Old 09-23-2014, 09:30 PM   #1
Mr.JAJA OP
Mr.JAJA's Avatar
Oddometer: 416
Low Voltage
Ok , I changed the rear shock last Sunday and right after this the triangle Warning light stays on all times. brake light is of and works with hand and foot brake. servo is of and start humming when brake is applied. There is on blink and a low Voltage on the brake light wire when the ignition is first turned on. I have checked this with a LED test light. did'n have the Multimeter handy. What can go wrong by removing the rear wheel, brake caliper and changing the shock?
2004 GSA 1150 Adv.
Mr.JAJA
Mr.JAJA screwed with this post 09-23-2014 at 09:31 PM Reason: Ad Bike
Mr.JAJA is offline   Reply With Quote
Old 09-23-2014, 09:51 PM   #2
spafxer
spafxer's Avatar
Oddometer: 2,599
ABS sensor damaged ?
spafxer is offline   Reply With Quote
Old 09-23-2014, 10:12 PM   #3
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,666
Pull the wheel and caliper then re-install. Maybe the ABS spacing is out of whack.
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 09-24-2014, 08:26 AM   #4
Mr.JAJA OP
Mr.JAJA's Avatar
Oddometer: 416
Thumb ABS Sensor
I just checked the resistance on the ABS rear Sensor 7.4 Mega Ohm. Sound hight for a inductive sensor. If some one has on laying around and can check the resistance It will help me to get closer to the problem. The low voltage on the brake light is 4.5Volt.
Sensor need to be 135 +/_ 20 Ohm.
Have to find a replacement.
Mr.JAJA
Mr.JAJA screwed with this post 09-24-2014 at 08:39 AM Reason: Found it in the UK forum
Old 09-27-2014, 07:50 PM   #5
Mr.JAJA OP
Mr.JAJA's Avatar
Oddometer: 416
Alright
After changing the sensor everything is alright.
Mr.JAJA
Old 09-29-2014, 10:18 AM   #6
motoree
motoree's Avatar
Oddometer: 204
If you obey all the rules you'll miss all the fun !
motoree is offline   Reply With Quote
Times are GMT -7.   It's 06:47 AM.
