Old 08-30-2008, 05:56 AM   #1
CaribouCases OP
Boulder CO
CaribouCases's Avatar
Location: Adventure Rider & Aftermarket Systems Manufacturer
Oddometer: 1,223
R100GS Fuel Line Replacement
I recently picked up a nice '94 R100GS, it needs a little love. My fuel lines are old and leaky (the ones on the bike smart guy). Is it possible to fish out the one that goes under the air box without having to take the air box out?
I searched topic to no avail.
Caribou Luggage Systems.
PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain
CaribouCases is offline   Reply With Quote
Old 08-30-2008, 06:17 AM   #2
phactory
Motorcycle Rescue
phactory's Avatar
Oddometer: 438
If you are going to replace the fuel line with the 7mm cloth braided fuel line that BMW sells, you will have to at least loosen the airbox to slide the fuel line through the opening. There are 2 bolts that attch it to the top rail of the tranny and one that attaches it to the top of the tranny. Not that big of a deal really.
PhacK
"There are only two true sports: bullfighting and auto racing. The rest are simply games," Ernest Hemingway
phactory is offline   Reply With Quote
Old 08-30-2008, 06:26 AM   #3
dfc
Reluctant Cannonball
dfc's Avatar
Oddometer: 2,767
Bing sells some nice urethane stuff, thats what I used.
YMMV
http://www.bingcarburetor.com/
'twas ever thus
dfc is offline   Reply With Quote
Old 08-30-2008, 08:38 AM   #4
CaribouCases OP
Boulder CO
Oddometer: 1,223
Thanks. I got the old one out and there was no way the new one was going back in without loosening up the airbox. Basically had to take the left carb partially off to get all the air/emissions parts out of the way to access those 3 bolts holding the box to the tranny. Would have been nice if there was a tube in there to slide the crossover fuel line in and out .
Old 08-30-2008, 09:17 AM   #5
jackd
Oddometer: 3,046
I Had No Problem.
I changed my fuel lines without loosening my airbox on my R100GS. I purchased my fuel line from MAX BMW (standard fuel line - not the fabric covered variety) and fed it into the cross-over space under the airbox. MAX coils the line when they ship it, so the line has a tendency to not travel straight and therefore snag on the gearbox structure. I just fed in a straight welding rod from the other side of the box and used the end of the welding rod to guide the hose end through the tight opening. Done in minutes - no bolts or carbs removed. Jackd
Old 08-30-2008, 12:28 PM   #6
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
you CAN fish out and "twist" through the braided stuff without loosening a single bolt. It's a pain, but it can be done.
Bing's special fuel line recently change. Not the same wonderful stuff they used to have.
Spare yourself the money and pain and just go buy 1/4" ID black urethane fuel line from Dennis Kirk or the like. Cheap, better, easy.
datchew is offline   Reply With Quote
Old 08-30-2008, 01:45 PM   #7
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,476
Sorry to hear that the bing line has changed, I liked the old stuff. Lots of folks I know of use a cloth covered line you can buy from VW parts suppliers. Like the BMW stuff but less expensive.
You can get the cloth line through there without removing stuff. I usually put a thin wooden dowel through it and that helps/
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 11-19-2012, 04:38 AM   #8
Hi Viz Guy
Hi Viz Guy's Avatar
Oddometer: 331
R100 GS Fuel Line Diameter
What is the fuel line diameter for the R100 GS?
Getting ready to order up some new fuel lines and filters...
Be Seen & Be Safe
Hi Viz Guy is offline   Reply With Quote
Times are GMT -7.   It's 12:56 PM.
