Old 03-25-2013, 07:28 PM   #2626
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,885
Originally Posted by farcall View Post
She's finished... well, for now at least.
Maybe I spoke too soon.
She's using way too much oil for my liking - 500ml per 600km . I'm surprised seeing that she's only done 60,000kms. Anyway, the motor is coming out and I'll hand it over to someone with more mech skills than me to refresh the top end. TBC, but valves seem to be the culprits. While the heads are off, will examine for any other bits to replace... the bike is a keeper, so I'm taking a long term approach and not gunna scrimp just to make a short term saving.
Will have to ride the DR or HP2 to Birdsville next month. Unbelievably disappointed not to be taking the AT . What an epic courtship this is proving be. Purchased in April 2012, licensed Sept 2012, but wont be able to use it for its intended purpose (multi-day rides) until OCR Aug 2014!
01 Africa Twin RD07A (x2)
05 HP2
11 K1600GTL
farcall is offline   Reply With Quote
Old 03-25-2013, 08:12 PM   #2627
Backonthebike
Giddy up
Backonthebike's Avatar
Oddometer: 675
Oh hell Shane, just when I was satisfied with my 87 Transalp, you go and do that. Well done and good luck with it.
Prick!!
Cheers
Tim
(NSFW) http://timothydunn.com.au/
I have come to accept that my role in life is simply to serve as a warning to others.
Backonthebike screwed with this post 03-26-2013 at 03:45 PM
Backonthebike is offline   Reply With Quote
Old 03-26-2013, 12:36 AM   #2628
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,239
That's a bummer Shane...sorry mate, had no idea.
Are you certain that it's nothing to do with fueling. An overrich mixture or choke stuck on can wash oil off the bores and what oil are you running if you don't mind me asking.
That bike looks so SWEET btw !!!!
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 03-26-2013, 12:53 AM   #2629
Hodgo
TWIN Cylinder ADV
Hodgo's Avatar
Oddometer: 1,591
Remove the chokes all together. I did. They have a nasty habit of sticking.
Hodgo Spot
My North America Trip
RD07 Africa Twin, KTM 950 Super Enduro
www.facebook.com/KTM950SE
Retired.. CR500E & lots more
Hodgo is offline   Reply With Quote
Old 03-26-2013, 02:14 AM   #2630
Thunder Dan
Thunder Dan's Avatar
Oddometer: 780
Geez Mate,
That's properly annoying. If Hodgo & Willy's suggestion is no good, and you still end up removing the engine, here is my suggestion on minimum work at this point:
1. Recondition Heads;
2. Hone & re-Ring (pending measure up of bores & pistons);
3. Timing Chains & Guides;
4. Clutch & Stator Cover Gaskets / Seals if applicable; &
5. Optional whilst clutch cover off - inspect clutch & install heavy duty clutch springs.
Cheers,
Dan.
Thunder Dan is offline   Reply With Quote
Old 03-26-2013, 03:27 AM   #2631
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,885
Thanks fella's.
In the 1,500kms I got to ride it, I was getting 5.5 ltrs/100km... so logic was telling me that it couldn't be running rich. But to eliminate running rich as the possible cause, I got it on a dyno and told the guy the background. After dyno he concluded it was running spot on, if anything a touch lean, but he said he wouldn't change anything. He commented that the blue smoke on overruns(?) probably meant the valves will need attention in the near future.
So then I took it to a mech here who has worked on these v-twins in the past and asked him to balance the carbs. After mucking around with it for a while, and not being able get the carbs 'just right' and the blue smoke seeming to get worse, he removed the plugs. The rear plugs were OK but the front were wet with oil. He stuck a screwdriver down the pot and said to me "mate, there was that much oil in there, the screwdriver was like a dipstick, the heads gotta come off, its gunna be the valves".
To save myself plenty of $$$, I'm taking the engine out. He gave me a good lead on a specialist engineer in Perth with a great reputation in the industry.
Hey Willy, no worries mate, there's no way either of us could know what was lurking in there.
Dan - Thanks. Appreciate the tip mate. I was chasing that sort of info from the poms but got no answer. Thanks again.
05 HP2
11 K1600GTL
Old 03-26-2013, 07:11 AM   #2632
Squily
Squily
Squily's Avatar
Oddometer: 1,224
If its valves, do both heads and fit bigger inlet valves. You won't be sorry.
Not being a professional, but I could do the motor for you as well if you're interested (at least I've got Africa Twin experience )
Squily
Squily is offline   Reply With Quote
Old 03-27-2013, 03:41 PM   #2633
farcall
Bike-a-holic
farcall's Avatar
Oddometer: 1,885
Thanks Squily. PM on its way soon.
05 HP2
11 K1600GTL
Old 03-30-2013, 10:49 PM   #2634
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,123
Ride through Bellthorpe yesterday was a bit wet and a huge tree down.
The TA and AT battled through the mud though.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 04-08-2013, 03:53 AM   #2635
Thunder Dan
Oddometer: 780
Hey Cruz,
Bugger me I missed this post. Who is on the AT?
Cheers,
Dan.
Old 04-08-2013, 07:55 AM   #2636
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,123
Tim, but he put it up on Fleabay last week and the next morning it sold. It was a very good one too! One of the boys on here has it now.
xronly
Old 04-08-2013, 08:30 PM   #2637
Backonthebike
Giddy up
Oddometer: 675
Still doesn't stop me lusting after one. Problem would be that I'd have to sell the Transalp, and she's like one of my kids now. I'm thinking of leaving my house to her when I die.
Old 04-09-2013, 10:06 PM   #2638
Squily
Squily
Squily's Avatar
Oddometer: 1,224
What you do with your V-twin this weekend?
http://www.advrider.com/forums/showpost.php?p=21150289&postcount=42
Squily
Old 04-09-2013, 10:56 PM   #2639
Backonthebike
Giddy up
Oddometer: 675
What did you do with your V Twin on the weekend?
Left it hibernating uder its winter coat while I got pissed with you at Angorichina and rode my pissy little DRZ.
Good to see you made it home safely John.
Catch up again.
Cheers
Tim
Old 04-09-2013, 11:01 PM   #2640
Squily
Squily
Squily's Avatar
Oddometer: 1,224
I do rmemeber seeing some pictures of you lying against a road-sign somewhere. Seems the DRZ was a little ruff on you (you know what they say about young love and old men).
Stick to the V's mate- they's never leave you
Was nice to c u 2
Squily
Times are GMT -7.   It's 07:33 AM.
