12-09-2011, 08:29 AM
#12586 | |
It's a short cut, really
Oddometer: 4,302
12-09-2011, 09:24 AM
#12587 |
Topher
Oddometer: 1,331
Ooh, I'd pay money to see that!
Topher 1989 Transalp. Sort of. I don't have a bucket list, I have a post-bucket list. So far it includes 1) Coroner's report is to read "Death by misadventure." 2) Dixieland jazz band at my funeral. |
12-09-2011, 09:31 AM
#12588 |
Oddometer: 4,302
Yes, I take PayPal |
12-09-2011, 10:18 AM
#12589 |
Wishing I was riding RTW
Oddometer: 2,425
Hey that Vespa is my avatar!
Ladder I found my dad a 89 with 26k on it needs some carb smoothing. Got some garage time available?
My screen name is kind of long. I am the "ME" part, my name is Cory. Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..." |
12-09-2011, 10:33 AM
#12590 | |
Ken Dodd's dads dogs dead
Oddometer: 533
So kind of you to offer garage space for the TA, but am adamant about selling it. |
12-09-2011, 10:39 AM
#12591 | |
Oddometer: 72
http://www.rando-moto.be BELGIUM Honda XL 1000 VARADERO 2008 - Honda TRANSALP 600 V 1991 - Yamaha TT 350 1991 - Honda XL 600 R 1985 In the past : Honda CAMINO & WALLAROO 50, Honda MT5, Honda DAX 72, Suzuki TS 50 X, Honda MTX 200 1985, Yamaha YZ 250 1990, Suzuki RM 250 1991, Kawasaki KX 125 1992, Honda CR 250 1994 2x. Greetings from Belgium - Western Europe
12-09-2011, 11:14 AM
#12592 |
Oddometer: 4,302
Cory,
Any better description of carb "smoothing". You're certainly welcome here, but it may be more fun (for me) to come to you. PM me and we can pick a time and day. |
12-09-2011, 12:22 PM
#12593 | |
Oddometer: 2,425
Sweet PM incoming
12-09-2011, 11:38 PM
#12594 |
Life is beautiful !!!
Eeeer... have mixed feelings
Engineer, mechanic, philosopher,adventurer...totally out there Reliable '90 Africa Twin aka "Desert queen" Mighty 2008 VTX 1800 T3 aka "Jumbo jet the queen of the skies" |
12-10-2011, 07:39 PM
#12595 | |
Oddometer: 174
'89 TRANSALP '05 XR650L '96 XR400R '00 XR650R '86 XL600R '83 XL600R |
12-10-2011, 11:19 PM
#12596 | |
12-11-2011, 06:58 AM
#12597 | |
Oddometer: 174
12-11-2011, 09:38 AM
#12598 | |
Oddometer: 1,583
Since you must ground the neutral switch it sounds like an interlock wiring /diode issue. Page 17.0 in the Honda TA shop manual explains the system. Page 18.0 shows the interlock and how it relates to engine cranking and the clutch switch plus neutral switch. The interlock system has two diodes. The interlock controls both spark and cranking as they relate to neutral, clutch handle and shifter position. Most times interlock does not relate to reving and engine run quality but it is possible if CDI grounding is marginal. Unmodified bikes can have this problem when the side switch is faulty with a marginal corrode connection. The side stand switch grounds the light green/yellow wire allowing spark. Grounding the light green/yellow should allow spark at all times. Does the side stand light work and neutral light work as expected?
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X 1971 CT90,1981 C70, 1986 TRX 250, 1993 TRX300 4X4, 1987 XR250L showkey screwed with this post 12-11-2011 at 06:28 PM |
12-11-2011, 07:22 PM
#12599 |
Oddometer: 174
[QUOTE=showkey;17493881]Since you must ground the neutral switch it sounds like an interlock wiring /diode issue. Page 17.0 in the Honda TA shop manual explains the system.
Page 18.0 shows the interlock and how it relates to engine cranking and the clutch switch plus neutral switch. The interlock system has two diodes. The interlock controls both spark and cranking as they relate to neutral, clutch handle and shifter position. Most times interlock does not relate to reving and engine run quality but it is possible if CDI grounding is marginal. Unmodified bikes can have this problem when the side switch is faulty with a marginal corrode connection. The side stand switch grounds the light green/yellow wire allowing spark. Grounding the light green/yellow should allow spark at all times. Does the side stand light work and neutral light work as expected?[/QUOTE Thanks for pointing out the electrical schematics on the manual. So, are you saying that the diodes may be faulty? Sounds like your spot on regarding the side stand safety switch. I have noticed that the side stand light seems to come on/off at times intermittently. I have checked and cleaned the connections to no avail. I had replaced it too with a good known working unit with the same results. How do you ground the light green/yellow side stand switch? Just put them together or insert a wire between both terminals and secure them together? The neutral switch light works fine. Looking forward to your reply. Thanks!
12-11-2011, 08:12 PM
#12600 |
I don't need a title
Oddometer: 365
I'm just trying to follow along here with the Hawk/TA swap because I own an 89 Hawk and an 89 TA. I was just going through the service manuals I have on my computer and the Hawk only has one CDI if I am right. Sitting here armchairing it, it seems like getting a Hawk harness/CDI setup is the best way to complete this swap. Again, don't know anything other than that I've seen TA's with Hawk engines on here. If you think the service manual will help you can download it online from http://liucrative.com/hawkgtmanual.pdf
I also do know that the ignition rotor is completely different for the 2 bikes. I have a Factory Pro advancer that someday I'll get around to installing on the Hawk. Looks totally different than the TA one in the fiche on sites like Bike Bandit, etc. Hope that helps and good luck! (just saw that you posted on Hawkgt forum that you were looking to buy the whole Hawk setup)
Semper Fi & YAT-YAS! |
