Old 06-28-2010, 07:09 AM   #136
CheckerdD
CheckerdD's Avatar
Oddometer: 1,293
Is this thread still the last word on toolkits. I am thinking of pulling out the credit card and getting the kit from advdesigns. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD screwed with this post 06-28-2010 at 07:17 AM
CheckerdD is offline   Reply With Quote
Old 06-28-2010, 09:38 AM   #137
blender
Just another rider
Oddometer: 727
Originally Posted by Mikey636
I like that tool tube location. It looks like you have Jesse bags (and the mounting racks) on your bike? I was trying to figure out how to mount a tool tube on the inside of my bag mounts, however I don't seem to have the same clearance as you do. My bags sit in a bit more flush than yours.
Steve
Madison, WI
blender is offline   Reply With Quote
Old 06-28-2010, 12:16 PM   #138
Moto Mikey
Moto Mikey's Avatar
Oddometer: 450
More info here on how I mounted it:
http://www.advrider.com/forums/showp...6&postcount=42
Moto Mikey is offline   Reply With Quote
Old 06-28-2010, 12:42 PM   #139
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,946
I have the compact underseat version and it is good. It fits under the seat with room for my manual in which I have my reg/insurance.
Pretty complete kit. I have added a few things mostly because of aftermarket stuff with different size fasteners.
Oh, and here's a working link:
http://www.advdesigns.net/bmwf8ac.html
_________________________________
My Ride Reports
DolphinJohn is online now   Reply With Quote
Old 06-28-2010, 01:18 PM   #140
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
So I gotta ask. Looks like you will need an extra 13 in that kit. Chain Tensioners are both 13 size right?
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 06-28-2010, 01:33 PM   #141
DolphinJohn
Caveman
Oddometer: 3,946
13 is included. You only need one.
My Ride Reports
Old 06-28-2010, 01:47 PM   #142
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Umm... so how do you adjust the chain tensioner with only one wrench?
Old 06-28-2010, 02:01 PM   #143
DolphinJohn
Caveman
Oddometer: 3,946
One at a time??
I will have to go look as it's been a while since I looked at it but as I remember you just loosen the outer nut then the inner one adjusts the tension.
My Ride Reports
Old 06-28-2010, 02:31 PM   #144
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
One at a time??
Right but when you go to tighten the locknut you have to hold the adjuster screw so it doesn't turn. I need two 13s.
Old 06-28-2010, 02:38 PM   #145
DolphinJohn
Caveman
Oddometer: 3,946
I've never had to hold it. It shouldn't turn. it's designed to be done with one wrench, but you can carry an extra if you want.
My Ride Reports
Old 06-28-2010, 02:44 PM   #146
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Interesting. I hold it when I tighten the locknut. Hmmm....
BTW be careful people when ajusting your chain. The left side (disc brake side) doesn't like to stay snugged up. I often find that when tightening the axel bolt the adjuster bolt often is a small space from the adjuster block.
The trick I use is that once I get the chain tension correct and the adjusters tightened up I grab a screw driver and roll it back in between the chain and sprocket. The extra tension on the chain holds the disc side snugged up.
Old 06-28-2010, 02:52 PM   #147
itsforrest
Ugly bag of mostly water
itsforrest's Avatar
Oddometer: 330
The bolt may turn a bit when tightening the lock nut but not enough to worry about. Adjusting the chain isn't like adjusting valve lash where a couple thousandths makes a difference.
The urge to buy terrorizes.
itsforrest is offline   Reply With Quote
Old 06-28-2010, 09:14 PM   #148
Maniac28
Maniac28's Avatar
Oddometer: 399
Good thread. I thought about putting one together myself... but it was so easy to just click and order the adv-design kit. I'm lazy I guess. And it comes with pouches and all fits under the seat. How awesome is that. Nice product, and the tools are decent, too. Not cheap crap.
Highly reccomended.
Also, you can fit motion pro t6 levers between the frame and gas tank under the seat. they slide in there and stay put. now all my tools except stuff like spare tube, etc, are under the seat. Even put CO2 and other stuff in the compartment underneath my sargent seat.
Ian S.
2014 500EXC - 2004 KLR650
Maniac28 is offline   Reply With Quote
Old 06-30-2010, 06:52 PM   #149
LilDirtRat
Oddometer: 256
tools under seat
I can't remember who suggested/did this, but props to that guy, cuz this is the shit..
Just cut the damn tabs off of the "first aid kit" spot, thread in some velcro cable ties, & blamo.. under seat storage for your tools. I also stuffed another little bag at the back of the seat cavity with some glow sticks, duct tape, zip ties etc.. it takes just a little shimmy-ing to get the seat back on, but it works just fine and all that shit is stowed away!
"Ignorance is bliss, but then there's Murphy and his damn law"
LilDirtRat screwed with this post 06-30-2010 at 08:14 PM
LilDirtRat is offline   Reply With Quote
Old 07-01-2010, 01:18 AM   #150
Soundboi
Ninja Style
Soundboi's Avatar
Oddometer: 7
I have the Adventure Designs kit its pretty complete needed to add a tube valve puller and 2 tire irons. O ja and a size 5 and 6 allen hex key and a size 10 open ended wrench for loosening the crash bars.
IF YOU DON'T FALL... YOUR NOT RIDING HARD ENOUGH
Soundboi is offline   Reply With Quote
Times are GMT -7.   It's 08:07 PM.
