02-03-2013, 12:00 PM
#14236 |
Oddometer: 24
bashplate made this weekend
its 10mm HDPE, £30 for 1000x500mm only need 600x500, so enough offcut for the CCM404. http://www.directplasticsonline.co.u...et/Black/10mm/ its a tough plastic which is hard to break, but does flex slightly so i've doubled it up on the vulnerable sump with 10mm Acetal, tougher/hard/doesn't flex but 3 times the price (i had an offcut lying around) i've made these for 3 or 4 dirtbikes over the years and they are cheap, light, strong and easy to make for DIY you can cut with a jigsaw and heat it to bend with a heatgun. I have a strip heater and table saw so easier for me cos the transalp sump hangs level with the bottom of the frame, i've spaced it by 15mm to allow for flex and have the Acetal in that area (i bust a transalp sump in Morocco which had an Africa Twin 4mm ali bashplate) Transalp bashplates are £160 for 3mm ali (grade not specified so won't be the Aircraft alloy Dural) local fabricators wouldn't make me one for less than that so DIY bit of faff and numerous refitting but.... ![]() ![]() on the bike (mudguard was £25 delivered off an Tenere) ![]() ![]() had a thrash round the field finally and it was fun, needs a big space, think i'll lower the gearing! fairing next weekend......
http://i589.photobucket.com/albums/s...b110/all-1.png Dirty R30 CCM Filty 404 CCM Tatty Transalp Rob 110 screwed with this post 02-03-2013 at 01:39 PM |
02-03-2013, 08:11 PM
#14237 |
Oddometer: 796
Advantage of the inverted brake setup? Just clearance for brush/rocks?
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying. Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials Past: 1999 KLR 650, 1990 Tengai 650 |
02-03-2013, 08:14 PM
#14238 |
Oddometer: 796
Beautiful fix Floyd! What kind of compound did you use to rebuild the plastics?? I think a lot of us here would be happy to get ahold of some of that...
02-03-2013, 10:18 PM
#14239 | |
Roaming ADV Gnome
Oddometer: 1,395
Have a look at this post I made regarding a fix for that problem. You'll have to email the guy to see if he's still making the product. http://www.advrider.com/forums/showp...postcount=7974
02-03-2013, 10:51 PM
#14240 | |
BIG ENDURO FREAK
I've used a fiberglass like this guy on youtube. Great instructions there. Fiberglassing part starting on 2:50. |
02-04-2013, 05:58 AM
#14241 | |
Chasing after theory
Oddometer: 140
Life is the last thing you experience before you die...living is what you do every day to get you to that point... |
02-04-2013, 07:41 AM
#14242 |
It's a short cut, really
Oddometer: 4,302
A bit of Anti-seize on the threads and just a bit of grease on the O-ring will keep this thing from welding itself to the case.
Also beware of Crafsman allen sockets. I've measure quite a few sets (to the odd glances of the salesman) with calipers and found them all to be a few tenths of a mm small. Snap-on ($$) is your friend here. The craftsman product will almost always round off a stubborn allen...particularly bad when it's as visible as this one. |
02-04-2013, 10:55 AM
#14243 | |
Oddometer: 140
02-04-2013, 11:45 AM
#14244 |
Loco, pero no estúpido!
Oddometer: 2,274
See that in the original position, you are pushing. In the inverted position, you are pulling. I dont know if there is any advantage, other than if you push hard, the brake rod might tend to bend and absorb the energy...
Carlos locorider 1989 Honda XL600V Transalp, slightly modified! 1974 Catalina 22....sailing, mi otra pasión! "If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian "Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller Longaniza Ride Ruta del Café |
02-04-2013, 11:52 AM
#14245 |
Oddometer: 2,274
02-04-2013, 12:22 PM
#14246 | |
Oddometer: 2,274
Good to know!
02-04-2013, 02:10 PM
#14247 |
Oddometer: 140
Carlos, looking at the mechanism in close detail and how the cam applies force to the pads, either a push or pull fashion gives equal loading, as that is based on the fulcrum at the pedal. However I did notice that you had applied a rubber coating over the arm to prevent rubbing and banging on the swing arm as I can see that under a vertical or "bouncing load" you could hit the arm and damage the paint. I just bent mind a tad bit further out and if I hear any banging or see and damage I will coat mine as well. Here is a cool older modification I found of how a racer configured his bike. Seems this idea and worry about damaging the lever arm hanging down has been around for awhile.
![]() I still liked how you did it and feel comfortable with using a reverse from the OEM configuration. As I did not post up pictures above, here are two quick snaps taken this morning before work: ![]() Now its like the jigsaw puzzle in making sure I get all the pieces back in the right order I took them off!
02-05-2013, 04:51 AM
#14248 | |
Oddometer: 791
Dudley
What ever happened to Roberta Claypool? 1996 Triumph Trophy 900 1989 Honda Transalp 2010 KTM 690 Duke |
02-05-2013, 11:45 AM
#14249 | |
Oddometer: 2,274
02-05-2013, 12:23 PM
#14250 | |
Oddometer: 2,274
