Old 09-07-2008, 01:01 PM   #1
paulsgs OP
paulsgs's Avatar
Oddometer: 125
Just Installed ROX on a 08 1200 GS
Put them on yesterday. After reading ALL the threads about it, I'm not completely satisfied. I mean, they look great and feel terrific with the extra height, the cables dont feel/look right.
First, the right side- I dropped the leg and dragged both cables on the other side. That seemed to put so much pressure on lines when the bars were turned right I thought something would snap. I loosened the bold on the "L", and next thing I'm loosing brake fluid. Anyway, I put the cables back where they started.
I left The throttle cable as is after the leaking brake fluid.
The left side-I started to drop that leg, then stopped in that it did not seem too bad (but snug none the less when turned).
What next? I dont know, I guess some suggestions ....or do I just get used to the snuggness?
2008 R1200GS -Titan Silver Metallic
TT Engine Guards
TT Oil Cooler Guard in Black
Vario Side and Top Cases (used)
BMW Tank Bag -Small
TT Under Tail Rack Bag
Larimar Lip
ROX Risers
Stebel Horn kit from Excel
Photon Blaster Front /Back Leds
Maier Front Fender Extender
Maier Rear Fender Mud Guard
IIlium Sidestand Footpad
PIAA H7 Super Whites 55W
Clearwater Krista Driving HPLED's
paulsgs is offline   Reply With Quote
Old 09-07-2008, 02:27 PM   #2
pavement pounder
Dirt is the spice of life
pavement pounder's Avatar
Oddometer: 743
the clutch hose can be loosened by removing one zip tie on the frame by the forks. I think it was the first one you come across as you work your way down the hose. Then, (and this is where you will get the most satisfaction) on the left side of the bike, find the hose leading to the back of the transmission, on the frame you will see a triangular frame section with a grey zip tie on it. Move (don't cut) this zip tie up until the hose can be perfectly horizontal. (you'll see what i mean when you get there). This will free up the hose enough for you to sleep at night. It is now "perfect" as for the throttle side, i moved the mirror bracket in about 1/4" as well as the clutch side. Play with the angle of the pivot and the angle of the bars and you will find satisfaction.
cb
The road to paradise is UN-paved!
go for it! Life's too short to think twice!
Charlie B. (The other Boorman)
Trans-Lab 2010 - James Bay 2011 - Shenandoah to Deal's Gap 2011
pavement pounder is offline   Reply With Quote
Old 09-07-2008, 02:32 PM   #3
pavement pounder
Oddometer: 743
here's one.
Old 09-07-2008, 05:57 PM   #4
paulsgs OP
paulsgs's Avatar
Oddometer: 125
cb
Wow, Thank you CB........! Ok, removed the first tie I found going down the frame, and, moved the one up at the triangle....that made a great difference. I Am now going to move the mirrors each in 1/4 and will report back. Have you rerouted the throttle cable under the bars? Or am I wasting my time?
TT Engine Guards
BMW Tank Bag -Small
Larimar Lip
ROX Risers
paulsgs screwed with this post 09-07-2008 at 06:39 PM
Old 09-07-2008, 06:45 PM   #5
paulsgs OP
paulsgs's Avatar
Oddometer: 125
Ok, I moved each mirror in 1/4 and that helped as well. Thank You. Also, one other thing I did was put a piece of plain white paper (it was suggested somewhere in the forum) between all points of contact as a suggestion to prevent slipping.
TT Engine Guards
BMW Tank Bag -Small
Larimar Lip
ROX Risers
Old 09-08-2008, 06:27 AM   #6
pavement pounder
Oddometer: 743
no need to move throttle cable
There is no need to re-route the throttle cable. Just make sure that you test it to make sure it doesn't get too tight (but it wont) when you turn lock to lock. (full left, full right turn) with engine idle (in neutral of course) turn bars fully, it idle goes up, you need to make some slack. I didn't have a problem.
