Old 10-20-2011, 06:11 PM   #16
DriveShaft
Oddometer: 3,518
Originally Posted by PoundSand View Post
blackberry mini usb cables are not proprietary. i use my blackberry charger to charge other devices, and use other cables to charge the blackberry all the time.
yeah. some usb cables have the data pins shorted to prevent the device from going into data mode and / or triggering a faster charge.
The Nook, apparently, uses some effed up usb cable.
DriveShaft is offline   Reply With Quote
Old 10-21-2011, 10:46 AM   #17
PoundSand
PoundSand's Avatar
Oddometer: 4,354
no, i got one of those too- standard usb.
PoundSand is offline   Reply With Quote
Old 10-24-2011, 12:35 AM   #18
bikecat
bikecat's Avatar
Oddometer: 1,007
Thanks, but standard USB cables do not work for the Zumo 220 to enable it to be used for powering (as opposed to charging). It goes into data mode unless a Garmin charger is used.
bikecat is offline   Reply With Quote
Old 10-24-2011, 12:47 PM   #19
DriveShaft
Oddometer: 3,518
http://en.m.wikipedia.org/wiki/Nook_Color#USB_port
compatible for the sake of charging (albeit, at a slower charge rate), but the nook color definitely does *not* use standard usb
Old 10-26-2011, 09:35 AM   #20
PoundSand
PoundSand's Avatar
Oddometer: 4,354
ah, you said nook, not nook color. ;D
"The original Nook utilized a standard micro-usb connection for both battery charging and PC connectivity."
Old 10-26-2011, 03:20 PM   #21
neanderthal
globeriding wannabe
neanderthal's Avatar
Oddometer: 1,533
When I connect my HP Touchpad to any mini usb to charge it I get an error message along the lines of "You have connected this device to a charger that is not original. Connect a genuine HP powercord to charge your device."
I can't charge the damn thing in the car when i'm going to or coming from somewhere.
'O=00=O'
BMW 2002. long live the legend
neanderthal is offline   Reply With Quote
Old 02-22-2012, 10:47 PM   #22
swingarm
Oddometer: 10
I'll probably end up buying the Powerlet. I like that a the fuse holder is included. I'm not so fond of the price, though.
http://www.powerlet.com/product/mini...ry-harness/258
Actually, this one sounds a little better, but I'm pretty sure the USB connector has it's 90° bend facing the wrong way.
https://buy.garmin.com/shop/shop.do?pID=87417
swingarm screwed with this post 02-22-2012 at 11:10 PM Reason: left something out
swingarm is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 04:34 AM.
