Old 10-03-2008, 05:47 PM   #16
jigdog
jigdog's Avatar
Oddometer: 813
Originally Posted by WarLlama
Your gauges wouldn't die because of the side stand being bounced down to hit the kill switch, neither would a too low engine rpm stall cause the gauges to die. This sounds more like a faulty electrical connection, like a main battery terminal connection.
A common problem on the orgional F650 single. But not always the cause of the stalling. Some people also found chafed wires where the wire bundle heads to the ignition switch. Since mine would stall and then start and run perfectly with the key turned to off and then on, I now suspect the ignition switch too.
jigdog is offline   Reply With Quote
Old 10-04-2008, 06:16 AM   #17
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Is there a manual idle adjustment on this bike, or is it solely controlled by the computer?
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 10-04-2008, 12:12 PM   #18
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 47,785
Software update should have been performed before delivery of the bike.
Uncle Pollo is offline   Reply With Quote
Old 10-04-2008, 04:56 PM   #19
5thTry OP
5thTry's Avatar
Oddometer: 44
I think I can eleminate the sidestand kill switch because:
1. I tested it and it has to go down 25-30% before the engine dies, and I wasn't bouncing enough to do that.
2. WarLlama is right that the instruments don't die when sidestand kills the engine.
Also, the more I think about it the more I'm convinced I didn't kill it myself by poor throttle/clutch work. And with a compression kill the instruments would still be working.
So that leaves and electrical or software problem. A possible hint might be that after the engine kill I do remember the instruments were down except the clock and the milage indicatiors. And during the testing I noticed that when I turn the key off everything goes off right away except the clock and milage indicators stay on for a couple of seconds longer.
What do you think? Might this indicate a problem with the ignition switch as suggested earlier?
Thanks for the input!
5thTry is offline   Reply With Quote
Old 10-04-2008, 05:31 PM   #20
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Could be. Did you verify that the battery terminals were tight?
Nate in N.E.
Old 10-04-2008, 08:53 PM   #21
jigdog
jigdog's Avatar
Oddometer: 813
The "software upgrade" is just a red herring BMW applies to any problem they cant solve. Also they will stare you down and tell you its all your fault ie you dont know how to ride a motorcycle.
Old 10-05-2008, 10:20 PM   #22
One Eye Mike
One Eye Mike's Avatar
Oddometer: 658
Not the sidestand.
Mine has done the ame thing to me at least 5 times in the 750 miles i have on it. Twice was on the asphalt at highway speed. Kinda unnerving. Starts right back up again. NOT COOL.
One Eye Mike is offline   Reply With Quote
Times are GMT -7.   It's 08:09 AM.
