Old 10-02-2008, 10:22 AM   #1
sailwa66 OP
Captain Cheap A**
sailwa66's Avatar
Oddometer: 206
Project: Strada Avventurosa
... which is Italian for "Adventure Road".
Ducati's Multistrada is a bike I hate to love. For all its quirks, "character", and polarizing styling, it just flat works for me. It's the first bike I truly love to ride anywhere for no reason at all, and few could argue that there's a more multi-talented (pun intended) road bike out there.
But there's more potential locked inside that ugly little Italian bike... much more.
I was raised on trail riding and enduros, so the rider-forward riding position of the Multi just feels "right". Shortly after I bought it in the spring of 2006, I roosted it down a dirt road or three near my house, and the bike seemed to take to it like a duck to... well, dirt. Hmmmm....
Ducati insists that the Multistrada is strictly a road bike, and a quick trip through the specs or a shred down a twisty road bears this out: 17" wheels, tubeless tires, road-oriented steering geometry, etc.
But take a few steps backward and look at a few of the other specs from an adventure perspective: (relatively) light weight, 5.5 gallon tank, extra-narrow bulletproof air-cooled L-twin, 6+" of suspension travel, well-protected and high air intakes, hi-mount undertail exhaust, quick-change real wheel, etc.
Definite potential there, but some serious tweaking is going to be needed:
1. There is no protection for the sump, oil filter, or starter motor
2. There is no crash protection for the wide fuel tank (which is plastic, fortunately), side-mounted battery, or the glove box
3. The forks have WAY too much compression damping, whereas the remote-preload-adjustable shock is surprisingly good.
4. The front fender is too tight to the front tire
5. The factory saddlebags won't even survive a garage tipover
6. There is no way to bungee anything to the back of the bike
7. The headlight, while good, doesn't throw a wide enough pattern (and is over $500 to replace!)
8. The upper fairing subframe, which holds the instruments/windshield, is prone to breaking in a crash, as it rotates with the bars
9. There is no aftermarket for the Multistrada, unless carbon fiber key guards is your thing.
So... project "Strada Avventurosa" was born.
The intent is not to create the next Dakar winner, just broaden the bike's already wide capabilities by adding dirt road and two-track to its repertoire'. I just happen to be an Industrial Engineer for a medium-sized custom fabrication company, so that helps... a bit ;')
Here's what I started with, a 2004 1000DS Multistrada:
First order of business is to fabricate a sump guard. One of the things we do at the shop is rapid prototyping on a Flow Waterjet & CNC press brake, but it still took quite a few samples to get the sump guard to fit right. Here's the finished part in .080" 304 stainless steel:
Next was to fab some crash bars that don't look like a$$, and are strong enough to take a good throw down. This is particularly difficult on the Multi, as you need to protect plastic panels that are either removable or hinged for access to the battery, fuse block, and glove compartment. Plus, there is precious little room, and no convenient mounting point(s) for the bars.
