10-04-2008, 07:56 PM
#1 |
NoMoTDM still Gary
Oddometer: 3,709
F800GS Toolkit needs
The 800 fasteners are just about all Torx vs hex or Allenhead.
So to work on the bike you need the following: Torx T10 left control housing T20 throttle assembly T25 fairings, control, body work T30 muffler mount, signals, motor chassis, rotor T40 triple clamp, brake pivot, rear rotor, brake line T45 body, exhaust mount, fork axle pinch bolts, controls T55 Bar Ends Torx socket E10 handlebar clamps E12 Front Caliper brakes Wrench 13mm Chain tension sprocket 17 mm Front Axle 24mm Rear axle 24mm Drain plug. PackMule screwed with this post 10-16-2008 at 12:22 PM Reason: Corrected rear axle size (24mm) |
10-04-2008, 08:02 PM
#2 |
Really, Really Cool
Oddometer: 3,315
Nice
Great post, really helpful.
Thanks, You'd think Bmw would include a driver, all the torx bits, and a few sockets. It could all fit in that little first-aid kit area under the seat. |
10-04-2008, 08:56 PM
#3 | |
Oddometer: 81
E8 for the external torx on the gear shifter lever. 19mm hex bit for the front axle. 22mm hex bit for the rear axle. |
10-08-2008, 10:28 PM
#4 | ||
Oddometer: 476
Rob in Seattle
Adventure Bikes: Rivendell Saluki + Rawland rSogn |
10-08-2008, 10:40 PM
#5 |
Dakar Dazed
Oddometer: 2,386
How many?!
So what do you get in the standard tool kit?!
At that rate, it would be cheaper to buy a load of Allen-head bolts and replace them all surely?! xxx |
10-09-2008, 01:24 PM
#6 | ||
Runcible Spoon
"Another road remains, but it provides no more. It can only take us away" |
10-09-2008, 07:17 PM
#7 |
Really, Really Cool
Oddometer: 3,315
how exactly are we supposed to get the wheels off?
Where do you get the tools? Sears didnt have a jumbo-ass hex even close to that size |
10-09-2008, 10:35 PM
#8 |
Oddometer: 7
I have changed my tires to TKCs and I did not need a bigass hex. Just losen the 17mm and the small torxes at the bottom of the fork, then take the bolt out. No probs at all.
10-10-2008, 04:51 PM
#9 | |
Exposed Member
Oddometer: 1,451
http://www.motionpro.com/motorcycle/...hex_axle_tool/ This it what I use on most of the sportbikes out there. They have been that way for about 10 years or so. There are cheaper ones out there for sure, some made of steel, but this one has all the sizes I need to do tire changes in my garage with my tire machine. Hope this helps. Assfault
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you* |
10-10-2008, 05:59 PM
#10 |
Really, Really Cool
Oddometer: 3,315
guess i could have looked at the manual first.
the smaller torx bolts hold the axels tight to loosen the axel bolt, so you really don't even need the tool. |
10-10-2008, 06:47 PM
#11 | |
Oddometer: 67
http://www.sears.com/shc/s/p_10153_1...0070921x00003a and a 22mm http://www.sears.com/shc/s/p_10153_12605_00999195000P dont know if these will work or not, but they do have big ass hex keys |
10-10-2008, 06:55 PM
#12 | |
I use profanities
Oddometer: 3,914
"America is not at war. The Marine Corps is at war; America is at the mall." EVERYTHING I need to know I learned from Porn GillaFunk annual Sierra Fall Colors Ride |
10-11-2008, 08:48 PM
#13 | |
love what you do
Oddometer: 19,441
I'm seriously contemplating that. Only a matter of time until someone comes out with a nice stainless fastener kit...
Nate in N.E. Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar! ![]() They don't expect you to finish. That's why it's the Dakar. -- PPiA Get your sweet Pyndon DakARTwork here Pyndon '13
10-12-2008, 04:57 AM
#14 |
The Gov
Oddometer: 34,125
I started with a foldup torx set that covers T10 to T40 along with a T25 T handle since there are so many on my GT as well. I have always used thumbwheel ratchets and started carrying one of those with a 3" extention and the Torx sockets - compact, gets into tight places and won't let you overtighten or strip screws or screw up well nuts. Along with it I have a very small folding handle ratchet drive that has also found it's way into my tool bag.
10-12-2008, 07:20 AM
#15 |
Enjoying the moment
Oddometer: 2,448
Don't forget one of these!
![]() Ya I know, the problem has supposedly been solved........ But even the best parts can fail. Being that BMW won't give us a work around in that event, a simple component failure that isn't even neccesary can stop you stranded with no hope of restarting. This will stay with my tools on the bike (when the bike gets here). |
