11-13-2008, 01:24 PM
#16 |
Oddometer: 74
Axle Bling
![]() These are Zip-Ty axle blocks & puller that I have had since 03, they fitted the 08 with no mods. They make tube changes quicker & easier as the blocks stay put & the handle makes axle removal a breeze. In the Zip-Ty kit comes a pointed piece that is fitted into the end of the axle to make pushing the axle easier. My is a little worn down from a slide down the bitumen from a green front knobby. Cheetah screwed with this post 01-13-2009 at 01:12 PM |
11-13-2008, 01:27 PM
#17 |
Oddometer: 74
The other side.
![]() Having the axle remove from the right hand side makes lining up the axle block, disc carrier & hub easier. Cheetah screwed with this post 01-13-2009 at 01:13 PM |
11-13-2008, 05:46 PM
#18 | |
ManchesterTRF.com
Oddometer: 33
Heres my bike on day one! Not so clean these days though... ![]() ![]() Yamaha ROCKS !!! www.ManchesterTRF.com |
11-17-2008, 08:25 PM
#19 |
Now sans KLX...
Oddometer: 1,879
First ride in the bush today - great conditions, nice and cool. Really love the bike. It's just more of everything than the KLX. Steers tighter, and the suspension is a real improvement for sure. And the power is really useable, easy to float the front end over tree roots and rocks just with a bit of throttle. Not as tractable as the green DRZ but what is? And I haven't had much of a go with the jetting. I suspect it's a touch lean down low but that might be more impression than fact. I'll have a play with it and see what happens.
I did find a bog to get stuck in though - usual poor line selection on my behalf. Instead of digging a bigger hole the big fella in the Souths jumper helped me drag it out and back up the inside line. ![]() ![]() Shortly after, he went over the bars of his TTR after clipping a tree and broke his collarbone so that was the end of play. "I know what I'd rather have between this busted collarbone and that lovely WR450 "
"There's nothing I can do about it now" |
01-01-2009, 02:25 PM
#20 |
Oddometer: 176
WR450 Africa rallye Build-Up
Great thread, both bike specific and rallye in general
http://www.advrider.com/forums/showthread.php?t=400288 |
01-01-2009, 02:44 PM
#21 | |
Big Bike, Slow Rider
Oddometer: 490
One of the guys does a lot of work for Yamaha and Craig Dack and I have been told he/they are now working on the oil cooler / increased oil capacity problems. BUT THAT IS ALL I KNOW. |
01-02-2009, 03:39 AM
#22 |
Oddometer: 74
I have found 1 solution that incorporates an oil cooler within a radiator. The unit is made by PWR Performance Products; I really like this concept of incorporating both into one. Simplicity at its best, no need to worry about where best to place a cooler & fittings. I first saw the kit in ADB ad section in the back which includes 2 radiators, silicon hoses, oil hose & adapter plate. There is no drilling & tapping involve for fitting this kit.
http://pwr.com.au/#view=products&s=rs |
01-11-2009, 09:39 PM
#23 |
Oddometer: 562
Hey guys!
New WR250F rider here, picked up a near-new '07 model late last year and so far I must say it is great! Things that need attention for me include: Force Radiator Guards - a must-have Alloy bash plate to replace the stock plastic version Ego Barkbusters to replace the stock version Front forks need adjustment to suit a fat bugger! I have Pivot Pegs on the way, as a special deal came up that was too good to miss. I'll be interested in seeing how these work out. I have tried them on mates bikes and thought they were quite nice. That, plus I bent a footpeg on my first ride! As an ex-DRZ400 rider I am finding the WR a lot lighter and more nimble, although it doesn't have the legs of the 400 to be sure. Most of my riding is tight single track so the 250 actually suits me better. I'm not concerned about the intervals between oil changes, mostly because I was over the top with the DRZ and used a similar interval. Here's a couple of pics from when I first picked it up: ![]() ![]()
Work to live, Live to Ride! |
01-11-2009, 09:44 PM
#24 | |
Southern Explorer
Welcome mate! Bike looks good, they sure are more nimble and light than the trailbike machines like your DRZ. Look forward to seeing some more pics. Make sure you get those bark busters on there or at least some plugs for those bar ends, don't want to hear you have taken a core sample of flesh!!
Moto Guzzi Griso 1100 Yamaha WR450F for sale!Yamaha WR250R for sale!KTM 990 Adventure ![]() Southern Explorers trail and adventure riding group contact me for details |
01-12-2009, 01:34 PM
#25 | |
Oddometer: 562
When I dug out the bits the bolts at the ends of the expanding bolts that go in the ends of the bar had no expanding nuts - you know the tapered ones. I immediately thought of some Hilti concrete bolts that I had and dug one out. The thread fit prefectly so I only had to find one more and I was right to go... and do you think I could find any??? So the first ride (pictured) I had no barkies and was most uncomfortable all day because of it! Of course when I got home and wheeled the bike into the shed what did I see? Of course, the rest of the Hilti bolts were sitting on the bench not 5 yards from where I tried to fit the barkbusters the first time! ![]() So now I'm all barkbustered up and ready to roll!
01-13-2009, 03:23 AM
#26 |
Oddometer: 263
These pics are too clear.........here's a shit one.
![]() 04 450........stock apart from bar risers & bashplate......fun bike. Anyone tried a lowering link yet ?? |
01-13-2009, 04:17 AM
#27 |
DIGITI EXTRACTUUS
Oddometer: 577
I spoke to Paul at MPE about lowering links for the WR and he recons they're no good because you can't lower the front to match and you end up riding a chopper! He can lower the suspension properly by 50mm for around $550. I haven't looked into it further yet but will need to do something as I suffer very badly from ducks disease.
Take it easy............but take it! (Woodie Guthrie) Studies show that politicians are not in office because they have your best interests at heart, they are driven by two things, money and power, (in that order). |
01-20-2009, 02:48 AM
#28 |
must......find.......fuel
Oddometer: 2,297
Yamaha "Dakartech" WR450F
12,000 euro ( about 40 million Aussie dollar ) for the kit from somewhere overseas. Sorry, thats all I know.
Some men like the fish'n, Some men like the foul'n, Some men like to hear........ to hear the cannonball a roar'n! |
01-20-2009, 04:04 AM
#29 | |
Southern Explorer
Quality! That looks sick mate
01-20-2009, 08:34 AM
#30 | |
Oddometer: 953
