Old 12-26-2008, 06:51 PM   #136
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,329
I'll bet
yeah, I can imagine the sawzall wants to buck.
I'll use the finest tooth blade I can muster, probably protecting the tank with 1/4 inch rubber sheet... .will mount the tank on a spare frame to get a grip as well.
thanks for the tips
Renner is offline   Reply With Quote
Old 12-27-2008, 10:47 AM   #137
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
thanks for the tips
I'd recommend using a die grinder with a 2" cutoff wheel (maybe even a dremel with a bunch of little cutoff discs) for this task. It'll result in a much cleaner cut. This is just a little too delicate of a task for a sawzall in my opinion. Cutting R100GS fenders, however, that's another story.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-27-2008, 06:34 PM   #138
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,508
y'all need to go back and read my post - which in turn references another more detailed post. the sawzall works fine for it's intended purpose: you use it to make three vertical cuts. the circular "collar" cut is made with dremel cut-off disks (resulting in a VERY clean edge if done carefully). The vertical cuts merely divide the "collar" into three pieces so that they can be extracted.
The real trick is to leave a little bit of material when doing the horizontal cuts, so the piece doesn't fall in the tank. You can then bend it up and out with hemostats etc.
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 12-27-2008, 08:58 PM   #139
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,329
yep
the annular cut would be difficult with the sawzall (also unattractive),
and the flapper-cup could be challenging to divide using the dremmel with abrasive cut-off wheels, but near impossible to remove without dividing.
I think we're all mostly in agreement on the execution, and I'm feeling a bit guilty over the thread hijack.
Hopefully I'll "git 'er done" during the week and will probably post the gory details over on the 'ST mod' thread Kev started.
It's one of those purple tanks
Old 12-28-2008, 03:50 PM   #140
lockyv7
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,067
Whats the difference
Can someone tell me whats the difference between the R80ST rear sub frame and the G/S sub frame. And for the next question, will any of the early round rocker covers fit the 84 motor with the square covers. Locky.
lockyv7 is online now   Reply With Quote
Old 12-29-2008, 09:19 AM   #141
England-Kev OP
Oddometer: 3,739
As far as I know (waits to be told different) there is no difference between the rear subframes of the ST and G/S, so you can use the G/S single seat, rack etc on the ST. and if you look at my ST on the 1st page of this thread, you will see I have fitted the early style covers to my bike.
England-Kev is offline   Reply With Quote
Old 12-29-2008, 09:30 AM   #142
Airhead Wrangler
Adios Mexico
Oddometer: 6,606
Yes, these subframes share the same part number. Also, I stumbled across a photo of an otherwise stock looking R80ST wearing a G/S solo seat and rack.
Old 12-29-2008, 09:42 AM   #143
England-Kev OP
Oddometer: 3,739
Nice tyres, anybody recognise them?
Old 12-29-2008, 10:27 AM   #144
Airhead Wrangler
Adios Mexico
Oddometer: 6,606
Rear is a Bridgestone trailwing TW42, front is a TW101.
Front:
Rear:
Old 12-29-2008, 10:46 AM   #145
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,722
My best guess is Pirelli MT60
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 12-29-2008, 11:18 AM   #146
Airhead Wrangler
Adios Mexico
Oddometer: 6,606
I forgot to mention: That's wasn't a guess. The tires SAY bridgestone on them.
Old 12-29-2008, 11:30 AM   #147
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,722
I should have guessed much better, my wife has those on her F650GS .
R1150GS
R80GS Basic
Old 12-29-2008, 12:10 PM   #148
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,508
Since no one else has said it yet, I'll go ahead and add:
Noice bike!!
Do we know who owns it?
Twain
Old 12-29-2008, 12:52 PM   #149
Airhead Wrangler
Adios Mexico
Oddometer: 6,606
Noice bike!!
No idea who owns it, but you can check out the rest of the photos here:
http://www.smugmug.com/gallery/20929...07961338_oBHvg
By backtracking out to his front page, you could figure out who it is or send him an email.
Old 12-30-2008, 07:01 AM   #150
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,508
Cool... thanks.
Somehow the ST looks *right* with the solo setup.
Twain
Times are GMT -7.   It's 05:23 AM.
