Closed Thread
Old 04-05-2010, 10:00 PM   #241
Nasty1
Nasty1's Avatar
Oddometer: 64
Hey Wachs
I have been reading about the GL and looking at your site....some nice kit you have there The trouble I am having over a possible purchase for my next bike is still the fixing method.
Your first incarnation was bolted up...but not quick release! Your second is pulled up with straps and easy to remove but maybe not so rigid!
So I got to thinking could the best of both worlds be Incorporated as an option to/along side the second generation model that is all strapped on? I am thinking of a base plate that is mounted similar to the first generation bolted up design that would allow the GL bag itself to be zipped to it...basically just like a lot of the quick release tank bags you see now.
This may prove too expensive and over complicated but just thinking a little out the box??
Keep up the good work
Adie
2009 Triumph Bonneville/Scrambler hybrid! Under Construction
Nasty1 is offline
Old 04-06-2010, 05:40 AM   #242
mattc
mattc's Avatar
Oddometer: 443
I was on the verge of ordering one this morning, but no more white???
Will white be available again anytime soon?
mattc is offline
Old 04-06-2010, 05:54 AM   #243
rosscoact
need constant supervision
rosscoact's Avatar
Oddometer: 5,503
I have a question on carrying bladders.
I have a coyote and need to carry an extra 27-30 litres of fuel and 8 litres of water. I was thinking of carrying the water in 4 litre bladders at the bottom on each side.
The fuel is in 3 x 10 litre bladders. One behind me on top of the bag, it gets emptied first. The other two I was planning on lashing (using the straps) to sides of the coyote next to the bike. I would then use metre long zip ties to fix them through the corner holes over the seat of the bike.
does this sound like a plan or is there a better way?
Stupidity got us into this mess, then why can't it get us out? Will Rogers
www.transaustraliatrail.com.au
rosscoact is offline
Old 04-06-2010, 08:45 AM   #244
xymotic
xymotic's Avatar
Oddometer: 8,367
The only problem with this is that the Coyote is waterprof, if the bladder breaks, you will soak everything in fuel/water.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline
Old 04-06-2010, 11:21 AM   #245
Nasty1
Nasty1's Avatar
Oddometer: 64
Having re-read my comments and yours and thought a bit more about it is clear you are the expert I am not really sure what I was trying to achieve as listening to what you have said and looking at your strap design further there is not a lot more that could be done to improve the system. Once I source a XRR BRP here in the UK I will probably be looking to buy. I see you have UK agent now but may come direct.
Cheers
Adie
Originally Posted by wachs
Thanks Adie - in my experience as a designer for alpine mountaineering gear and clothing, we learned that zippers are the 'weak link' in any truly high pe rformance piece of gear. That's why all of our saddlebags have a redundant compression strap. No matter how hard you crash, should the zipper blow, there is still a method for containing your stuff. So, to rely on a zipper to attach anything other than a tank bag (it sits in a very protected area) is risky. That is also why we spent the extra $ on custom YKK # 10 zippers. They are the burliest available and with proper maintenance can handle, dirt, dust and mud. There are more waterproof units available, like those found on dry suits but they are actually quite delicate and designed strictly for an aquatic environment.
The Coyote is not unlike a rubber raft - when it's properly filled, it is tailored to become its own structure. If the raft is only half-full it will still float but it's mushy and not as strong as it is filled tight.
Thanks again for your thoughts and input, we are constantly looking for ways to improve and appreciate the feedback!
Nasty1 is offline
Old 04-06-2010, 01:30 PM   #246
rosscoact
rosscoact's Avatar
Oddometer: 5,503
The best way to carry fuel is in an approved fuel cell mounted to the bike (obviously). But we are consistently asked by Husky owners about packing fuel as their after market choices are limited. In the past, we packed a gallon in a fuel can in a backpack and after the first 40 -50 miles, dumped it in the gas tank. That sucks and is probably illegal. Since then, we've outfitted our bikes with 6+ gallon Acerbis desert tanks and even though they ride kinda weird when full, we've never had a fuel issue since.
We've heard about those bladders you guys have and that they are approved to carry gasoline but we don't have any experience with them. If you are able to get that going, please let us know how it works!
No worries. I'll go for a test ride in a couple of weeks and take some pics. The fuel bladder must go on the outside as the smell comes through. The big issue besides having them secure, is carrying an extra 32kg on the back of an already loaded bike
Old 04-06-2010, 07:36 PM   #247
mattc
mattc's Avatar
Oddometer: 443
We could not sell any white units and now, all of a sudden, we are receiving request for that color! I have been using a white Coyote on our XR and it's great. Doesn't get nearly as hot in the desert sun and is really easy to see your stuff inside. With use (I never clean other than hosing it off) it acquires a kind of 'patina' not unlike a favorite leather jacket.
I'll know if we are going to produce any more white by the end of the month - stay tuned.
Thanks for the response, and please do let me know if they will be available.
mattc is offline
Old 04-12-2010, 03:09 PM   #248
Jwats
Bike till u Die
Oddometer: 178
Gl
On our BAJA 2009 trip,1 rider had a GL bag it worked very well. this year in BAJA myself & another rider had GL bags. The bags we used are small & perfect for minimalist travel. There is a RR on this site. three wyoming boys in baja. Thanks for a great product.
Jwats is offline
Old 04-17-2010, 03:22 PM   #249
Timmer
Timmer's Avatar
Oddometer: 2,361
I saw the product in person at the SouthSound BMW vendor faire today. Looked great (yellow and black varieties were there along with the tank bag).
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline
Old 04-19-2010, 07:52 PM   #250
30Bones
30Bones's Avatar
Oddometer: 4,648
Aces! Bag worked great all weekend, several hundred miles, single track and a fair amount of drops, once in the water...everything inside was dry.
30Bones is offline
Old 04-21-2010, 04:23 PM   #251
JTucker
JTucker's Avatar
Oddometer: 2,270
Trying mine out for the first time this weekend. This thing holds a lot of stuff.
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline
Old 04-22-2010, 03:53 AM   #252
Road Kill
Road Kill's Avatar
Location: Melb,Aus,Earth,Sol,Milky Way,Only Known Universe
Oddometer: 225
mix colours in GB bag and Fandango
G'day Wachs,
I want to order the Great Basin bag along with the Fandango tank bag. However, I want the Great Basin Bag in yellow and the Fandango bag in black. Is this possible?
Cheers
07 BMW G650 XChallenge
Road Kill is online now
Old 04-22-2010, 03:57 AM   #253
Nasty1
Nasty1's Avatar
Oddometer: 64
Is that Trials tyre??
Adie
Nasty1 is offline
Old 04-22-2010, 07:23 PM   #254
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,355
I emailed them and got a phone call the next day.
joenuclear is offline
Old 04-22-2010, 08:40 PM   #255
Road Kill
Road Kill's Avatar
Oddometer: 225
Thanks guys. I've email them at their web site as well.
I'll patiently await their reply
Closed Thread
Times are GMT -7.   It's 03:20 PM.
