Old 08-27-2008, 07:20 AM   #1
toolfan OP
Broken Hearted
toolfan's Avatar
Oddometer: 9,543
1992 R100GS - Progressive shock rubs tire
I recently bought a '92 R100GS with a sidecar, and now I'm in the process of sorting it out.
The sidecar uses the same shock as the bike, the bike has a stocker, the hack has a progressive unit. I switched them over as an experiment last night (the stocker is way to soft, and I'm not a big guy.)
Anyway, the spring on the progressive hits the end of the tire (gripster.)
Anyone else have this problem?
Is there an easy cheap way to fix it and retain the stiffer shock on the bike?
toolfan is offline   Reply With Quote
Old 08-27-2008, 07:33 AM   #2
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,238
the spacer from a k75 with fix the problem. i think it's under 10 bucks.
bmwblake is offline   Reply With Quote
Old 08-27-2008, 08:25 AM   #3
toolfan OP
Broken Hearted
toolfan's Avatar
Oddometer: 9,543
Sounds like the first simple solution problem on the rig yet!
Old 08-27-2008, 08:43 PM   #4
GJUNKY
Oddometer: 50
Take a very close look at the shock rod where it goes into the aluminum under the snubber at the bottom there is a groove under the snubber where mine broke.!!!! My Progressive rubbed the tire just before the shock SNAPPED IN HALF!
68 Honda CT90
69 Honda CT90
93 GSPD
02 1150 RT
90 CR250
90 KX250
97 XR400
GJUNKY is offline   Reply With Quote
Times are GMT -7.   It's 01:45 AM.
