. I am not knocking the kit at all. I just think you can do it yourself for a lot less money. As stated, my bike had been plated by the previous owner (with no kit installed....not even a brake light...I think he slipped it through while CT wasn't doing DOT inspections). I only added the parts that were needed for the 50' view so that Jonny Law would leave me alone. My bike certainly wouldn't pass a DOT inspection. To do it right, I think I could still do it for hal the BD price.
Old 09-07-2008, 01:01 PM   #13
yater
yater's Avatar
Oddometer: 8,517
Yeah you can do it cheaper if you don't mind some research, part hunting, trial and error, soldering, splicing, etc. I'm a DIY type on just about everything....but the kits are plug and go. They're color coded and all connectors are ready to plug into your specific year/model's wiring harness. If you're good with electronics and have the patience to mess with it, you can probably save a couple hundred bucks. The baja kit is a sure thing and everything is DOT approved.
Old 09-07-2008, 05:50 PM   #14
bongodave
Join my cult!
bongodave's Avatar
Oddometer: 41,773
My bike came with the Baja Designs kit, and it's held up with no problems so far on or off road. It's a 2000, and it's seen a lot of dirt!
Don't know when the kit was installed, but it has to be 4 years old, at the minimum. You can't plate dirtbikes anymore after 2004 in this state. Still has the same tiny battery pack it came with.
Freedom without regulations that protect the general good is nothing more than anarchy by the rich. -R-1150-RS
Corporatism walking hand in hand with patriotism .... just as deadly as religion. - Icewalker
if you depend on lies and misinformation to support your belief system, you need a better belief system. - Dances With Roads
bongodave is offline   Reply With Quote
Old 09-07-2008, 09:15 PM   #15
ryanwilliamcantrell
Get Out and Ride!!
ryanwilliamcantrell's Avatar
Oddometer: 3,861
I've got the Baja Designs kit. It's a good kit minus the rear brake light... it's a pain in the ass.
Ride your own ride & enjoy your ride.
ryanwilliamcantrell is offline   Reply With Quote
Times are GMT -7.   It's 06:01 PM.
