Old 07-29-2009, 11:03 PM   #7576
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,583
To Idaho and Beyond...
Well, I'm off tomorrow on another 4000 mile+ ride up thru the Pacific Northwest. Highlight will be touring Glacier National Park, then into Canada and up to Banff and Jasper N.P.'s and soaking in the many Hot Springs to be found - that's if my Passport gets processed and arrives at the Post Office in Kalispell, MT by August 15th .
No laptop so I won't be doing a live RR but look for one down the road when I return - if I survive the Grizzly's and all the Kamikaze Deer up north .
Here are links to my planned routes more or less on Google Maps - on the 2nd leg, Point "M" on the map is my starting point and I'll also be stopping there on the loop back down so it doesn't show Point "A" for some reason
1st leg of my planned route - California to Idaho
2nd leg of my route - Idaho to Canada? and back Home
Help Stop McNugget Rage
WeeBee screwed with this post 07-29-2009 at 11:14 PM
WeeBee is offline   Reply With Quote
Old 07-30-2009, 02:08 AM   #7577
ravelv
from Baltic side of river
Oddometer: 444
When starter works, on battery woltage usually drops to around 8 volts. When starter motor jams and don't turn, voltage can drop really low and wires to starter motor starts to heat... If you just turn ignition key and voltage drops on battery terminals to zero, probably battery is dead... Just use some other power source like car battery for test.
If you short relay properly, there should not be any clicking sound as you bypass relay. Otherwise seems that you just "duplicated" starter botton. And clicking sound means that battery does not have enough power for relay to work.
Originally Posted by selah
Thanks Ladder.
Well, after jumping between the terminals with the screw driver I get some clicking from the relay but no action form the starter. Also from the starter button on the bars. What is the lowest voltage that the battery will turn the starter? - Just to make sure that it is not the battery before messing with the starter motor. I have it on the charger now, though I would have thought the 100 mile ride would have topped off the battery.
ravelv screwed with this post 07-30-2009 at 02:14 AM
ravelv is offline   Reply With Quote
Old 07-30-2009, 04:47 AM   #7578
showkey
Oddometer: 1,997
Hoping someone might be able to help out with this.
Situation:
After stopping for coffee 100 miles into a 4 day tour I turn the key and get no response from the starter. No lights not any thing at all. I check connections, fuses, and battery. Multitester shows battery at 12.6 volts with the key off. With the key on it goes to zero. Again no blown fuses. Spend another couple of hours going over all electical connections. Put everything back together and push start the bike. All electrics functional, though not the starter. Start the 100 mile ride back home. Stop the bike on the pass and try the electric starter again. No luck. Push start it again and finish the ride home.
The instructions in the Haynes manual shows a different starter relay than what is on my 88 bike. So not quite sure how to proceed. I am confused why the battery shows a charge with the key off and goes to zero whith the key on - especially with no blow fuses.
Any ideas? Thanks
All the good ideas have been tossed forward, second suggestion for the future is toss the Haynes manual and get the HONDA published book
showkey is offline   Reply With Quote
Old 07-30-2009, 09:40 AM   #7579
gothamAlp
happy to be here
gothamAlp's Avatar
Oddometer: 817
bon voyage, norcal -- looking forward to hearing about your trip
gothamAlp is offline   Reply With Quote
Old 07-30-2009, 09:51 AM   #7580
gothamAlp
happy to be here
gothamAlp's Avatar
Oddometer: 817
and thanks for the paint job linky
Old 07-30-2009, 10:02 AM   #7581
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,597
Hey!!! Have fun!!
Ride safe...
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 07-31-2009, 06:23 AM   #7582
icekube1
Middle aged git
icekube1's Avatar
Oddometer: 1,866
So...are you going to do the same thing?
It does look good doesn't it....once you drag your eyes away from those lights
Cheers
Mike
Why stand when you can sit down..
Why sit when you can lie down..
icekube1 is offline   Reply With Quote
Old 07-31-2009, 12:32 PM   #7583
locorider
locorider's Avatar
Oddometer: 2,597
Paint...
Has anyone tried Colorrite spary cans on your bikes? They have a nice setup at their webpage, but want to know if any had any experience with their products.
Carlos locorider
Old 07-31-2009, 01:04 PM   #7584
mas335
xendurist
Oddometer: 2,015
Cry
Without going into a long explaination I did not have very good luck with their spray color for the NH193P. Not even close in my opinion. After taking them up on their custom color matching option ($$) I was still less than impressed. It simply did not match, even sent them a side panel portion to go by. I think the Pearl White is just impossible to match.
Having said that the R134 in the spray can was a perfect match. They do not offer the '90 Moonstone color in cans. No non USA colors available.
Transalps
mas335 is offline   Reply With Quote
Old 08-02-2009, 01:37 PM   #7585
Thunder Dan
Thunder Dan's Avatar
Oddometer: 793
Boano Rally Fairing?
Hey Jim Rowley (or anyone else with one?),
Have you test fitted your Boano fairing? I'm just wondering - how accessible is the radiator cap with the new fairing in place? If it's not easily reached, would it be quicker to remove the fuel tank to access the cap?
If you don't know off hand, could you have a look when you next fit it up? It's not a burning issue - just curious.
Cheers,
Dan.
Thunder Dan is offline   Reply With Quote
Old 08-02-2009, 01:55 PM   #7586
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Dan,
I'm right in the middle of it right now. Pics to follow soon.
Jim.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 08-03-2009, 04:57 AM   #7587
Thunder Dan
Oddometer: 793
Originally Posted by icekube1
Hi Dan
Was only kidding really, BUT if you do decide to do something with the Boano fairing next year then let me know. I might be able to go for one as well and we can split the freight.
PM sent.
Cheers,
Dan.
Old 08-03-2009, 02:24 PM   #7588
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,913
Originally Posted by Jim Rowley
Dan,
Jim.
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 08-03-2009, 04:53 PM   #7589
mas335
xendurist
Oddometer: 2,015
Anyone here live in the Los Altos, Ca. area?
Transalps
Old 08-04-2009, 06:40 PM   #7590
Menasco Pirate
Menasco Pirate's Avatar
Oddometer: 349
Sorry, Socal, Just North of LA
Steve
XLV750, RTL250S, 1989 XL600V, 1990 XL600V Transalps Red and Moonstone, 1992 XL600V Green, 1993 CRM250R, 1994 XRV750 Africa Twin
2009 FE390 tagged, 2011 FE450 tagged, 2011 FE570S super motard, 2011 FE570S
Menasco Pirate is offline   Reply With Quote
Times are GMT -7.   It's 04:27 PM.
