09-14-2008, 09:14 PM
#1 | |
Runcible Spoon
BMW F800 GS- Acerbis handguard install
Pissed off by the fact that everything for this bike is on backorder, I decided to take matters into my own hands. Gateway had a set of Acerbis Rally pros laying there that had been ordered for a customer, but didn't work. I took them home, and:
![]() Drilled and tapped the end of the bar-end weight bolt to fit the M8 1.25 mounting bolt for the guards, and cut the bolts down to like 1.5" or so (I used the highly technical calibrated thumb measurement method). Here's the finished product, from the end. The inside was a pretty direct bolt-in, except that I had to bend the left guard a little for it to fit.
"Another road remains, but it provides no more. It can only take us away" |
09-15-2008, 04:18 AM
#2 | |
back in the saddle again
Oddometer: 590
Cowboy
09-15-2008, 06:55 AM
#3 |
Oddometer: 823
Handguards
Could you post a pic. of the inner handlebar mount? Is there plenty of room on the handlebar for this or is it a tight fit?
TIA, Wendell
Wendell You will never find a more wretched hive of scum and villainy....we must be cautious. |
09-15-2008, 07:26 AM
#4 | ||
Runcible Spoon
I'll snap a picture later of the inside mounts. It is pretty tight.
09-29-2008, 07:22 AM
#5 | |
Runcible Spoon
If You Do This, Shorten Your Levers!
If you do this mod, shorten your levers. Had a getoff two days ago, caused when a friend dropped the bike in a parking lot. It apparently bent the right guard in just enough to put a slight amount of pressure on the brake lever (Note, I did not get an ABS fault!). Front brake pumped itself full, and locked up on me.
09-29-2008, 05:52 PM
#6 | |
Oddometer: 201
I don't know what sort of hardware is included, but I assume there is no way to modify the guards or braces or anything to use the original bolt or otherwise avoid tapping the bar ends? The existing bolt LOOKS (from the outside) a bit bigger than M8 1.25...
Cheers, Tom '09 F800GS (Yellow) '05 F650GS (Sold) '04 K1200RS (Sold) '03 F650GS (Crashed) (formerly hyperiate) http://www.shoottheapex.com |
09-29-2008, 06:31 PM
#7 | |
Runcible Spoon
the stock bar end bolt is about a 20mm or so. The machine work would be super cheap to have a local shop do. If you were around here, I'd just do it for you...
09-30-2008, 06:27 PM
#8 | |
Oddometer: 201
Why did you cut the Acerbis bolt? Why didn't you just drill all the way through the BMW bolt? I'm going to stop by a machine shop with the hardware tomorrow and have them drill through and tap the threads. I'm having a hard time figuring how to orient the handguards around the controls. (oops, I've been playing with the left guard which you mentioned you had to bend -- let me see the right one) Anyway, if you have any additional pictures of where you placed the inner mounts and where the guards sit in relation to the control levers that would probably shorten my fiddling time. Thanks for pioneering this! I'll post pics when I'm done.
09-30-2008, 06:41 PM
#9 |
Roads are to explore
Oddometer: 357
Nice job. I fiddled with a set of Acerbis Pro Rally's for my R1200GS so good to see others doing the same on their Bmr.
Adventure feeds my soul, without it I would wilt 2011 Dalton & Dempster Solo trip http://tiny.cc/a0b69 Other adventure pics here |
09-30-2008, 07:03 PM
#10 | |
Oddometer: 201
There are three options for mounting to the bar end: 1. Drill the hole in the handguards bigger 2. Tap the BMW bolt to fit an 8mm inside it 3. Use the Acerbis mounting kit, which expands a knurled surface inside the bar I didn't like 3 much because it would munge up the threads if for some reason I ever wanted to return to stock. I like option 1, but the BMW bolt is just such a PERFECT fit for the Acerbis bolt that I appreciate the elegance of ]I)Money's solution I want to try that first.
09-30-2008, 09:00 PM
#11 | ||
Runcible Spoon
I'll snap some pictures tomorrow of the guards. Been meaning to, but got lazy about it.
09-30-2008, 09:04 PM
#12 | ||
Runcible Spoon
The problem with 1. is that the BMW bolt is so big that it will take up nearly all of the countersunk portion of the handguard. Also, the BMW bolt is also tapered, and the handguard isn't wide enough to accommodate a countersink for the head, which would leave the bolt sticking out oddly...
09-30-2008, 11:00 PM
#13 | |
Oddometer: 201
The right side was a pain. I needed to get the inner mount as far outside as I could, and mounted it a mm or so away from the brake parts. I (think) I bent the guard a bit in order to make it longer, and had to take a bit of the inner bend out with a vise. Then I trimmed a little plastic to allow for clearance of the brake switch and it finally fit pretty well. On this side the lever is fully covered by the hand guards. I didn't get the idea that this mirrored your experience, so I'm interested to see what you came up with as well.
10-03-2008, 01:15 PM
#14 | |
Runcible Spoon
More Pics
here's a couple from the top that show how the inner bracket is placed. Clearance pictures don't show the newly shortened levers...
![]() BTW, that cheap-ass wal-mart pannier bag saved me a ton of damage ![]() ![]() ![]() They're not quite in the same spot on either side, but you have to be looking hard to tell. Hope that helps.
10-04-2008, 05:50 PM
#15 |
love what you do
Oddometer: 19,441
![]() Make sure you check your lever freeplay on a regular basis, especially after any biff. Had these guards on my KTM 620, and the lever fitment was similar (until I cut the levers down). I find these guards bend without too much (IMO) provocation, and at one point, it was putting enough pressure on the brake lever to heat things up before I noticed it. I also found that if you positioned the guard to protect the levers, they were rotated down and didn't really cover your hands all that well (and vice versa).
Nate in N.E. Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar! ![]() They don't expect you to finish. That's why it's the Dakar. -- PPiA Get your sweet Pyndon DakARTwork here Pyndon '13
