Old 02-10-2011, 06:46 AM   #10681
mas335
xendurist
Oddometer: 2,003
You guys are smart, just spoke with the PO and that is exactly where they came from. He thinks he still has the BMW cases.
I want to sell this rack system but I needed to know just want it was first. I doubt to many K bike owners would be looking for these arms.
I think he made decent adapter mounts to make it work on the TA, very sturdy but not purdy.
Transalps
mas335 is online now   Reply With Quote
Old 02-10-2011, 08:25 AM   #10682
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,046
Mark,
I've always liked the Krauser stuff.
I may be interested in buying it. Possible to take a few photos of the bags on the bike so I can see how it fits. I'm kinda particular about bags that stick out too far.
The mounts can be refabricated in aluminium or some such.
Ladder106 is offline   Reply With Quote
Old 02-10-2011, 08:25 AM   #10683
cnf
m00k
cnf's Avatar
Oddometer: 94
Thumbs down Acerbis Rally Pro Handguards
I just finished installing the Acerbis Rally Pro Handguards on my '93 TransAlp, and I must say I am not impressed.
I had to cut off the ball on the front brake and clutch levers etc just to make it fit, and once it was installed I noticed they hit the windscreen when turning the wheel.
All in all, I think I should have picked different handguards
cnf is offline   Reply With Quote
Old 02-10-2011, 04:03 PM   #10684
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,563
It wil happen with the Cycras too!
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 02-10-2011, 04:07 PM   #10685
cnf
m00k
cnf's Avatar
Oddometer: 94
How did you fix it? Right now I find it difficult to engage the steer lock.
Old 02-11-2011, 04:11 AM   #10686
shimazaki
shimazaki's Avatar
Oddometer: 60
I have one TA 93 too, I have installed these one´s from Polisport without any problem
shimazaki is offline   Reply With Quote
Old 02-11-2011, 08:18 AM   #10687
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,576
Do those have an aluminum bar/spine that helps prevent broken brake/clutch levers and crushing injuries to your hands in the case of a fall or get-off? If not, what use are they (like the stock TA ones) other than for wind and light brush/branch strike protection?
Help Stop McNugget Rage
WeeBee screwed with this post 02-11-2011 at 09:01 AM
WeeBee is offline   Reply With Quote
Old 02-11-2011, 08:29 AM   #10688
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,576
I too have the Acerbis Rally Pro guards and they also make contact with my Givi windscreen but not enough to prevent using the steering lock. You could use a curved file or Dremel tool with the Sanding Barrel attachment and make a slight "(" in the area that the handguard contacts the windscreen.
I too had to cut the ball end off my levers to prevent binding between the levers and the inside of the hand guards. Another slight drawback is I find the wind protection of the Acerbis guards to be less than optimal but this is only an issue for me when riding in temps below 35F. When the weather gets that cold, I put on a set of cheap Tusk Handlebar Muffs to block that icy wind and with my awesome Polly Heaters Grip Heaters on High, the problem of frozen fingertips is fixed.
WeeBee screwed with this post 02-11-2011 at 08:59 AM
Old 02-11-2011, 08:38 AM   #10689
thetourist
Just passing thru
Oddometer: 4,240
I epoxied a large bolt in the end of my bars. Drilled and tapped for a machine screw and then mounted the brush guard. This cleared the levers without cutting them down.
I then connected the two guards together with a heavy piece of "L" bent aluminum with one leg of the "L" onto the handlebar mounting bolts.
Remove the excess aluminum to your taste. It has been heavily tested and is very solid. Doesn't touch the stock windshield.
thetourist
The gate guard glares at me. "It's after curfew." He looks me up and down, "What do you think you are, some kind of ****** tourist?" ..Phu Loi 1969
My Idaho =7893
thetourist is offline   Reply With Quote
Old 02-11-2011, 12:39 PM   #10690
mas335
xendurist
Oddometer: 2,003
Some time back there was a discussion about changing Valve cover gaskets. It seems the question was if this could be done with the engine in the frame? Although the Honda manual does say this is possible I seem to recall someone saying it could not be done?
Sorry for the blurry memory about this topic but while I was getting ready to pull an engine from a frame I thought I would test out what really can and can't be done.
Bear in mind that I am striping this bike down to the frame so I have removed just about everything which would normally not be necessary.
The manual states that you have to remove both water tubes from the head but I had no trouble removing the front cover with the front water tube still in place.
The rear cylinder cover is another story, there is no way to remove the valve cover without removing the rear water tube mounted on the rear head. Once the tube is removed the valve cover will "roll" forward and lift off.
Without removing the rear water tube the valve cover will lift away enough to get some gasket type sealer on the head but you went this far and may as well do it right.
Transalps
Old 02-12-2011, 03:20 AM   #10691
costinell_mc
adv
Oddometer: 35
Lowering kit Transalp
Do anyone know where to buy a lowering kit for Transalp 2001?
costinell_mc is offline   Reply With Quote
Old 02-12-2011, 08:49 AM   #10692
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,576
A search of the Transalp forum on XRV.org in the UK turned up no direct links to a manufactured lowering kit. There are references to a lower seat option that was available for the XL650V so if you can find one used, that may help you lower your bike some. There are also references to lowering the front forks slightly and reducing the preload on the rear shock but these steps can produce handling problems in some cases if taken too far.
Here's some info that may help you from XRV.org
http://www.xrv.org.uk/forums/transal...available.html
http://www.xrv.org.uk/forums/transal...uspension.html
http://www.xrv.org.uk/forums/transal...de-height.html
http://www.xrv.org.uk/forums/transal...ernatives.html
http://www.xrv.org.uk/forums/transal...-lowering.html
http://www.xrv.org.uk/forums/transal...ne-bought.html
WeeBee screwed with this post 02-12-2011 at 08:59 AM
Old 02-12-2011, 08:51 AM   #10693
johnynovak
Oddometer: 22
did you try Louis or Polo in Germany?
nisam ginekolog ali mogu da pogledam
johnynovak is offline   Reply With Quote
Old 02-12-2011, 01:12 PM   #10694
mas335
xendurist
Oddometer: 2,003
I am listing a "rough" Corbin in the flea market.
Transalps
Old 02-12-2011, 07:24 PM   #10695
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,576
Anyone have an extra Front Turn Signal Socket & Wire Assembly they'd be willing to sell? One of mine up and died as I'm getting no continuity on the green wire between the plug and socket.
Times are GMT -7.   It's 03:01 PM.