This part of the project took more time than anything else. What I wound up with are bars made from 1.063" OD structural steel tube, which is pinned at one end to a rubber-isolated mounting plate behind the steering head (specifically engineered to prevent frame damage), and pivots on a special alloy steel "axle" which replaced the forward engine mounting bolt:
But the system works, and a week after installation, was (unintentionally) crash tested in a 40mph lowside on asphalt:
Next item up is hand guards. My experience is that those with aluminum spines can bend the bars in a crash, at least when you're bouncing off trees in the woods. While I won't be doing the same thing on the Multi, the sheer weight of the bike sure is going to add to the impact force that the hand guards are going to take, so it's kinda the same thing. So a set of Acerbis Rally guards were bolted up to a Renthal medium-rise "Street" bar. No problems here, and they also survived the crash with no damage to themselves, or the bars:
To get my bling on, I ordered a set of PIAA 520 ATP lights... that was easy. The hard part was where to mount them? Any location I tried, either meant that the lights would be too low, partially obscured, or subject to crash damage. I've never really liked the "grille" on the front of the bike, so I popped it off, made a bracket and strut, and viola! The lights are aimed 10 degrees off center on purpose, and are astoundingly bright:
Next was unbolting and chucking the front fender; I substituted an Acerbis Supermoto fender, since it's in proportion with the 17" front wheel, and its chiseled lines match the bike quite well. I fabbed a bracket from 304 stainless, and bolted it to some existing holes in the lower triple:
Then, to protect the (now) exposed fork tubes, I made from fork guards from the same 304 stainless, and I'll probably get these powdercoated black:
I wanted a small, unobtrusive rear rack that I could bungee my raingear bag to, which incorporated my Cateye taillight & LED turnsignals. Off came the rear plastic, which is crash-damage-prone anyway, exposing the rear of the trademark Ducati framework. The Leo Vince Evolution cans look great fully exposed, and the rear of the bike now looks super-narrow... awesome, as I'm not into the whole big booty thing... not that there's anything wrong with that... :'O
I designed a small rack that is made from .125" & .250" 5052 aluminum, Tig welded it together, and had it powdercoated to match the upper nose fairing gray color. (Any similarity to 'Transformers' or 'Decepticon' is purely unintentional. Really.)
Luggage was pretty straightforward; the factory bags are beyond flimsy, and aluminum boxes are clunky and damage way too easily. I decided to use Pelican cases, but of course, I'd have to make my own bracketry.
With a catch:
I *hate* the way bag brackets look without bags, especially on Italian art, so I designed brackets that permanently attach to the Pelican cases, and quick-disconnect from the bike. The only thing left on the bike are 4 stainless pins; everything else folds and locks to the bags. And since they're made from 250" alumninum, they add very little weight. And once the bags are mounted/locked onto the bike, they will take a beating. The system works so trick, that I have applied for a patent for it:
In addition, the underseat exhaust and single-sided-swingarm of the bike mean that even generous-sized cases (Pelican 1500, in my "case") don't make the bike wider than a city bus:
To fix the overly slow compression circuits in the forks, I drained the oil and refilled with 5w. While it made a little difference, I need to modify the shims to really get it right. At least it's just about right for rough (paved) roads now!
Sundry bits:
- Ducati Hypermotard pegs are a hybrid design; a dirt-grip-style base which has a removable rubber insert.
- Dunlop D616 tires are about as aggressive as you can get on 3.5x17/5.5x17 rim sizes. I've had really good luck with them, but as always, YMMV
- Magellan 400 Explorist GPS: Compact, waterproof, and can be operated without obscuring the screen
- Third eye barend mirrors. The stockers are miserable. These are $12 each and actually allow you to see things behind you... What a concept?
- Breakaway shift & brake levers. I haven't gotten them done yet, but the stock cast aluminum brake lever survived the crash surprisingly well!
- Shark fin & passenger peg guards in a "trellis" motif in 6061 aluminum
- Thick 3M adhesive headlight protector
- Marsee Rocket Pocket tankbag
- Hoosier Hooligans crank end cover: my only sparkley bit ;'P
Disclaimer: I'm sure there are folks who think I'm an idiot for doing this to a Ducati, that's not what they're for, there are "better" bikes for adventure riding, blah, blah, blah. Whatever... I don't care... talk to the hand.
As it stands, the bike works great for me, and what I intend to use it for. It's unique, and that counts for something with me.
I like it.
Enjoy!!!
"Why should I grow up? I don't like grown-ups."
Ducati Multistrada Adventure Gear: www.strada-avventurosa.com
sailwa66 is offline   Reply With Quote
Old 10-02-2008, 10:30 AM   #2
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 16,077
Nice!
So now that the prototyping is done, when are the parts going to be available?
Rocker59 (aka guzzimike), Aux Arcs
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 10-02-2008, 10:30 AM   #3
RaY YreKa
Palanquins RTW
RaY YreKa's Avatar
Oddometer: 16,325
I'm not a MS fan - but I like yours!!
