Old 10-14-2008, 07:40 PM   #16
Keystone
Oddometer: 201
Finally I get around to posting to the thread...
I installed the Rally Pro's on my bike as well. They look good, they feel very solid, and I'm confident they saved me from having to buy a new clutch lever after this weekend.
The hardest part I needed to deal with was the brake hardware interfering with both the amount the inner mount could come out to the end of the bar AND the brake light switch interfering with the bar itself.
I ended up cutting some of the plastic away to allow the switch to clear and bent the bar to make it a little wider from inside to out. This enabled me to nestle the lever inside the hand guard, but still give me clearance to push the lever out and tap the guard. I'm developing the habit of tapping the guard with the lever while stopped, so I'll notice if that clearance goes away.
I also had to rotate the clutch lever down under the handguard. I don't know HOW you bent it to fit, but at first glance there is NO WAY I can get the lever inside the cup. It didn't seem to matter this weekend though as I had two falls at speed in the sand and the lever wasn't bothered at all, though I do have abrasions on the guards.
I had no problem getting the bar end bolts drilled and tapped for the 8mm acerbis bolts and it all went together really well.
Overall I'm really pleased. I wasn't sure if I'd get them at first, but when I priced out a new lever (some $80 or so I think!) it only made sense to protect them as much as possible.
More pictures of placement, clearance, etc in this album:
http://picasaweb.google.com/Hyperiat...84965150839730
These were before the bolts were tapped, so it's all just press fit together in the pictures. I didn't change the placement of the inner mounts at all in final form though.
Cheers,
Tom
'09 F800GS (Yellow)
'05 F650GS (Sold)
'04 K1200RS (Sold)
'03 F650GS (Crashed)
(formerly hyperiate)
http://www.shoottheapex.com
Keystone is offline   Reply With Quote
Old 10-14-2008, 08:08 PM   #17
jessehere
Ridin'
jessehere's Avatar
Oddometer: 775
tom ,
how did you damage your radiator?
jessehere is offline   Reply With Quote
Old 10-14-2008, 08:12 PM   #18
Keystone
Oddometer: 201
Originally Posted by jessehere
tom ,
Hi Jesse,
See this thread for that write up:
http://www.advrider.com/forums/showthread.php?t=395717
Cheers,
Tom
'09 F800GS (Yellow)
'05 F650GS (Sold)
'04 K1200RS (Sold)
Old 10-15-2008, 06:35 AM   #19
jessehere
Ridin'
jessehere's Avatar
Oddometer: 775
Old 10-15-2008, 07:46 AM   #20
]I)Money OP
D NOT I
]I)Money's Avatar
Oddometer: 3,796
comparing installs
It looks like the difference is that I positioned the inner mount further out toward the end of the bars. It did require more bending of the guards to get them to fit, but on the upside, they are positioned directly in front of the levers. As mentioned, I did go ahead and trim down my levers, as well, so I don't have to worry about the guards getting tweaked a little and interfering with the levers. Odd data point: the "break-off point" on the clutch and brake lever is not at the same distance...
Originally Posted by wxwax
Yes, but everything you've ever posted in the basement indicates that you're certifiably crazy, so you don't count.
"Another road remains, but it provides no more. It can only take us away"
]I)Money is offline   Reply With Quote
Times are GMT -7.   It's 02:48 PM.
