Old 08-28-2008, 07:19 PM   #1
cueball OP
should'a walked it first
cueball's Avatar
Location: lake serene, ms. at least it was 'til i moved in!!
Oddometer: 699
new airhead project!!
picked a 1975 r60/6 today . missing some bits, incorrect valve covers, rear signals & no telling what else. however, it runs ok, will run great after some tweaking, & i'm thrilled to get it !! (had an r50/5 in the early 70's & loved it)
here are some pics. hope you won't mind my asking for help on this project. i'm not sure if i should keep the supertrapp system---any thoughts??
anybody got a grab handle, seat rail, correct valve covers, tank emblems & rear turn signal set up??
frank
frank
lake serene
2007 r1200gsa, ducati st4, sherco 290, rocky mountain rm7 for true adventure riding!!
cueball screwed with this post 08-28-2008 at 07:29 PM
cueball is offline   Reply With Quote
Old 08-28-2008, 07:21 PM   #2
cueball OP
cueball's Avatar
Oddometer: 699
another pic
frank
lake serene
cueball screwed with this post 08-28-2008 at 07:22 PM Reason: pic didn't work
Old 08-28-2008, 07:24 PM   #3
cueball OP
cueball's Avatar
Oddometer: 699
sorry, can't help it!!
frank
lake serene
Old 08-28-2008, 08:01 PM   #4
kixtand
kixtand's Avatar
Oddometer: 2,077
Ahh yesss....the R60 w/ the much sought after front drum. Nice looking purchase all 'round from what I can tell.
Good luck--
kix
Bacon...
it makes everything better.
kixtand is offline   Reply With Quote
Old 08-28-2008, 09:44 PM   #5
P B G
Oddometer: 9,781
did someone rattle can the whole engine silver?
Old 08-29-2008, 03:22 AM   #6
halmc
Turkey T*urd
halmc's Avatar
Oddometer: 1,578
Originally Posted by cueball
another pic
Hey, what's all that crap in your garage? Kathy's right: you need to clean it out.
BMW R1200RT; BMW K1200RS; KTM 525 EXC; KTM 300EXC; '80 Yamaha IT 175H
If teachers had guns, I wouldn't have survived the seventh grade.
halmc is offline   Reply With Quote
Old 08-29-2008, 05:16 AM   #7
cueball OP
cueball's Avatar
Oddometer: 699
no, the po actually had it & the frame powdercoated (appears to be true--much tougher than paint), then quit the project when his wife got sick. it actually looks like a new engine more so than one that has been coated.
frank
lake serene
Old 08-29-2008, 03:41 PM   #8
cueball OP
cueball's Avatar
Oddometer: 699
shhhhhh!!
frank
lake serene
Old 11-01-2008, 07:31 AM   #9
jellycow
out there & loving it
jellycow's Avatar
Oddometer: 479
Why is the drum much sought after? I'm thinking about replacing it with double Brembo's on my 60/6.
[Sir Mix-a-lot mode]
I like big tanks and I cannot lie
[\Sir Mix-a-lot mode]
jellycow is online now   Reply With Quote
Old 11-01-2008, 09:15 AM   #10
P B G
Oddometer: 9,781
The drums actually work really well.
If you think about it the 70's are about the peak of drum brakes. Everyone was switching to disc, but the early bmw discs aren't the greatest, hence all the talk about converting single disc or dual ate's to brembo or what not.
Properly adjusted dual discs work well but so do properly adjusted/bedded drums, and with better period aesthetics.
Old 11-01-2008, 10:33 AM   #11
Kismet
vagrant philosopher
Kismet's Avatar
Oddometer: 387
The drums work very well when used to stop FORWARD movement.
I'd been riding slash 6s and 7s when I came upon a 70 R75/5. Awful shape, but young in miles. Brought it home, did the stuff you have to do.
But I park my bikes in sheds that I drive into, and then "walk" backwards to get out, and down a slight slope. Never a problem with the discs.
Imagine my surprise when I found that ?leading shoe? drum brakes don't stop BACKWARD movement.
Only took...er...ten or twelve instances before I caught on.
Loved that engine/tranny combo. SWB wasn't a problem for me.
Congratulations. You will make yourself very happy.
Kis
enjoy every sandwich
'75 R90/6
'78 R100/7, well really, R80/7
'87 Radian/fj600
'81 C70--IT'S ALIVE !!!!
Kismet is offline   Reply With Quote
Old 11-01-2008, 10:38 AM   #12
dlrides
1:1.618
dlrides's Avatar
Oddometer: 4,795
I would be interested in your drum set-up ! I prefer the drums over the early disc.
I must work, millions of losers are depending my taxes for a check.
dlrides is offline   Reply With Quote
Old 11-01-2008, 10:52 AM   #13
P B G
Oddometer: 9,781
You should try a band brake minibike sometime ;)
You learned something special, these brakes are Dual leading shoe, the concept being that as the drum and shoe interact the rotational force of the drum actually grabs the shoe and puts more pressure on it increasing brake force.
But in reverse the rotation of the drum counteracts your hand actually you end up with a dual trailing shoe set up in that instance, which is never found on a vehicle. Since a single leading shoe design requires one cam that actuates two shoes, a dual leading shoe requires two cams (or hydraulics) to drive the leading edges of both shoes which are on opposite sides. To make a dual trailing is equally compled as dual leading!
Anyway that's part of the set up of these brakes is that you have to have both cams set up to get shoe contact with the drum equally, and you wnat the majority of the shoe touching the drum when in operation, not just a tiny portion of the tip. That's where bedding brake shoes comes in. Once adjusted they are just good lucking.
Old 11-01-2008, 11:43 AM   #14
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,354
Is that true that these drum brakes don't work well in reverse? I don't ever recall having a problem, but then again, I never developed much need for lotsa brake in reverse.
Old 11-01-2008, 11:50 AM   #15
P B G
Oddometer: 9,781
The better the shoes are adjusted the better they will work in reverse. That being if you have little contact and its all at the leading edge then the brake will fight your hand. If however you have pretty good surface contact when you brake there will be enough surface area on the shoe to do a decent job.
Just need a turn table/lazy susan in your shed to spin them on. I use a peice of plastic and a rope to turn mine in the garage.
Times are GMT -7.   It's 12:07 PM.