Top job mate
IBA #40578
shine on, you crazy emo diamond
RaY YreKa is offline   Reply With Quote
Old 10-02-2008, 10:35 AM   #4
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 800
I've been using the Magellan Explorist 400 for my bar-mounted setup, but the damn thing blinks off after only two minutes. Have you had that problem?
baldwithglasses is offline   Reply With Quote
Old 10-02-2008, 10:57 AM   #5
sailwa66 OP
Captain Cheap A**
sailwa66's Avatar
Oddometer: 206
Not at all... Is the battery toast?
The only problem I've had was buying a USB cable off sleazebay that didn't work.
Old 10-02-2008, 10:58 AM   #6
sailwa66 OP
Captain Cheap A**
sailwa66's Avatar
Oddometer: 206
Originally Posted by rocker59
Nice!
PM me, so I don't rub Arch's rhubarb
Old 10-02-2008, 11:04 AM   #7
Ze Red Baron
Adventure seeker
Ze Red Baron's Avatar
Oddometer: 437
That is totally bada$$ cool. I've never liked the front-end cosmetics of the MS, but you've created a totally different machine.
You should offer to do customs for your local dealer.
1974 R75/6
2002 Stumpjumper S-Works M5
2009 Kestrel Evoke SL
www.ars-natura.com
Ze Red Baron is offline   Reply With Quote
Old 10-02-2008, 11:44 AM   #8
tslewisz
tslewisz's Avatar
Oddometer: 2,382
That's a Multi I'd buy. Fantastic work.
tslewisz is online now   Reply With Quote
Old 10-02-2008, 12:10 PM   #9
bacon
KZ5TLP
bacon's Avatar
Oddometer: 615
I have never liked an MS until NOW
Great job and fantastic workmanship.
"Be still, and know that I am God"
For all that motorcycling is, one of it's greatest gifts is the ability to take us to places where that quote is the first things that came to my mind.
bacon is offline   Reply With Quote
Old 10-02-2008, 12:31 PM   #10
Gustavo
Motociclista Errante
Gustavo's Avatar
Oddometer: 2,292
I like it too. Very, very nice work.
You really should try your hand at making some special accessories for MS or other bikes. I think you could find quite a few customers willing to pay for some items of this type of design and quality.
Gustavo
Gustavo is offline   Reply With Quote
Old 10-02-2008, 12:46 PM   #11
TTRider
Oddometer: 56
Very nice !!! It reminds me of the Uly. The shape is the same. Yours is very well designed and unique. The sumpguard is a masterpiece of art. Todays arstists work at a flowjet station. Everything you did to this bike makes me smile - i ilke it very much ! Keep up the good work and post some more pictures.
TTRider is offline   Reply With Quote
Old 10-02-2008, 01:21 PM   #12
andyrock
03' BMW R1150GSA
andyrock's Avatar
Oddometer: 93
Great job mate.
I HATE signature thingy's ........
andyrock is offline   Reply With Quote
Old 10-02-2008, 01:44 PM   #13
Kidder
Poser
Kidder's Avatar
Oddometer: 529
That is friggin' cool. I'll bet that skid plate would be of great interest to a lot of Multi owners along with the crash bars.
Very well done.
15 Kawasaki Versys 1000 LT
Kidder is online now   Reply With Quote
Old 10-02-2008, 02:43 PM   #14
wizz
Oddometer: 2,658
that is why i havent bought the bimmer. i was waiting for someone to do that with the ms. much easier on the eyes. two questions:
do you think the ohlins on the s would have the same problems with the dampening?
am i missing something or are there no turn signals on the front?
wizz is offline   Reply With Quote
Old 10-02-2008, 03:11 PM   #15
fatalerror
skrik vir niks
fatalerror's Avatar
Location: South West Florida, USA [formerly, South Africa]
Oddometer: 909
Nice! I am just waiting to see you mount a pair of TKC 80's on there
fatalerror is offline   Reply With Quote
Times are GMT -7.   It's 05:23 PM.
