09-03-2008, 01:43 PM
#1 |
Oddometer: 45
Hi All,
I loaded up the Iceland map from http://www.ourfootprints.de/gps/mapsource-island_e.html into MapSource, and the map looks distorted (image below) I thought Iceland was taller than that ![]() I have a message in to the webmaster there, but have no heard anything back yet. Does anyone have experience with this map, or know if I need to change some setting in MapSource? |
09-03-2008, 06:21 PM
#2 |
Traveller
Oddometer: 6,593
Might simply be the way mapsource projects the image on the screen .. 1 degree in either direction being a square? Try it. If so - than as you get closer to the poles the distortion becomes large...
And your peception of tall vs wide for Iceland comes from where ? Maybe that is distorted too... All a question of projection .. I'll just go look at a globe for reality check .. well a little squashed ... but not more than could be explaind by different projections .. maybe your are thinking of Greenland? That is a bit more triangular... |
09-03-2008, 07:42 PM
#3 |
Oddometer: 45
Thanks Frank,
There's a good chance the projection in mynd is distorted yes but I figured it would be proportioned like on the googlemaps -http://maps.google.com/maps?ie=UTF8&...,20.588379&z=6 So I drew out a 100km distance each direction using the measure tool in MapSource (image below), it thinks that yellow rectangle is equally 100km on each side. It doesnt do that when I have other maps loaded, so Im confused. I will try installing it on the GPS to see if it looks right. |
09-03-2008, 07:59 PM
#4 |
Oddometer: 45
Ok, I think I get what youre saying with the degrees, Im dense.
I guess Ive never seen a map this far north on the software, still seems odd to me. |
09-03-2008, 08:48 PM
#5 |
Oddometer: 45
The map looks fine once it's loaded into the unit, proportions look as I would expect. Dont know what the deal is with MapSource.
Awesome map, lots of POI's, topo as well. Much thanks to the folks at http://www.ourfootprints.de. I hope to use this soon |
09-07-2008, 01:27 PM
#6 | |
Alps Adventurer
All the best, Alex Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure Euro & Alps Motorcycle Tours - Priced Right, How to go about Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein |
09-08-2008, 08:20 PM
#7 | |
Traveller
Oddometer: 6,593
Just the 'easy' way mapsource deals with the map data .. KISS ... not usually a problem .. as most as around the equator, and most zoom in .. |
09-19-2008, 04:36 PM
#8 | |
Oddometer: 45
Hey Frank,
Just got back from Japan, and getting to this now. I had checked it out by degree as you suggested, then it made sense. Also, heard back from Tom at http://www.ourfootprints.de, he confirmed the distortion from the map projection and attributed it to a recent MapSource update. And that it should look and work normally on the unit itself. It looks normal in the unit and Im going to go try it out next week. Quote:
Anyone want to recommend some sites, or must see's? Itll be late Sept - Nov, that limits some things a bit. |
10-11-2008, 07:42 PM
#9 |
Oddometer: 45
Back from Iceland
The map worked great, and we were able to check it along side a Nuvi that had the Ísland Kort loaded, until the Nuvi was stolen
![]() From there we relied on the ourfootprints.de map solely to get around, no auto-routing, but accurate and lots of poi's built in, it did the job. Beautiful country, I will definitely go back when things are better. -Steve |
11-11-2008, 03:28 PM
#10 |
Oddometer: 31
If you use MapSource 6.14.1 the Island map will by distorted, but if you use MapSource 6.13.7 or older the Island map is OK. I had to change back from 6,14,1 to 6,13,7 because of this.
11-12-2008, 10:14 AM
#11 | |
Oddometer: 45
Takk fyrir ţađ
I was just reading one of your other threads, hope your collarbone is mended, and I will be interested to hear how the shipping of your bike went. -Steve
'07 XR650L |
11-12-2008, 01:38 PM
#12 |
Oddometer: 31
Going back to 6,13,7 you lose the possibility of "user specified colors for routes" that is in 6,14,1 you can have a map that show track for example 4 days ride and for every day the track has a different color. Very smart but the map must look right so I changed back to 6,13,7.
The collarbone is better but far from OK and the bike will by back in Reykjavik beginning of December. Eimskip a Icelandic transport company will transport the bike. |
11-12-2008, 01:55 PM
#13 | |
Traveller
Oddometer: 6,593
Good that the map worked well. ----------------------- I'm using 6.13 at home - that showes the 'distortion'. As it is simply a projection 'problem' I'm not worried by it. No matter what projection they chose to use there will be distortion somewhere.. and that particular projection does mean navigation by compass is simple. Not tried it on the GPS it self - as I have 60Cx (small screen) I don't think any distortion will be evident (zoomed in too far for it to show). |
11-14-2008, 10:53 AM
#14 | |
Oddometer: 45
We all chipped in for a new one for our freind, and on the bright side- we had some fun running around to price compare in a bunch of stores and shops. Not to forget, we had the other GPS as backup. So I installed 6,13,7 on another computer that Im switching to, and the map looks proportional, so I have the luxury of running both for now. Not to make any more fuss about the projection, I realize it is correct and not really a 'problem' or 'distortion', but IMO it is easier to use when the dimensions are 1:1. No offence to any cartographers out there GB - Thanks for the tip, and the info about Eimskip. Hope you're well and riding again soon.
'07 XR650L |