Old 09-08-2008, 06:36 PM   #7
paulsgs OP
paulsgs's Avatar
Oddometer: 125
Thanks ! Mine looks exactly as yours, and I did those tests in neutral and NO problems. So Thank YOU PP and CB.
By the way, I put more miles on them today and wow what a difference, it really changes the ride (positively). Although I dont do a lot of peg standing, I did try and it is great! Thanks.
TT Engine Guards
BMW Tank Bag -Small
Larimar Lip
ROX Risers
Old 09-09-2008, 04:18 AM   #8
pavement pounder
Oddometer: 743
I found that it completely eliminated shoulder burn (neck burn) from the previous setup. I have done 2 longish trips since the install and find them to be a really nice addition. I didn't have any problems with slipping, in fact, i had a hard time to rotate them where i wanted and then tighten the bolts. I only tightened two of them firsts, the located, then the others. I had a wobble drive extension. It helped.
good luck
cb
Old 04-22-2009, 10:46 AM   #9
N1 Qualified Man
Impulse Purchaser of Moto
N1 Qualified Man's Avatar
Oddometer: 101
cb
thank you cb. i just installed rox risers and this worked perfectly (along with moving the clutch & break controls in by about 1/2in.
anyway, thank you!
oG
'08 R1200GS Adventure
N1 Qualified Man is offline   Reply With Quote
Old 04-22-2009, 01:58 PM   #10
tyler73
n00b 'bout covers it...
Oddometer: 148
This was my problem with ROX. Cable destruction in the circle caused by sharp edges on the machined ROX parts.
Fixed in under 2 minutes using this thread. Routed cable under the bars and zip tied the excess to the brake lines. I had plenty of slack on the clutch/brake/electrical lines.
tyler73 is offline   Reply With Quote
Old 04-22-2009, 09:26 PM   #11
German
Ich liebe Bayrischen Mist
German's Avatar
Oddometer: 349
Wunderlich
I just installed the Wunderlich vario risers and they work wonderful. I did not have the reroute any cables etc. I do like the Roxy and they are lot more affordable than the Wunderlich at $235. I was not too crazy about the shiny look.
Niemals nie sagen
Immer wie eine Drecksau fahren
1200 GS Yellow Desert
German is offline   Reply With Quote
Old 04-23-2009, 04:02 AM   #12
pavement pounder
Oddometer: 743
BMW now puts a piece of plastic there to prevent scraping. The only place it touches on mine is the bar, not the risers. (or at least not hard) Great post BTW.
Old 08-29-2009, 05:48 PM   #13
Cumminsman76
befuddled
Cumminsman76's Avatar
Oddometer: 8,138
Are the handebars on a GS Adventure 1 1/8"?
STURGIS ride report.
2009 R1200 Gelände/Straße Abenteuer
A GS is like chlamydia, it grows on you whether you want it to or not. WhiteManFlail
Save $5 on Smugmug "1alkVgTNLEuyQ"
Cumminsman76 is offline   Reply With Quote
Old 07-07-2010, 01:05 PM   #14
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 657
fits a 2010 also
To update this thread, I just installed my rox risers w/vibration dampening on my 2010 GS. I didn't need to reroute the cables after clipping the first clutch zip tie and moving the clutch zip tie in this pic from PP so that the line was horizontal.
PP, Thanks for that idea. And here's a link to a video of an installation on an 08 GSA http://vids.myspace.com/index.cfm?fu...deoid=31550745
here's one.
Doc Reid
2013 GS LC Red (the fastest color )
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 07-31-2011, 08:21 PM   #15
AZuwere
AZuwere's Avatar
Oddometer: 358
Ditto here, I just installed the 2" Rox on my 2011 GSA and only needed to cut one tie wrap. Easy job, 20 minutes or less. Except for the trip to Harbor Freight for the weird Torx head sockets.
'11 BMW 1200GSA
''11 Husky TE449
'08 Polaris RZR
'09 Vespa GTS 250
AZuwere is offline   Reply With Quote
Times are GMT -7.   It's 11:12 PM.
