Old 05-26-2009, 03:49 PM   #61
LC8TY
must......find.......fuel
LC8TY's Avatar
Oddometer: 2,297
Originally Posted by Cheetah
I am about to embark on an adventurisation of my 08 WR450, making it a capable long distance off roader. I have done the outback touring on a KTM 950 Super Enduro & now want to do the interesting Great Divide exploring. I have done some riding of this type on the SE but I find it over kill for the single track riding that I prefer to do.
List of mods I plan to do;
Cush drive rear wheel
oil cooler
Safari 15.5 l tank
thermo fan
GYTR full exhaust
Increase in fuel efficiency.
In the bikes current state of standard exhaust with GYTR insert, 15t front sprocket, 42 pilot, needle on position 2 from top, 165 main I am averaging 17.7km/l. Cruising down the open road it's getting 24km/l @ 90km/h. My aim is to get longer range through efficiency rather than strapping on a 44 gallon drum.
LC8TY, I noticed that you have a GYTR exhaust on yours, how much of an improvement in performance did it have?
Did you get the JD jet because of the change in exhaust? Was there a noticable change.
G'day Cheetah
The pipe on mine is the YZ GYTR, its a bigger bore than the stock one. It increases the power output slightly but the big difference is it shifts the torque more to bottom end/mid range with stock jetting. The JD kit makes it far more tuneable as the stock needle only has on clip position and the fuel screw is blocked off. The JD comes with good instruction and a list of base settings for various bike setups and altitude.
The WR adventure project sounds good, Ash's Spoked Wheels is the guru on cush drives for the WR, PWR do a radiator with an inbuilt oil cooler, I get around 220 - 250 Kms from my 16 ltr Safari tank.
Some men like the fish'n,
Some men like the foul'n,
Some men like to hear........
to hear the cannonball a roar'n!
LC8TY is offline   Reply With Quote
Old 05-26-2009, 05:51 PM   #62
Cheetah
Cheetah's Avatar
Oddometer: 74
I have spoken with the guys at Ash's & have a RAD cush hub lined up. I have been down to PWR factory to have a look at the Stage 3 cooling kit. Very good setup but I am after a larger oil cooler to increase the oil volume in an effort to increase oil change intervals to 1000km or greater.
I have done similar work to the previous bike, WR426. I would change the oil at 1200km with no ill effect. The bike only had the titanium valves replaced with stainless & new cam chain at about 5000km. When I sold the bike late last year it had done 20000km, 2 Finke Desert races, & numerous other off road races. Still the original bore, pistion, rings, & clutch plates.
Compression was still higher than factory; goes to show when someone that knows what they are doing with valve work makes a world of difference.
The GYTR pipe sounds like the way to go as the extra pulling power down low will help in running taller gearing at lower revs.
Cheetah is offline   Reply With Quote
Old 05-27-2009, 10:48 AM   #63
stevh0
Desktop Adventurer.
stevh0's Avatar
Oddometer: 1,093
oil cooler
Safari 15.5 l tank
thermo fan
GYTR full exhaust
Id love to see this!!
Ive run my bike for 8000km as a dp with plenty of wheelies through the gears and have not had any gearbox issues?
is the cush drive really nec?
2000 Suzuk DRZ400S & M
2004 KTM Adventure 950S
stevh0 is offline   Reply With Quote
Old 05-27-2009, 10:49 AM   #64
stevh0
Desktop Adventurer.
stevh0's Avatar
Oddometer: 1,093
current oil change intervals as per Yamaha manual is 1000km ??
Old 05-27-2009, 03:25 PM   #65
Cheetah
Cheetah's Avatar
Oddometer: 74
Stevh0
I'm going the cush drive to remove the risk of trashing the gearbox from long runs on bitumen & hard pack dirt roads. I doing the prevention is better than the cure method. A lot of the Safari racers put cush drives on their bikes for this very reason.
Oil change intervals I thought were 500km?
