Old 08-27-2012, 10:56 AM   #13576
mas335
xendurist
Oddometer: 1,974
Chris,
I have not studied your comments and questions but only caught the issue about the counter shaft sprocket "wobble". I do not know how bad yours is but every Transalp that I have worked on clearly has some very noticeable counter shaft sprocket "wobble". A more accurate description maybe "wiggle" but it is unmistakeable and normal.
The current Transalp that I am working on has less that 1,900 original miles and the counter shaft sprocket clearly wiggles, they just don't fit all the tightly on the shaft.
After market ( non OEM Honda) sprockets are another matter and I can not comment on their quality of machine work and fit.
I only mention this in a effort to clarify that there is normal sprocket "wiggle" and perhaps there is no reason to be overly worried about it.
Transalps
mas335 is offline   Reply With Quote
Old 08-27-2012, 11:18 AM   #13577
Belgian Waffles
Oddometer: 874
Been looking at batteries with the tips I read on here. I saw that Motorcycle Superstore is having a sale at the moment so I thought I'd check out their battery selection.
On the drop down menu for bike models the TA wasn't listed, so I selected XR650L (1993) and NX650 (1989) as the closest big bore bike on there to the TA. I don't know if these bikes would use the same batteries, as the twin may need a different amount of cranking power?
The batteries that turned up are:
Western Power Sports YTX9-BS - -- - $44.99
Western Power Sports sealed factory activated battery, YTX9-BS - -- - $72.99
Can anyone tell me if these batteries will work with the TA?
Thanks.
BW
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying.
Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials
Past: 1999 KLR 650, 1990 Tengai 650
Belgian Waffles is offline   Reply With Quote
Old 08-27-2012, 12:40 PM   #13578
showkey
Oddometer: 1,936
[QUOTE=mas335;19456589]Chris,
I only mention this in a effort to clarify that there is normal sprocket "wiggle" and perhaps there is no reason to be overly worried about it.[/QUOT
+2 on the above................the front sprocket is a floating design used on hundreds of 1000's of Hondas and "wiggle" is TOTALLY normal and I could image it has been described as a wobble but most are very loose on the splines and Honda retainer and Honda sprocket effect this fit.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 08-27-2012, 04:56 PM   #13579
2old2Bbold
was 2bold2getold
Oddometer: 1,732
Sorry. Guess I should have asked how much "wobble" was in wobble. Didn't mean to lead anyone astray.
2old2Bbold is offline   Reply With Quote
Old 08-27-2012, 06:08 PM   #13580
happyclam
happyclam's Avatar
Oddometer: 155
shock spacer
Hey, Anybody have a shock spacer laying around? Did the xrl front end, now need to raise the rear a tad. Thanks. Jeff.
happyclam is offline   Reply With Quote
Old 08-27-2012, 06:24 PM   #13581
Motoswami
Motoswami
Oddometer: 79
Transalp rally in North Carolina
Posting this here just so no inmate misses the alert -- there will be a Transalp rally at The Ironhorse Lodge in Stecoah, NC, October 12-14. Camping, cabins, bunkhouse are part of this complex. Meals served morning and night on weekends. Very nice facility in a great part of the country.
Motoswami is online now   Reply With Quote
Old 08-27-2012, 07:32 PM   #13582
ChrisUK
ChrisUK's Avatar
Oddometer: 602
When does a wiggle become a wobble?
I'm gonna have to wait til next year to see how my current sprok and a new one compare in wobble/wiggle stakes. I can't decide if mine wiggles or wobbles. The level of movement may be normal or worse because the hole in the centre of the sprocket may have worn because of the sideways force of being pulled "wrongly" by the chain.
I read somewhere that non-oem holes are harder than the shaft, so the shaft wears and that on oem sproks, the hole is softer, so the hole wears. Maybe my sprok is oem? I paid an oem price and the invoice included a Honda part number (discussion elsewhere, linked previously).
I'm now off to fix my Scottoiler and spotlights. They got wet a little while ago...
Remember to turn up the volume. The Off looks a bit lame, sorry.
Thanks again guys!
ChrisUK is offline   Reply With Quote
Old 08-27-2012, 09:10 PM   #13583
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Thanks.
BW
They may work for a while. Listen to your elders and buy a YTX14AH-BS. I can help you if you need some.
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 08-28-2012, 05:36 AM   #13584
Clockwatcher
Oddometer: 514
My 2 cents.........
Hey Jeff, Since you have done the forks why not match the rear with a shock? Give Rick a call at Cogent Dynamics, he built me a Moab shock for my TA and the difference is amazing. The Moab shock provides 10 1/2 in of travel on the rear to match the 11 1/2 of the xr forks. Rick also increased the springs in my xr forks to handle the weight of the TA. This guy knows suspension stuff..........
I also have a spacer if you decide to go that way.......
Russ
Clockwatcher is offline   Reply With Quote
Old 08-28-2012, 05:58 AM   #13585
Clockwatcher
Oddometer: 514
FYI on batteries.........
I have been getting batteries from Batteries Plus......they are nationwide and are comparably priced.
Would be handy if you are traveling and had battery issues.
They also had a Transalp listed..........just sayin.......
Old 08-28-2012, 06:19 PM   #13586
Belgian Waffles
Oddometer: 874
That's exactly what I needed to hear, thanks. Do you have any good sources (or do you sell any?) or would I be better off just looking for a local one?
Belgian Waffles screwed with this post 08-28-2012 at 06:26 PM
Old 08-28-2012, 08:03 PM   #13587
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,986
Search this thread.
Carlos made a great one from a auto lugnut. Forget the model but its listed here somewhere.
Ladder106 is offline   Reply With Quote
Old 08-28-2012, 09:07 PM   #13588
2old2Bbold
was 2bold2getold
Oddometer: 1,732
Originally Posted by Ladder106 View Post
Search this thread.
Page 353 - starts at post # 5283
Old 08-29-2012, 04:35 AM   #13589
ChrisUK
ChrisUK's Avatar
Oddometer: 602
Sorry to sound like an anorak, but should you be interested in creating a modified front sprocket retainer (as mentioned above or on page 905), the grove it sits in is 3.15mm wide (the oem retainer is 2.3mm thick).
Managed to get special dispensation from Mongolia Customs today to leave my bike here for a year. They belieeved my bike is genuinely only worth 600 bucks... Hence v low deposit needed.
Siberia 2013 is on!
cheers guys
Old 08-29-2012, 03:15 PM   #13590
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,695
TA forsale
I just listed one of my TAs for sale
http://www.advrider.com/forums/showthread.php?t=821872
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Times are GMT -7.   It's 02:36 AM.
