Old 07-26-2012, 05:56 PM   #13471
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,268
I love my bike!!!!!! Its been sitting in the garage for 3 months....and it started on the first try! No battery issues, no hassle!
Carlos locorider
1974 Catalina 22....sailing, mi otra pasión!
"If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian
"Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller
Longaniza Ride
Ruta del Café
Old 07-27-2012, 04:16 PM   #13472
happyclam
happyclam's Avatar
Oddometer: 52
Originally Posted by Ladder106 View Post
This will only work if the TA caliper will bolt up to the XR forks
AND
Will also line up with the TA disc.
If this does indeed work you will have just discovered a great TA improvement and should also run right out and buy a Lottery ticket.....not that I'm pessimistic...I really hope it works...not highly probable.
Correct me if i'm wrong, but i think i saw on transalp.org there is an adapter for the rotor to bolt to the xr forks. I'm preety sure 1 guy just enlarged the bolt hole/ made it oblong to accomadate the bolt.. they may have changed the spacers as well for the disk to line up.If I had a functional ta wheel .... but i don't so.....?
happyclam is offline   Reply With Quote
Old 07-27-2012, 05:39 PM   #13473
macrae85
Oddometer: 375
My old Transalp 650 when in Norway.
Hepco Becker 'box frames' as used on this bike on eBay.co.uk
will post Worldwide,225GBP here,starting/sell for 99GBP
Search the word "Touratech",you'll find them.....ultra rare secondhand!
macrae85 is offline   Reply With Quote
Old 07-27-2012, 08:51 PM   #13474
WarHorse1961
Oddometer: 13
Went out to Denver back in April. Ended up having to jump start my buddy's KTM 990 Adventure almost every day. And that was AFTER cranking mine over for 5 minutes to get it started.
"There are four boxes to be used in the defense of liberty: soap, ballot, jury, and ammo. Please use in that order." - Ed Howdershelt
WarHorse1961 is offline   Reply With Quote
Old 07-27-2012, 09:35 PM   #13475
locorider
locorider's Avatar
Oddometer: 2,268
I transfered the big disc adapter from the TA forks to the xr's. Had to grind a little but its working fine....as is the wheel nut spacer on the shock...
Carlos locorider
Longaniza Ride
Ruta del Café
locorider screwed with this post 07-30-2012 at 08:28 AM
Old 07-28-2012, 09:05 AM   #13476
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,269
Yes but this was with early 90s XR forks. I,m assuming yours are modern
XRL models. dunno if the caliper mounting is the same or not....if so, the mods on the early part of this thread should work well.
Ladder106 is offline   Reply With Quote
Old 07-29-2012, 10:41 AM   #13477
Freakdaddy
Freakdaddy's Avatar
Oddometer: 9
Temp Guage
Need a little help on my NT 650 engine swap into a T A chassis. Could someone please tell me left to right sitting on bike how the black, green, and blue with green stripe wires are installed into the back of the temp guage on U S model. After a long bout of stagnation I finally got the carbs working and it runs bitchin. Got some wiring and fab. work and I should be back in the saddle. I will do a recap when completed for everyone edification of my trials and tribulations. As our motorbikes accumulate the miles I think many will go the NT 650 engine swap as there are many out there.
Freakdaddy is offline   Reply With Quote
Old 07-29-2012, 04:20 PM   #13478
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,418
Been following this thread for a bit now. 2 up 89 TA through Mexico and south America pretty impressive
http://www.advrider.com/forums/showt...684537&page=15
They have plenty of mods and do some trouble shooting as you would expect on a epic journey.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 07-30-2012, 05:53 PM   #13479
happyclam
happyclam's Avatar
Oddometer: 52
I think i'll keep searching for a ta wheel, hub,rotor,...but in the mean time i'll just improve on the xrl set up. That's a beautiful ride locorider.
Old 07-30-2012, 06:37 PM   #13480
Hotmamaandme
Oddometer: 2,418
Some one help this guy
Mark or ladder someone help this guy. We are all going to need his super detailed full of pictures write up on the hawk motor swap.
Old 07-30-2012, 08:22 PM   #13481
showkey
Oddometer: 1,571
According to the shop manual wiring diagram:
Green on the right
Black is in the center
Green with blue on left
This info has not been double checked on the bike, proceed with caution.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 1987 XR250L
showkey is offline   Reply With Quote
Old 07-30-2012, 08:31 PM   #13482
Ladder106
Ladder106's Avatar
Oddometer: 4,269
When I mated my AT gauges up to the TA wiring I found the temp gauge not working....on closer inspection is was working but in reverse. I swapped the two wires leading to the gauge and it's been working well ever since.
Maybe the Hawk temp sensor is wired the other way 'round.
Old 07-31-2012, 12:14 PM   #13483
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,450
Just picked up a very nice 1900 original mile transalp. A few carb issues but all is well. I've searched here but haven't been able to find the info, has anyone found acceptable substitutes for honda's discontinued carb kits.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 07-31-2012, 01:03 PM   #13484
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,450
Never mind, if it helps anyone else, I have been told the GL1200 diaphramns fit perfectly but the proper ones and floatbowl gaskets are available from these guys in England, http://www.nrp-carbs.co.uk
JT
Old 07-31-2012, 01:57 PM   #13485
Hotmamaandme
Oddometer: 2,418
Thanks for the tip
Times are GMT -7.   It's 12:57 AM.
