Old 08-22-2008, 03:52 PM   #1
oktulsa17 OP
Oddometer: 208
Stem pulled out
Anybody ever see anything like this before? I felt the back tire getting wobbly (going flat) so I headed home about 1.5 miles away, but had to stop about .5 from home because it was getting worse. Pulled the rear tire and this is what I found. Stem had pulled out of inner tube. I'm not sure if this was the original problem or happened when I drove on it the mile or so.
It's a DRZ400s with new tire Cont. TWC80 and a new tube both with less than 300 miles. My thoughts were:
1. Need rim lock(which I'm going to do)
2. Valve stem lock nut too tight
3. Valve stem lock nut too loose
4. Punctured tube and pulled stem loose drving on flat tire.
That's a match stick where the valve stem should be.
oktulsa17 screwed with this post 05-07-2009 at 01:24 PM
oktulsa17 is offline   Reply With Quote
Old 08-22-2008, 05:00 PM   #2
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
Did you check for a puncture? If you have a compressor and a blow gun attachment you can inflate it and check for a hole, or look at your tire to see if there is still something stuck in it. My guess is the tire slipped while it was flat.
GreaseMonkey is offline   Reply With Quote
Old 08-22-2008, 05:47 PM   #3
mcma111
mcma111's Avatar
Oddometer: 12,392
It went flat then spun on the rim thus ripping the stem off. That's why there are rim locks on dirt bikes. Before you put a new tube in the tire check for what caused the puncture.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-22-2008, 06:06 PM   #4
Lone Rider
Registered User
Oddometer: 25,130
I had a stem pull out a couple/few weeks ago during a CDR ride. Clean tube, but with without the stem.
For whatever reason, I'd installed the tube a few days before inside a new tire without a nut on the inside. Bad on me.
Lone Rider is offline   Reply With Quote
Old 08-27-2008, 09:31 AM   #5
oktulsa17 OP
Oddometer: 208
same here
I think this is what I did. I'm also going to install a rim lock.
Thanks for all the help, I knew I could count on this group.
Old 08-27-2008, 01:12 PM   #6
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,285
If you can stand it, take the nut off or at least run it up the stem under the cap. Some have chamfered the hole on the rim to allow the stem to pull through or move around without yankin' it off the tube. Absolutly run a rim lock.
1991 Honda XR628R
1978 Yamaha XT500
JAB is online now   Reply With Quote
Times are GMT -7.   It's 02:32 PM.
