Old 03-13-2013, 12:50 PM   #14416
thepoddo
thepoddo's Avatar
Oddometer: 53
Originally Posted by mgorman View Post
They are easy to shorten, I have some spacers here from a set of WP's that were on my 640 to lower them 2"
I already lowered them 21mm, but I'd like to take advantage of the greater excursion
and unless I use some more raisers the rebound registers on top of the forks are going to end up against the lower end of the handlebars
thepoddo is offline   Reply With Quote
Old 03-13-2013, 05:02 PM   #14417
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,720
Those CR shrouds look pretty good on the TA. With a nice baja designs LED head light it would be a good no fairing option.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 03-14-2013, 10:39 AM   #14418
danyila
danyila's Avatar
Oddometer: 74
http://vimeo.com/61606264
This is too much ! Hard ! Very hard. Russian film. Good team.
Good !!! :-)))) No problem. :-))
This area:
GPS: 53.092375, 56.465378
Hiking around the lake !
danyila screwed with this post 03-14-2013 at 11:04 AM
danyila is offline   Reply With Quote
Old 03-14-2013, 02:13 PM   #14419
GSPD750
GSPD750's Avatar
Oddometer: 1,468
This area:
Awesome vid! 19 minutes well spent. All thumpers too...and
rightly so. Were those ticks they were pulling out of their skin with
thread?
The field radiator repair was cool. Vodka and rope also appears to be standard issue in those parts for a trip such as that. Thanks for putting that up.
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 03-14-2013, 06:18 PM   #14420
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 5,097
Great vid.
Note the complete lack of hard bags.
Good thing it didn't rain. T'was muddy enough already.
Also, it would appear that the women don't take kindly to motorcycling types....sad.
Ladder106 is offline   Reply With Quote
Old 03-14-2013, 06:51 PM   #14421
happyclam
happyclam's Avatar
Oddometer: 163
This area:
Awesome! Thank You. Makes me miss my xrl, colorado, and vodka. Might have to try that tick trick.
happyclam is offline   Reply With Quote
Old 03-14-2013, 07:28 PM   #14422
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,304
Make sure your tire does not bottom against the lower clamp, that could ruin your day
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 03-14-2013, 07:32 PM   #14423
Ladder106
Ladder106's Avatar
Oddometer: 5,097
From what I've done in this area, I find you wil contact the frame downtube (and crashbars if installed and the front wheel is turned) before you will contact the bottom triple clamp.
I you possess any sense of self-preservation, you will assess the full travel of front and rear suspension and make certain that the tire stays free of hard parts.
Old 03-15-2013, 03:30 AM   #14424
thepoddo
thepoddo's Avatar
Oddometer: 53
already tried and tested for that
I bottomed hard just once, coming down from a 60 slope to a flat part
the wheel sligthly scratched the crashbars, nothing major
I am pretty sure it won't get stuck in there since wp forks have the wheel advanced 60mm more that the regular ones, and it was already happening many times with those
I guess I am going to check anyway, and I'll make myself a couple 20mm spacers just to be sure
thepoddo screwed with this post 03-15-2013 at 03:37 AM
Old 03-15-2013, 03:55 PM   #14425
hobes
Oddometer: 18
Originally Posted by Santa View Post
I wanted to ask if anyone has recomendations for rad shrouds and maybe pics?
I see that UFO sells the 89 CR 125 shroud in the US.
Anybody have a pic of them on a TA?
Originally Posted by hobes View Post
here is my '88 TA (PD06) im owning since '92, modified a little bit in the late '90ties
RD04 engine
RD04 swingarm
RD03 fork and brake
yes, these shrouds are for a '89 CR 125/250 (from Cemoto), since several years no longer available here in Germany or Europe.
It's nice to hear that UFO sells them - still or again (fortuantely I still got one Cemoto set)
hobes is offline   Reply With Quote
Old 03-15-2013, 06:14 PM   #14426
thepoddo
thepoddo's Avatar
Oddometer: 53
you can drop a mail at UFO
I heard they always keep the molds and can run a small batch production if asked
Old 03-15-2013, 07:54 PM   #14427
2old2Bbold
was 2bold2getold
Oddometer: 1,909
Made a little progress on the TA. Installed some new LED turn signals and extra LED indicators. Welded a couple of brackets on the engine guards to get the turn signals on a lower plane, away from the head lights. Replaced the RD07 clocks that came on it, to me, with correct RD04s. That bit of rewiring led to adding a relay for each headlight, 1 relay for the horns, an LED flasher relay and a couple of relays for the turn signals. By using 2 NC relays you can wire the turn signals as running lights (always on) and cause them to flash as turn signals, and light the indicators. This, of course is not new, there's all kinds of info on the web on how to do it, but it still took a couple of trys to get em all working right. Boy, this stuff was a lot easier 40 years ago.
2old2Bbold is online now   Reply With Quote
Old 03-15-2013, 08:28 PM   #14428
Hotmamaandme
Oddometer: 2,720
Sweet Rothmans TA
Old 03-16-2013, 11:49 AM   #14429
KilgoreTrout
adventure flyfisher
Oddometer: 372
Good Chuckles on a snowy day
This area:
Can't wait for some spring mud to ride in
96 DR 650,,87 XL600V,89 DR 750 Big,77 Montesa Cota 247,77 TY 250,76 TY175,76 TL 250,75 CT90
KilgoreTrout is offline   Reply With Quote
Old 03-16-2013, 12:25 PM   #14430
Ladder106
Ladder106's Avatar
Oddometer: 5,097
I remember the days before every 3rd person had a law degree.....days when you could just take off and ride cross-country like those guys did.
Now every bloddy vacant lot has chainlink around it and all of our off-road planning is tied up trying to determine if the forest service gates are open or locked.
Times are GMT -7.   It's 01:43 PM.
