Old 10-02-2008, 01:15 AM   #61
Dieselboy OP
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,175
Originally Posted by Frank Warner
Dieselboy - if that connection works then you have a problem with your AP1 system ...
That is actually one of my suspicions. Unfortunately, work has been nuts and I have been unable to pursue this at all this week.
The last thing I did was run a new ground wire to the AP1. I need to re-ground the Stebel and test a new connection to the AP1.
You have to remove 13 screws in order to remove the top cover and left side cover. While that is not an overly large number, try doing that 2 or more times in a row (BTW you have to re-insert them too). It gets old quick and consumes time in a limited evening.
Since I have the horn working (which I actually had to use on the way home last night-- car drifted onto the line next to me) I am less manic about solving the AP1 issue. I will get there.
Dieselboy
The Adventure Continues
Dieselboy is offline   Reply With Quote
Old 10-02-2008, 04:58 PM   #62
MJS
MJS's Avatar
Oddometer: 1,912
The resistor wires across the relay coil terminals (in parallel). I removed my horn so the resistor was required to imitate the electrical load of the stock horn. The ZFE doesn't know what the load is, only the current draw. The resistor is close to the stock horn (I don't remeber what the horn was when I measured it)..
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 10-05-2008, 05:34 AM   #63
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,175
A few pics:
F8GS Center Panel
F8GS AP1 under center panel
F8GS AP1 under center panel (moved to show wiring)
F8GS Seat
F8GS under seat
F8GS Starcom1 in tail section
Dieselboy
Dieselboy screwed with this post 11-21-2012 at 07:49 PM
Old 10-06-2008, 04:54 PM   #64
JRWooden
Oddometer: 4,292
DB:
I'm not trying to be a dick or anything but I'm thinking I would not "lash" the manual on top of the engine computer ... it could provide extra "insulation" in hot weather that you don't want...
Just a thought ... all free advice is worth the price paid
Jim
Old 10-06-2008, 10:05 PM   #65
sekalilagi
sekalilagi's Avatar
Oddometer: 495
Hey there Diesel
I have not much familiarity with the BMW but am quite familiar with CAN bus systems as we've developed 'nodes' for various projects at work using CAN. A couple of things come to mind.
1. The load resistor in parallel with the relay makes sense if you have disconnected the stock horn, otherwise should not make that much difference.
2. Clamping diodes on both your relays make sense but you might want to check as some automotive relays already have these diodes built-in. Normally can be seen on the 'schematic' printed on the relay.
3. The Stebel (at 18A) is probably capable of huge inductive spikes in and by itself. The longer the wiring or more circuitous (no pun) the path between the battery and horn (via relays, and fuse panels) give more opportunity for any voltage spike to be inductively coupled into nearby wiring (including the CAN data lines). We've had inductive loads cause all kinds of havoc on circuits that are not physically attached/connected.
Here're a couple of suggestions:
1. Ensure that you have 'matched' the supply and return lines that feed the load to the horn. i.e. you should be able to trace the outbound and return route with as few skips/junctions along the way. Using the chassis to ground the load 'on the way back' is a no-no when dealing with high current, inductive loads. If possible I'd isolate the ground lead for the horn (straight shot to the battery) from the ground leads used for the relay coil(s).
2. When routing the high current load lines to the horn (via the relay) try to avoid bundling it in parallel with the CAN lines while keeping the high-current leads as short as possible.
Hopefully the above should do the trick.
If not, you might consider one of two things
a) placing a clamping diode at the 'horn connector' i.e. closest to the source of the transient.
alternatively
b) Use a TVS (transient voltage suppresor) which will curb the positive swings as well. You would use a TVS in parallel with a 'plain' diode.
Here's one that should work
http://search.digikey.com/scripts/Dk...=478-2492-2-ND
That being said, if the wiring (both positive and return) between the battery and the horn are 'clean' and balanced, you should not have to resort to a TVS.
CAN is pretty tolerant of all sorts of noise but I've witnessed a 30A inductive load generate 400V spikes and even inductively coupled to the datalines, this can wreak some havoc.
Here's a quickie (!) test, if you feed the horn relay directly with two leads from the battery (and bypass your fuse panel and CAN powered relay) and it helps, it most likely points to noise coming from the wiring and the above suggestions should help.
The above assumes that firing the horn generates some sort of voltage spike/transient capable of restting the system. It might be worthwhile to check the state of charge of the battery or terminal connections as a weak battery (from loads of testing) can also amplify the symptoms or trigger some other low-voltage related circuitry.
Hope this helps
Ken
Change is the law of life. And those who look only to the past or present are certain to miss the future. - John F Kennedy
sekalilagi screwed with this post 10-06-2008 at 10:17 PM
sekalilagi is offline   Reply With Quote
Old 10-07-2008, 04:49 AM   #66
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,175
Originally Posted by sekalilagi
Hey there Diesel
alternatively
Hope this helps
Ken
Ken, wow, thanks for the input. Not only pertinent-- even bettter, it's lucid.
You are the second person to mention inductive loads crossing over at bundled wiring. If you look at my pics with the AP1 moved, you will note a white block between the battery and airbox. That box is a multi-prong connector through which I am attempting to wire all my accessories.
My plan was to have a quick disconnect to allow ease of maintenance. I am beginning to suspect that I need a new plan.
I still need to get to that oscilliscope and see what the electron beasties are doing.
It's Tuesday...no way to invest time now...maybe I can get this thing moving again this weekend.
Stay tuned.
Dieselboy
Old 10-07-2008, 07:03 AM   #67
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Hey there Diesel
--snip--
Hope this helps
Ken
I love this place.
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 10-11-2008, 04:53 PM   #68
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,175
Fixed
AP1 had corroded on the bottom of the circuit board. This tiny detail was repaired by resoldering the board (something for which I definitely needed help-- and I happily recieved.) That and a bit of wiring verification and now the horn, happily, operates through the AP1. I don't fully understand how it was working at all, but it is moot.
The relays are operating as expected.
The horn is operating as expected.
So my saga is now over, except I will be buying a new AP1 (or 2).
Of interest to all of you, the oscilliscope confirmed that there is no spike coming back into the system from the horn operation.
On to the next project....driving lights...
Dieselboy
Old 10-11-2008, 05:02 PM   #69
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,175
Originally Posted by Boston12GS
Are you sure the AP-1 relay isn't bad...
Boston12GS, you win.
When you reach the end and look back, the path is so clear....
Dieselboy
Old 10-11-2008, 05:04 PM   #70
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,175
Originally Posted by JRWooden
DB:
Jim
Jimbo, I've decided to take your observation to heart and have moved the manual ontop of the fuel pump. I'm tired of eletrical issues for now and certainly don't intend to create any more.
Dieselboy
Old 10-12-2008, 11:10 AM   #71
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,175
So it wasn't actually the relay...as I re-read this....so credit is misplaced. Nonetheless, much like Columbus, I've given you credit so the holiday will remain in place...
Dieselboy
Old 10-12-2008, 05:45 PM   #72
JRWooden
Oddometer: 4,292
Talking
Given the price of that little shiny box ... I think that's good plan!
Jim
Times are GMT -7.   It's 04:13 PM.
