Old 04-11-2013, 04:06 AM   #2641
Thunder Dan
Thunder Dan's Avatar
Oddometer: 760
Awesome Squily, thanks for the write up!
Getting itching feet here. Getting pretty close to finishing this next phase of mods & do a few short trips before Bills memorial run to Big Red.
Damn, that was a decent hole in the Varadero case!
Cheers,
Dan.
Thunder Dan screwed with this post 04-11-2013 at 07:55 PM
Thunder Dan is offline   Reply With Quote
Old 04-11-2013, 06:21 AM   #2642
Squily
Squily
Squily's Avatar
Oddometer: 1,223
Bit bigger than normal. Danish people are like the Germans- they do things really well...
I've added a video to Youtube:
Squily
Squily is offline   Reply With Quote
Old 04-29-2013, 03:24 AM   #2643
Thunder Dan
Oddometer: 760
Been a Bit Quiet Here...
G'day All,
The bike is more or less done, there are a few things still to sort out. Here are a few pics:
The full build / mod report is in the beasts section, click here...
And BTW it's freakin' loud...
Cheers,
Dan.
Old 04-29-2013, 03:38 AM   #2644
Squily
Squily
Squily's Avatar
Oddometer: 1,223
G'day All,
Wow!!I Love the rear tanks and the exhauses
Squily
Old 04-29-2013, 03:46 AM   #2645
robmoto
robmoto's Avatar
Oddometer: 3,848
Dan , very very very nice.
I ride alone and not a KTM in sight .
Menace Racing supported by Robmoto Industries
robmoto is offline   Reply With Quote
Old 04-29-2013, 03:46 AM   #2646
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,546
If you ever drop that thing Dan, I will be crying on the side of the road with ya.
Fogo72 is offline   Reply With Quote
Old 04-29-2013, 03:47 AM   #2647
HEKOT
HEKOT's Avatar
Oddometer: 115
G'day All,
She is beautiful!
HEKOT is offline   Reply With Quote
Old 04-29-2013, 05:38 PM   #2648
Backonthebike
Giddy up
Backonthebike's Avatar
Oddometer: 674
It just gets better and better Dan. Once again you put us mere mortals to shame. Well done mate!
(NSFW) http://timothydunn.com.au/
I have come to accept that my role in life is simply to serve as a warning to others.
Backonthebike is offline   Reply With Quote
Old 04-29-2013, 05:51 PM   #2649
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,462
I got my pipe ceramic coated. it hides the welds where the pipe steps up in size and on the bends.
surposed to half the radiating heat
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 screwed with this post 04-30-2013 at 02:27 AM
digga1111 is offline   Reply With Quote
Old 04-30-2013, 04:35 AM   #2650
Thunder Dan
Oddometer: 760
Roger that Digga,
That's not a bad idea. Any idea what it cost to get the coating?
Cheers,
Dan.
Old 04-30-2013, 04:56 AM   #2651
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,462
mine was about $150 or something, for all the pieces including the exhaust flanges.
looks more polished in real life
digga1111 screwed with this post 04-30-2013 at 05:24 AM
Old 04-30-2013, 01:46 PM   #2652
atgreg OP
Africatwinarama
atgreg's Avatar
Oddometer: 10,023
magic Dan as always !!!, hows the performance with the exhaust ??
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 05-10-2013, 11:12 PM   #2653
Thunder Dan
Oddometer: 760
G'day Greg,
Sorry for the late reply, been away at Bills Farewell.
The performance was a bit disappointing - the first run indicated a 5hp power loss . However, the bike was running a bit rich. We cleaned up the rear cylinder fuel curve. The power picked up marginally (maybe 1hp), but needed a #122 Main jet for the front carb. It arrived (ex-Japan) before the trip. I've fitted it before the trip, but never got time to re-dyno to confirm results.
I also fitted the TA650 carb's from Liz's bike. They're a little different in some of the breathers & plumbing. Still need to correct / sort that out.
The bike isn't as crisp off idle either, which is a bit annoying.
Having said all that - the engine now has approx. 80K kms on it. I did a compression test before the trip (Spec: 164 - 224 psi). The front is 160psi, and the rear is 164psi. So the engine is getting a little tired, and has done quite a few more kms since the previous dyno test (almost 48hp on the wheel).
So what does this all mean? After talking to DrJoe, we're thinking it is possible that the split back to 2 pipes is messing around with the exhaust pressure wave. Another consideration is that none of the boys racing Hawks in the US have fitted twin pipes for performance. They stick with 2 - 1 systems. Also noticed that Hordpower don't sell aftermarket (ie, Arrow) headers. Makes you wonder, eh??
So, either way - the pipes are on for now. The engine will be due for a freshen up next year. I've sourced 2 x spare heads from the UK. They came with cams (although 1 x cam has a bit of pitting on the exhaust lobe). The next question what to scope? 663cc kit? 153 cams? 28mm inlet valves & matched ports? Polish the inner radii? Then there is the option of JE pistons which I know little about - or oversize Honda pistons?
I'll talk to you and Squilly about that when the time is closer.
Maybe after the engine is done, I'll get Dennis to make up a single pipe - and fit another Remus or FMF type pipe. Something with just a bit of restriction - to help out the bottom end.
Cheers,
Dan.
Old 05-10-2013, 11:26 PM   #2654
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,217
Very nice Dan
Just a thought, if your two headers run into one and then into two again, try capping one muffler and taking it for a spin.
A vewwy good fwiend in Wome
Big Willy is offline   Reply With Quote
Old 05-10-2013, 11:27 PM   #2655
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,462
how hard would it be to fit a EFI 700 in the old girl.
Times are GMT -7.   It's 04:45 AM.
