Old 03-28-2004, 11:34 AM   #1
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
KTM LC4 clutch lock-out switch
The information below pertains to the US ’03 KTM 640 Adventure. It may also be of use to any street legal KTM LC4 model including the enduro, Duke and Motard... and possibly the 950 Adventure.
For almost a year now I’ve been pondering as to why my bike must be in neutral to start. Obviously, I haven’t pondered that much or I would have investigated the issue sooner.
Anyway, after reading the translated (?) starting description and staring at the wiring diagram, I came to the conclusion that there was a problem with either my clutch switch or the diode it is wired to and I should in fact be able to start the bike in any gear with the clutch pulled in.
I removed the fairing, hooked a multimeter to the two-pin plug connection on the clutch switch and saw no change in resistance when I pulled in the lever… Ah Ha! Bad switch!
I removed the offending switch and retested it (yes, I’m like that) and found less than 1 ohm continuity when I pushed the plunger in with my finger… Ah Ha! Good switch!
Apparently, after examining the parts, it appears that the relationship of switch plunger, the “bump” on the clutch lever intended to depress the plunger, and there proximity to each other was insufficient to engage the switch.
I could see no way to make the lever “bump” higher, or to extend the plunger, so I looked at ways to increase the depth in which the switch screwed into the clutch master cylinder casting.
If I had a mill, it would have been a simple thing to “face off” a bit of the boss (oddly enough, about .060”) that extends out away from the master cylinder casting, allowing the switch (and plunger) to go deeper into the casting, and the plunger to be in closer proximity to the clutch lever.
Instead, I used a hand held lathe, designed to turn down the necks of benchrest rifle cartridge cases, to remove approximately .060” from the shoulder of the switch.
This was sufficient for the lever to fully depress the switch plunger, providing continuity for the diode and finally… in gear starts for me. Ta Da!
I may be the only one on the planet that had this problem… but I doubt it.
Creeper
First view is relationship of parts
So... how's tricks?
creeper screwed with this post 03-28-2004 at 12:52 PM Reason: revision of applications
creeper is offline   Reply With Quote
Old 03-28-2004, 11:34 AM   #2
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
A view of the switch and material removed (shiny area)
So... how's tricks?
Old 03-28-2004, 11:35 AM   #3
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
A view of the master cylinder boss.
So... how's tricks?
Old 03-28-2004, 01:06 PM   #4
dagwood
dagwood's Avatar
Oddometer: 35,427
Mine took a dump and would periodicly "kill" the motor while in motion. Nada, not gonna happen again. thew that pos away. Beware if anyone else rides my bike, it will start in gear with the clutch out.
dagwood is offline   Reply With Quote
Old 03-28-2004, 03:09 PM   #5
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
That can be a handy feature .. pushing the bike out of a river (motor won't start) and you cannot push it over a log/bump simply use the starter to get you over that hard bit.. not for continuous use though.
And Yes - the cluctch switches and side stand switchs on all of my bikes have been removed.. problems waitin to happen if you ask me.
Regards Frank Warner
motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S
http://www.geocities.com/fwarner_au/
Frank Warner is offline   Reply With Quote
Old 03-28-2004, 03:21 PM   #6
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,909
POS hydraulic clutch!
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Old 03-28-2004, 06:43 PM   #7
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Yea, I considered bagging the whole starter "safety" package. I want to see if it all works for awhile, correctly, before I do.
Creeper
So... how's tricks?
Old 03-29-2004, 05:15 AM   #8
Gary
Another Adventure Rider
Gary's Avatar
Oddometer: 304
Question Safety switches...
My sidestand switch failed a couple of weeks ago on my LC4E, bike only has 3000 miles, but the wires take a beating under there where the switch is. Removed the wire and re-inserted the electrics source pins (under the seat) together and problem solved for that switch. Looks like I need to get a different bolt for the sidestand inorder to actually remove the (now disconnected) switch itself.
Anyone care to offer a quick rundown on removing/disabling the clutch switch on an LC4 w/cable clutch?
Thanks,
Gary
Gary is offline   Reply With Quote
Old 03-29-2004, 08:06 AM   #9
dagwood
dagwood's Avatar
Oddometer: 35,427
cut the wires and solder them together, put a piece of shrink toobing over the exposed end and stuff it back under top tripple clamp.
Old 03-29-2004, 11:08 AM   #10
Gary
Gary's Avatar
Oddometer: 304
clutch wire...
Thanks Dagwood. That seems simple enough!
Gary
Old 03-30-2004, 09:30 AM   #11
kurtw
Child of the Wind
kurtw's Avatar
Oddometer: 209
When I installed my KTM sidestand, I first removed the switch. I believe that the small bolt that holds the switch serves only that purpose, so with the switch gone, I didnt bother replacing the bolt.
kurtw is offline   Reply With Quote
Old 03-31-2004, 12:31 PM   #12
gozell
gozell's Avatar
Oddometer: 70
Hi Creeper,
Your post made my realise that im having the same problem with my 03 Adv, unable to start with clutch pulled in...
Had a quick fiddle and pulled the clutch switch from its socket without too much trouble... Perhaps i need to screw it in again or do some like you described above..
Will have a closer look tomorrow.
Grtz
gozell is offline   Reply With Quote
Old 03-31-2004, 12:48 PM   #13
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by gozell
Hi Creeper,
Grtz
Test the switch off the bike... it probably works. If you know someone with a small lathe, that would be the easiest way to turn down the shoulder of the switch.
Thats two. If it goes five, I'm gona' contact KTM.
Creeper
So... how's tricks?
Old 04-18-2004, 10:42 AM   #14
BlownCJ
dangerous rider ?
BlownCJ's Avatar
Oddometer: 153
Creeper
im there to creep my new bike only starts in neutral with clutch out
if ya stall it your fucked
got my 03 adv on friday in new hampshire put on 17 tooth ctrshft abd 42 rear sprocket ......... made to my home in north ga sunday morning at 6 am
grand happy ass total 1270 miles ....
BARRY new 03 640 adv
you know what i ride or you will learn
BlownCJ screwed with this post 04-18-2004 at 10:44 PM
BlownCJ is offline   Reply With Quote
Old 04-18-2004, 02:33 PM   #15
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Thats three. That is three isn't it?
So... how's tricks?
Times are GMT -7.   It's 09:58 PM.
