Old 02-07-2009, 01:42 PM   #6376
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,502
Grips and mitts
Thanks guys...I'll go with the grips and mitts...You know, this caribbean guy is not used to that kind of cold weather.
I'll see which of the propposed solution I can find.
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 02-07-2009, 03:44 PM   #6377
azabeemerboy
azabeemerboy's Avatar
Oddometer: 1,580
I prefer heated gloves. I have had both for years and IMHO the heated gloves do a much better job than grips.
Barry
azabeemerboy is offline   Reply With Quote
Old 02-07-2009, 04:52 PM   #6378
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,818
Originally Posted by NorCalDave
I've heard of a much easier way to prevent thermal loss through the clutch side grip heater. All you have to do is install a piece of over-sized heat shrink tubing over the handlebar end, then install the grip heater.
I use heat shrink that has epoxy built into it. It's thicker than standard heat shrink and glues itself to the bars. I use 3M Weatherstrip Adhesive to glue the grips on. I like Spider grips and Pro Taper pillow grips.
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is online now   Reply With Quote
Old 02-07-2009, 05:13 PM   #6379
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,818
Is anyone else having trouble logging on to Transalp.org? I put my user name and password in and it doesn't work. It doesn't say "incorrect user name or password" it just doesn't log me in.
Can someone send a PM to Russ for me to see if he can check the problem. My screen name over there is Jeff@TireBalls
thanks!
Old 02-07-2009, 05:17 PM   #6380
azabeemerboy
Oddometer: 1,580
Jeff,
I was just over there and got in ok.
I will Pm Russ for you
Barry
Old 02-07-2009, 05:52 PM   #6381
Menasco Pirate
Menasco Pirate's Avatar
Oddometer: 349
I just tried and no luck, Tried a new name and got "already taken" typed in garbage and got the same notice.
Steve
XLV750, RTL250S, 1989 XL600V, 1990 XL600V Transalps Red and Moonstone, 1992 XL600V Green, 1993 CRM250R, 1994 XRV750 Africa Twin
2009 FE390 tagged, 2011 FE450 tagged, 2011 FE570S super motard, 2011 FE570S
Menasco Pirate is offline   Reply With Quote
Old 02-07-2009, 06:16 PM   #6382
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,818
Originally Posted by azabeemerboy
Jeff,
Thanks!!!
Old 02-07-2009, 07:30 PM   #6383
Menasco Pirate
Oddometer: 349
Originally Posted by Jeff@TheQuadShop
Thanks!!!
I got in finally
Steve
Old 02-07-2009, 08:00 PM   #6384
Jeff@TheQuadShop
TAT survivor
Oddometer: 4,818
I still can't.
Old 02-08-2009, 01:27 PM   #6385
debaisley
debaisley's Avatar
Oddometer: 1,424
Nice warm day today , so i used the opportunity to work in my unheated garage. I got the time to install my wingrack. My arrow pipe was a little bit wide and the support bar makes contact with it.
From ta
anybody think this will be a problem , I really dont think it will be too hot.
I also fixed the faring vibration caused by the crashbars , just snipped the corner off where the faring makes contact with the bars.
From ta
And in case anybody wants to do a fork swap with the XR250 forks , the XR600 Fork brace from RSW racing fits like a glove
From ta
debaisley is offline   Reply With Quote
Old 02-08-2009, 01:58 PM   #6386
Santa
Focused on the Future
Santa's Avatar
Oddometer: 1,402
I'd add a couple of washers and space the rack out a couple of mm's
The contact will likely wear a hole in the muffler eventually if you take no action.
Santa is offline   Reply With Quote
Old 02-08-2009, 02:54 PM   #6387
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,986
Thanks,
That is a very valuable bit of information and...unless I'm mistaken....was an "unknown" until now.
Great Work
Ladder106 is offline   Reply With Quote
Old 02-08-2009, 09:23 PM   #6388
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,553
If any of you other TA nutz are interested, I'm just finishing up my ride report from my 4100 mile, multi-state ride from last summer. I took a little over 300 pics and even though I'm just a point n shoot kinda photog, had many that came out real nice. Will be finishing with a rundown on how the TA did and other gear I used on the trip but as TA owners, you all pretty much know the answer to the 1st part.
A Transalp's Travels - 4100 thru Five States
Help Stop McNugget Rage
WeeBee screwed with this post 02-09-2009 at 03:45 AM
WeeBee is offline   Reply With Quote
Old 02-08-2009, 11:04 PM   #6389
Menasco Pirate
Oddometer: 349
If any of you TA nutz are interested, I'm just finishing up my ride report from my 4100 mile, multi-state ride from last summer. I took a little over 300 pics and even though I'm just a point n shoot kinda photog, had many that came out real nice. Will be finishing with a rundown on how the TA did and other gear I used on the trip but as TA owners, you all pretty much know the answer to the 1st part.
You bet we're interested. I was about to go off to bed but checked in to see if anybody had posted anything, now I'm going to be up till dawn thinking about my next trip! Good luck on the job hunt. PM me if you're ever in the Lancaster, CA area.
For me it's Alaska June 12 - July 6th, via Nevada, Wyoming, Montana into Canada and return through Washington, Oregon and California PCH and 101
Thanks Dave
Steve
Menasco Pirate screwed with this post 02-09-2009 at 12:03 PM
Old 02-09-2009, 05:28 AM   #6390
debaisley
debaisley's Avatar
Oddometer: 1,424
good to know , the only concern I had was that maybe the support would get hot , and possibly melt the rack.
Times are GMT -7.   It's 06:16 AM.