I'll post photos of the project progress as they happen.
Old 05-27-2009, 03:56 PM   #66
LC8TY
LC8TY's Avatar
Oddometer: 2,297
My manual for the 07 says 1000km oil changes.
I do it at 500km or less.
Old 05-27-2009, 05:43 PM   #67
The Fireman
on the edge
The Fireman's Avatar
Oddometer: 257
Wr 450 pic's
Helped a mate out with his Wr450 in a comp a little while ago.
Thought I better get around to posting some pic's.
Most motorcycle problems are caused by the nut that connects the handlebars
to the saddle
98% Of all Harleys ever sold are still on the road. The other 2% made it home.
- Anonymous
The Fireman is offline   Reply With Quote
Old 05-27-2009, 08:14 PM   #68
ECKS-Man
ECKS-Man's Avatar
Oddometer: 565
Yeah, not a bad job you did too mate! Shame about the rider eh!
You do all that hard work and all the rider can do is win the race outright! Not sure I'd be happy with that if I were you!
Work to live, Live to Ride!
ECKS-Man is offline   Reply With Quote
Old 05-27-2009, 08:50 PM   #69
The Fireman
on the edge
Oddometer: 257
All I did was put fuel in it , the rest is up to the Rider!
The guy in the pic is one of my best mates and a bit of a legend, he built the bike!
Todd is a pleasure to work with and the rest of his family and extended family are really great people.
It was an honor and pleasure to help him out.
Just hope he does well at finke and then the big one!!!
to the saddle
- Anonymous
Old 05-29-2009, 03:17 AM   #70
LC8TY
LC8TY's Avatar
Oddometer: 2,297
WR 450 Rallye, aussie style
I've got all the parts, just need the time to put it all together.
Stay tuned.
Old 05-29-2009, 06:03 PM   #71
Cheetah
Cheetah's Avatar
Oddometer: 74
Just got the pipe today, even after a short ride around the block you can notice that the bike runs so much smoother & pulls nicely from low revs. Tomorrow I will do some testing at Glasshouse & some fine tuning.
Cush drive wheel & 15l Safari tank still 2-3 weeks away.
Old 05-30-2009, 02:29 PM   #72
twotyred
Practising Recedivist
twotyred's Avatar
Oddometer: 1,447
I was reading in the latest Australian Trailrider magazine the other day on their project WR450F where they experienced the (apparently) common problem of front suspension fade after a short amount of time
The guys at Teknik have an answer to this.
http://www.teknikracing.com/information/WR-Forks-Fix
You have not had enough coffee until you can thread a sewing machine...while it is going!!
More enthusiasm than ability!!
twotyred is offline   Reply With Quote
Old 05-30-2009, 10:53 PM   #73
rhino_343 OP
Southern Explorer
rhino_343's Avatar
Oddometer: 2,088
Send a message via MSN to rhino_343 Send a message via Skype™ to rhino_343
Thumper Talks list of WR performance updates... all models and pretty much all mods!
http://www.thumpertalk.com/forum/sho...d.php?t=440372
Moto Guzzi Griso 1100
Yamaha WR450F for sale!
Yamaha WR250R for sale!
KTM 990 Adventure
Southern Explorers trail and adventure riding group contact me for details
rhino_343 is offline   Reply With Quote
Old 05-31-2009, 03:05 AM   #74
LC8TY
LC8TY's Avatar
Oddometer: 2,297
I read this just before I set of for a trail ride out the back of my place and thought " I've never had probs with the front forks bottoming out."
I bottomed them out four times this morning. I think I'll install the YZ forks before next weekends 700 km trail ride in the Gregory National park.
A pic of my extended back yard.
Old 06-01-2009, 12:14 AM   #75
The Fireman
on the edge
Oddometer: 257
[/quote]
Noice view!!!
to the saddle
- Anonymous
Times are GMT -7.   It's 06:16 PM.
