Old 03-29-2009, 08:30 PM   #46
The Fireman
on the edge
The Fireman's Avatar
Oddometer: 257
Wr450 dash
Have been experimenting with a 'dash' for the Wr to incorporate the heated hand grip switch, a 12v outlet and a spot for the GPS.(gps not mounted yet)
Here is the prototype, is a bit ruff (was done at 3am {nightshift} ), also added another switch to run a thermofan or something later.
I will re-design it in a few weeks to incorporate LED blinkers in the sides, and make it 'flatter', it is great while sitting but a bit hard to see while standing, it has rivets in it ATM but will be all one piece now I have some thicker material.
After that I will start on a screen...
Cheers
MacKa...
Most motorcycle problems are caused by the nut that connects the handlebars
to the saddle
98% Of all Harleys ever sold are still on the road. The other 2% made it home.
- Anonymous
The Fireman is offline   Reply With Quote
Old 03-30-2009, 01:30 AM   #47
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,042
G`day Yamaha riders . I`ve just bought a set of 02 YZ 426 forks which I hope to fit on another bike . I`m hoping someone could tell me the standard fork oil weight , oil height & quantity . Also if you have some heavy springs you might want to part with in .50 , .51 or .52 .
Thank you .
Brute is offline   Reply With Quote
Old 03-30-2009, 03:37 AM   #48
peteandheidi
Oddometer: 395
100mls air gap and 5w oil is a pretty good starting point.
peteandheidi is offline   Reply With Quote
Old 03-30-2009, 03:58 AM   #49
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,419
On the steel framed bikes, where the oil is kept in the frame, how about adding a tank upfront protected by a bashplate of some kind, then tapping into the frame through the drain nut.
I suppose you would have to have a oil feed and return pipe. Maybe the oil cooler up top by the radiator would be a better alternative?
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 03-30-2009, 06:18 AM   #50
The Fireman
on the edge
Oddometer: 257
Check out the 90ish on XR 400/600 etc, they have a cooler that wraps around the head stem,
You might be able to copy/modify/adapt something.
Cheers
MacKa....
to the saddle
- Anonymous
Old 05-02-2009, 06:48 PM   #51
LC8TY
must......find.......fuel
LC8TY's Avatar
Oddometer: 2,297
Its time for my WR450F to have a preventitive top end rebuild. The bikes done 7000ks now with only one valve adjustment, a few chains, sprockets and tyres.
I ran the bike at Yilgarn in standard form except for the safari tank, after the event I had two riders ask me what I'd done to the motor and how fast did it go. The look on their faces was pricless when I told them it was stock standard.
I spoke to Centretune MC the other day and got some info on what Rod Faggoter ran in his WR at last years Safari. His setup was a ported head, quality valves, 06 YZF cams and a CP high comp piston. They reckon its a good way of increasing power and torque without sacrafising reliabilty.
Fortunately I brought a 06 YZ450F with a blown bottom end very cheap a couple of weeks ago. I had a look at the cams and as far as I can tell they seem to be perfect.
I do need a little help though.
Who does good head jobs? porting, pollishing, valve replacements and seating.
Anyone been down this road before? Got any addvice?
Some men like the fish'n,
Some men like the foul'n,
Some men like to hear........
to hear the cannonball a roar'n!
LC8TY is offline   Reply With Quote
Old 05-02-2009, 11:33 PM   #52
LC8TY
LC8TY's Avatar
Oddometer: 2,297
Preparing for Surgery
First thing was to give it a good clean up.
Then drain the fluids. I won't go inside the top end untill I have all of the new parts ready to go.
Old 05-02-2009, 11:44 PM   #53
LC8TY
LC8TY's Avatar
Oddometer: 2,297
Here's something to think about, comparing the WR to the YZ rear shock.
The overall length and mounts are the same but the YZ has a thicker diameter spring but with less coils. Also the shock shaft on the YZ is 2mm thicker. I'm assuming the YZ is firmer than the WR, I think I'll install the YZ rear shock and add some more preload (same as the existing setting on the WR) and see how it goes.
Old 05-03-2009, 12:58 AM   #54
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,419
7000km .. why so little?
I know of some bike's that have run 30 000km without a rebuild ..
Im also sitting on about 7500km currently... No valves just oil and plugs.
I must admit that I dont race mine so thats probably where the difference comes in.
06 950S
Yamaha YZ250WR
Old 05-03-2009, 06:54 AM   #55
abigserve
Oddometer: 108
Originally Posted by DRjoe
Can i join the club to.
I have just taken possession of 04 wr250
Its not registered yet so i haven't ridden it off road but hell it looks like its gonna be fun.
It came with a bash plate, rad braces and a case saver. next to go on will be a moto X rear fender with a cheapo rear light and mini blinkers.
Just a heads up, if you angle for the mini-blinkers it actually makes the bike unregistable...I know because I just recently had to get my 04 250f re-registered and the guy picked up on the small blinkers straight away.
abigserve is offline   Reply With Quote
Old 05-03-2009, 07:03 AM   #56
DRjoe
DRjoe's Avatar
Oddometer: 5,072
it had the original indicators on when i got it registerd.
this is what it looks like now
DRjoe is online now   Reply With Quote
Old 05-03-2009, 08:38 AM   #57
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,419
my right rear keeps melting. its in the oem location, but i need to move it ...or find shorter ones .. where can i look?
06 950S
Yamaha YZ250WR
Old 05-03-2009, 06:28 PM   #58
DRjoe
DRjoe's Avatar
Oddometer: 5,072
mine did that on the first ride, melted the center rite out of the indicator so i have the yz rear fender with mini indicators now
Old 05-23-2009, 04:34 AM   #59
LC8TY
LC8TY's Avatar
Oddometer: 2,297
I've given up on the top end rebuild for the time being, too long waiting for parts.
But I did install the YZ cams.
I marked the cam chain at the top dead centre marks before removing the old ones. I did a valve clearance check as well.
I fitted the YZ rear shock and started to put the bike back together.
I also installed a JD Jetting kit
I went for a quick test ride around the streets, the cams have increased the power output, but its not a massive difference. Feels good though.
The rear sits about 20mm higher but needs some fine tuning on the comp and rebound. Tomorrow I'll take it out for a day in the dirt and get a better feel for it.
Finished product, for now...............
Old 05-26-2009, 04:07 PM   #60
Cheetah
Cheetah's Avatar
Oddometer: 80
WR450 Enduro Adventure Project
I am about to embark on an adventurisation of my 08 WR450, making it a capable long distance off roader. I have done the outback touring on a KTM 950 Super Enduro & now want to do the interesting Great Divide exploring. I have done some riding of this type on the SE but I find it over kill for the single track riding that I prefer to do.
List of mods I plan to do;
Cush drive rear wheel
oil cooler
Safari 15.5 l tank
thermo fan
GYTR full exhaust
Increase in fuel efficiency.
In the bikes current state of standard exhaust with GYTR insert, 15t front sprocket, 42 pilot, needle on position 2 from top, 165 main I am averaging 17.7km/l. Cruising down the open road it's getting 24km/l @ 90km/h. My aim is to get longer range through efficiency rather than strapping on a 44 gallon drum.
LC8TY, I noticed that you have a GYTR exhaust on yours, how much of an improvement in performance did it have?
Did you get the JD jet because of the change in exhaust? Was there a noticable change.
Cheetah is offline   Reply With Quote
Times are GMT -7.   It's 01:56 AM.
