Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 12-26-2013, 02:44 PM   #2971
Themastermike
Passin gas
Themastermike's Avatar
Oddometer: 754
Originally Posted by Gamequeazy View Post
I'm guilty of doing this to multiple people on a hillclimb on bigdogs old bike in front of bigdog. Does that make me a bad person?
THAT isn't what makes you A Bad person, only confirms it.
Sent using Telepathy
BBF 03-09-13 "It is cool. I was playing dakar racer It truly was a gr8 day of riding you bitch"
Themastermike is online now   Reply With Quote
Old 12-26-2013, 02:52 PM   #2972
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,600
I'd say that's between you and your DOG.
What if you took Axl Rose down to Paradise City, but the grass was brown and under watered?
bigborefan is online now   Reply With Quote
Old 12-26-2013, 04:29 PM   #2973
Nodabs
Nodabs's Avatar
Oddometer: 218
Passing off road is a no no? Damn I've been doing it wrong for at least 45 years then. I thought that passing everyone was the point!
Why does it hurt when I pee?
Nodabs is offline   Reply With Quote
Old 12-26-2013, 05:12 PM   #2974
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,600
Finally, someone that gets it. Welcome aboard Nonubs.
Old 12-26-2013, 05:45 PM   #2975
Themastermike
Passin gas
Oddometer: 754
I will start using turn signals to indicate I am ALLOWING you to pass, not that you are passing me. If I don't get them installed, just consider me flipping the bird to be a signal that I am allowing you to pass.
Please don't puke in trail when you get past me tho, you dog?
Old 12-26-2013, 06:00 PM   #2976
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,600
I puked one time, I think it was allergies, drainage made me nauseous, and the blistering pace that I run would make anyone puke.
Old 12-27-2013, 06:20 AM   #2977
ihatemybike
Oddometer: 381
Ah, well according to the title its a 93. Thanks for the offer! I need to get around to pulling the CEL codes (intermittently on, but ehhh) and probably swap the shocks and check the plugs and air filters (cabin and interior). Most annoyingly, the hitch mounting points on the body are totally rusted out as seen here:
Damn! I can't say that I've ever seen a Astrofari rusted that bad under there and with all my bone yard picking that's saying a lot. I zoomed your first pics, I was thrown off on the year by what looks like paint coming off the mirror arm, making me think it was the older thinner arms.
Reading the codes is easy.
Use a paper clip or similar to jump A to B
Turn the key to the on position
Engine light will flash once short pause then twice (12) three times
Then count the flashes to acquire the codes, it will always be first of two numbers, short pause then the second number
Example 5 flashes pause 2 flashes = 52
When done it with flash 12 three times again
Rear shocks are pretty easy, PB Blaster and some heat may help.
Front shocks on RWD vans, I've always had to break the top of the shock's piston rod off. I use an impact socket and a breaker bar. Push down on breaker bar, rotate, push down, rotate, push down. Pretty quick actually.
Spark plugs are done through the wheel wells, remove the splash guard and they are a straight shot between the body and sub-frame. I use a about 18" worth of extensions with an impact universal joint just behind the socket to make the job easier.
No Astrofaris ever had cabin filters. I'm partial to Amsoil air filters, dry and re-useable.
Check the RPO codes in the glovebox, see if you have a G80 (limited slip rear diff). If it doesn't have it, I highly recommend swapping one in. Really helps these vans get around in the snow and off-road. I get mine from LKQ, cause they can be had for $126. Usually found on the AWD vans.
Aaron - Elgin, IL
1980 Kawasaki KE100 (ZomBessy)
ihatemybike is offline   Reply With Quote
Old 12-27-2013, 10:20 AM   #2978
Themastermike
Passin gas
Oddometer: 754
Cool story Bro
Old 12-27-2013, 10:22 AM   #2979
Themastermike
Passin gas
Oddometer: 754
GQ bonds on the oddest topics
#strange
Old 12-27-2013, 11:05 AM   #2980
vfrpilot
Stress Relief Rider
vfrpilot's Avatar
Oddometer: 719
John, you are the most politically incorrect lib that I have ever had the pleasure of being around!
Luv ya man!
*1975 Kawasaki KS125 **1987 Honda TR200 Fat Cat
*1976 Honda MR250 Elsinore **1987 Honda XR200R
*2011 Beta 400RR **2012 R1200GSA
*2012 Gas Gas TXT250 **2014 Beta 520RS
*2014 Ural Patrol
vfrpilot is offline   Reply With Quote
Old 12-27-2013, 12:06 PM   #2981
paulrn
User Awaiting Email Confirmation
Oddometer: 430
I have known John a long time. We have had many discussions involving politics. He has influenced some of my thought and I think maybe vice versa. The thing that separates John from most liberals is his willingness to be open about what he wants. Also, John is not a hard core socialists/fascists/statists/wannabe dictator more commonly encountered. Not even sure I would call him a liberal, more of a libertarian with an expanded view of the social safety net.
paulrn is offline   Reply With Quote
Old 12-27-2013, 12:47 PM   #2982
Nodabs
Nodabs's Avatar
Oddometer: 218
Nodabs, Nonubs. Tomato, Tomatoh.
It is kind of funny, the Nodabs is because I am a trials guy. Nonubs is just making fun of the fact that I am missing a part of a finger on my left hand.
It is hard to be ridiculed because of a vicious accident.
I was working at the St. Louis Zoo as a feeder for the tigers. We had one particular Siberian that one day took a liking to my left hand. I hope it was the best meal that he ever had.
Or I could just be telling a tall tail, hard to tell the difference.
Old 12-27-2013, 01:21 PM   #2983
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,600
I had no idea that Nonubs was digitally challenged. I just try and butcher everyone's screen-name and Nonubs came to mind. I think it all worked out quite well.
My buddy in OKC, his lady friend lost a part of her pinky trying to separate his two bitch dogs during a fight. The dogs are Dachshunds. They never found the tip of the pinky. I think the dog ate it. He had to buy her a press on prosthetic. I have heard of Press-On Nails, but not entire fingers.
Not sure which story is better, Dachshunds vs. Tiger, but they're both good stories.
My politics are complicated. I took a test, it said I was a left leaning Libertarian. I would agree with that. I came to realize that the Left/Right paradigm is all part of the Rothschilds NWO plan. Keep us fighting each other and we won't have time to fight them. I'd bet $100 all of us on here have more in common than not.
I think Paul might of just paid me a compliment. One of the few I have received on ADVRider. Thanks Paul.
Old 12-27-2013, 02:29 PM   #2984
Themastermike
Passin gas
Oddometer: 754
I've seen lots of bbf compliments on Adv.
Of course you wrote em all.....
:O
Old 12-27-2013, 04:02 PM   #2985
paulrn
Oddometer: 430
Hey guys I wanted to let you local guys know about this before I put it out more widespread. I am selling my 2007 KTM 450exc. Please PM me any questions.
Times are GMT -7.   It's 09:29 AM.
