Old 05-13-2013, 05:11 PM   #14746
thepoddo
thepoddo's Avatar
Oddometer: 52
Originally Posted by P3ia View Post
Finally done modding my Tranny.
that paintjob really make it shine
can you post a pic of the front?
thepoddo is online now   Reply With Quote
Old 05-14-2013, 04:41 AM   #14747
P3ia
Swede
Oddometer: 42
Transalps do not look pretty from that direction...
(No bags on this pic)
P3ia is offline   Reply With Quote
Old 05-14-2013, 05:41 AM   #14748
mas335
xendurist
Oddometer: 1,927
Standard OEM rear shock for 89-90 and I think 91 as well is 375mm center to center or very close to that number.
Transalps
mas335 is online now   Reply With Quote
Old 05-14-2013, 08:57 AM   #14749
R_Rick
Oddometer: 332
That makes sense. I recall somewhere a few hundred pages back (or possibly in another thread) that someone was looking to sell a rear shock that was received in error. Said that he was shipped one for an 87/88 model that was about an inch shorter than his 90ish.
I'll pop mine off one of these days and measure it.
R_Rick is offline   Reply With Quote
Old 05-14-2013, 05:00 PM   #14750
ric678
ric678's Avatar
Oddometer: 866
no start
Well after a long winters sleep my TA doesn't seem to want to start, Like no turning over start. I have the battery on the charger overnight, Any weird hidden fuses or circut breakers I should check?
Just random blather
ric678 is offline   Reply With Quote
Old 05-14-2013, 06:47 PM   #14751
Big Chris
Oddometer: 87
There's a good chance your petrol has gone stale, since they took lead out of petrol it seems to now have a shorter life. Drain it out of both the tank and carbs and pour it into your car's fuel tank. Get fresh petrol. Also get a small syringe and some fuel line, remove a sparkplug and squirt 1cc (no more!) of fresh petrol into each cylinder. If you have a healthy spark that should get it running.
Before doing all this turn the engine on the starter motor to ensure oil gets to the top end before it runs.
Big Chris is offline   Reply With Quote
Old 05-14-2013, 06:51 PM   #14752
thepoddo
thepoddo's Avatar
Oddometer: 52
I got a 650 myself, that's why I asked
Still it really look good in those colors, even in this pic
Old 05-14-2013, 06:59 PM   #14753
ric678
ric678's Avatar
Oddometer: 866
Well when I get it to actually turn over I can worry about the gas, /the tank did have some sta-bill stuff put in it, and it always seemed to run on just about any fuel I put in it, I couldn't get any cranking or lights at all, not even the horn..
Just random blather
Old 05-14-2013, 07:09 PM   #14754
wdeTA
TransAlp Adv
wdeTA's Avatar
Oddometer: 449
If the bike sat that long and there was any moisture, some or all of the important electrical connections can corrode a little or at least get a film on them that limits the juice that can get through. Disconnect the major wires in the battery/starter circuit, clean them using electrical spray like Deoxit, and make sure everything is connected back up properly. If you know your battery is properly topped off, you can use your volt meter (everyone has one right ) and trace down how far the power is getting.
Dale
89 Transalp
01 XR400R
http://daleeva.smugmug.com/Motorcycle
wdeTA is offline   Reply With Quote
Old 05-14-2013, 07:40 PM   #14755
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
This may be a silly question but in what position is your kill switch? Another one, is the bike in gear with the sidestand deployed?
Jim Rowley
Black Forest, CO
Jim Rowley is offline   Reply With Quote
Old 05-14-2013, 07:44 PM   #14756
2bold2getold
Oddometer: 1,577
No weird fuses or circut breakers. There's the 30amp fuse on the solenoid/start relay and the ones up front, but they shouldn't keep it from cranking. If your battery is GOOD and it won't crank, try jumpering across the start relay. that should make it spin.
2bold2getold is offline   Reply With Quote
Old 05-14-2013, 11:18 PM   #14757
Belgian Waffles
Oddometer: 874
Put some rubber killers on my handlebar mounts to get rid of the squishy feeling in the bars. Handling is much better and feels like a much more solid machine. Definitely recommended. Thank you to Jim Rowley for the parts.
I was looking at why my rear brake light is always on and discovered that for some reason my lever no longer covered the solenoid on the front side of the assembly. Not sure why, but I JB welded a little piece to cover it back up and now the solenoid clicks properly with each pull of the lever, but my light is still stuck on.
Before I discovered the solenoid issue I put some WD40 around the whole assembly thinking something mechanical was stuck. Could the WD40 have shorted the circuit to keep it always on if it got in there? Or insulated it maybe? I wonder if electrical contact cleaner will help clean it up?
Always chase your dreams. Even if you don't catch them, you'll have a hell of a time trying.
Current: 1989 Honda Transalp, 2006 Scorpa TY125F trials
Past: 1999 KLR 650, 1990 Tengai 650
Belgian Waffles is offline   Reply With Quote
Old 05-15-2013, 12:09 AM   #14758
GSPD750
GSPD750's Avatar
Oddometer: 1,429
Hello Jordan...first..it's actually a switch and not a solenoid. It may be mechanical so first thing is to check the security of the spring and it's function. The switch can be checked with a multimeter...and if it's faulty just order a new one.
Item #3 at the following. Spring is #4
http://www.bike-parts-honda.com/piec...NSALP+600.html
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 is offline   Reply With Quote
Old 05-15-2013, 07:36 AM   #14759
Jim Rowley
Rise above
Jim Rowley's Avatar
Oddometer: 2,512
Jordan, you may want to check the rear brake light switch too. If it's dirty, it will stick. Both front and rear switches are mechanical and require more attention than the pressure switches.
Jim Rowley
Black Forest, CO
Old 05-15-2013, 10:07 AM   #14760
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,928
Remember there are 2 switches. One operated from the front brake lever, the other from the rear footbrake lever.
The rear light switch is adjustable up and down.
To find the culprit, remove the rear braks spring from the pedal, then see if the light operates correctly with the front brake lever. If not, repair the front switch. If the light is OK, adjust or repair the rear.
Normally, when a light stays on all the time it's because the rear switch is out of adjustment so I'd look there first.
Ladder106 is offline   Reply With Quote
Times are GMT -7.   It's 05:03 AM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
