Old 03-30-2010, 10:20 AM   #31
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 3,253
Back from the depths.....
Ok, I have my forks apart to do this update/mod just in time to hurry up for the spring rally a few weeks away. The clunking has been quite annoying on full extension.
I have gone over this thread for my part numbers, (Thanks Phack) and the one thing I cant seem to find is the large O-ring that fits in the bottom of the fork leg to seal the lower cap. Anyone have any ideas where I may find this culprit on the fiche ?
TIA
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 03-30-2010, 11:24 AM   #32
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 5,516
Since this thread fell into obscurity, I'm pretty sure I've traced my particular clunk to the dash mount bracket flexing on sharp bumps. I can hold it with one hand and pull against it and silence the clunk over bumps that normally cause it.
Now what is actually clunking under the plastic trim remains to be discovered. I can't find anything loose in there.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 03-30-2010, 01:01 PM   #33
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 3,253
Mark do you mean the mount for the instruments on the rubber bushings ?
Other than that I'm stuck. Went to the local dealer and he tells me that
part #31-42-2-301-885 is no longer available from BMW, so I may not be able to do the update unless I find a dealer with the parts covered in dust on the shelf.
Mike
Old 03-30-2010, 06:28 PM   #34
mark1305
mark1305's Avatar
Oddometer: 5,516
Mike, when I run that part number through the Max BMW fiche, its available for under $3 (remove the dashes to search part numbers). And its listed for a whole bunch of bikes. Valve housing down in the shock absorber part of the forks, correct?
http://www.maxbmwmotorcycles.com/fic...31422301885%20
In my case, yeah, the clunk is either the plastic fairing around the instruments or the instruments flexing the stamped sheet metal "Panel" that holds tach, speedo, and headlight. The headlight is held pretty rigidly, so I suspect a combo of instruments and plastic fairing bouncing and hitting over bumps.
Mark J
Merritt Island, FL
Old 03-30-2010, 07:54 PM   #35
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 1,600
Try checking the wear on the large centre nut at the upper yoke.
These can wear over the years. Remove it, and replace with a shim made from an alu drink can, applied over the forward facing surface. Does Grolsch come in a can?
It's an easy test, and cheap to try. Might get lucky.
boxerboy81 is offline   Reply With Quote
Old 03-31-2010, 05:44 AM   #36
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 3,253
Mark, I had the local dealer run it on "lightspeed" I think part locator and it showed NLA in the US and the Fatherland, he called BMW parts help in Jersey too.
I spoke with Craig at Benchmark works yesterday afternoon and he said his parts source in europe shows it available. I will know in 3-4 weeks if it shows up. I may call a few others in the meantime in the event some are laying on the shelf somewhere.
Hey I've got 3 weeks till the rally right, plenty of time.
Mike
Old 03-31-2010, 05:44 AM   #37
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 3,253
Thanks, I'll check the clearance at the large center nut too.
Mike
Old 03-31-2010, 03:17 PM   #38
spo123
spo123's Avatar
Oddometer: 453
Talking
Rusty, at Max BMW in NH, is absolutely THE BEST PARTSMAN ANYWHERE!
spo
spo123 is offline   Reply With Quote
Old 03-31-2010, 05:25 PM   #39
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 3,253
spo
I called and spoke with Rose yesterday, Rusty won't be back from vacation till tomorrow.
Mike
Old 10-23-2012, 09:16 PM   #40
rustygardhouse
rusty
Oddometer: 24
So...
How did this end?
Smiles or tears?
Did you find a source of 31 42 2 301 885 VALVE HOUSING?
Got the same problem on my '80 R65 & looking for a fix.
rustygardhouse screwed with this post 10-23-2012 at 11:29 PM
rustygardhouse is offline   Reply With Quote
Times are GMT -7.   It's 11:37 PM.
