Old 07-01-2010, 06:37 AM   #151
Pomo
gonzo
Pomo's Avatar
Oddometer: 611
Originally Posted by Gangplank
Interesting. I hold it when I tighten the locknut. Hmmm....
BTW be careful people when ajusting your chain. The left side (disc brake side) doesn't like to stay snugged up. I often find that when tightening the axel bolt the adjuster bolt often is a small space from the adjuster block.
The trick I use is that once I get the chain tension correct and the adjusters tightened up I grab a screw driver and roll it back in between the chain and sprocket. The extra tension on the chain holds the disc side snugged up.
I've also never had to use more than one wrench to get it tight. The adjustment bolt doesn't turn more than 1/4, if at all. A little pinch with your fingers should do the trick.
As for the disc side gap, I just give the tire a few swift kicks while sitting on the ground behind the bike. Same thing happens on a cam adjustment rear wheel.
Stubborn and Stupid
"It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way." ~ Rubin, Road Trip
Pomo is offline   Reply With Quote
Old 07-12-2010, 01:16 PM   #152
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Updated my kit after this last trip:
Here is my kit as I will be adding to it after this trip.
Heavy Duty Tool Roll or tool bag
Driver bit kit & driver
Screw driver with bit adapter end & drive screw driver bits
11 Piece Torx Bits (T8, T10, T20, T25, T30, T40, T45, T55)
E8 external (gear shift lever), E10 handlebar clamps, E12 Front Caliper brakes
Metric Box Wrenches
10 mm wrench (I believe this is the size valve stem nut, brake bleed nut, motor bolts
13mm (x2 for chain tension but I think you only need one)
17mm (front axle)
Ratchet - 3/8" and "
5x Metric 6-Point Sockets (8, 10, 13, 17, 24)
Spark Plug Socket 5/8
3/8" to 1/2" driver adapter / Drives 24mm socket
3/8 to 1/4 driver adapter / Drives small sockets
3 & 6 extension
Other Repair Stuff
Black zip ties / misc. hose and fastener repairs
Duct tape (mini roll)
Black electrical tape
3 levers - two regular and a big one
Patch kit/tube & RU Glide (or chapstick works)
Set of rim protectors made from an old shampoo bottle
Valve core tool
Front and rear tubes (can you run a front tube in the rear? Maybe carry two fronts...)
Pump & Pressure Gauge
Locktite blue
Magnet
3 feet of stainless steel wire
Oil Filter Wrench
Rag
LED lamp MINI light
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 07-23-2010, 12:48 PM   #153
ride2little
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,938
Originally Posted by AMERUS
bit confused on the spanner front, have put my kit together myself and have noticed diferences in the ones on sale
I have in my kit 8,10,12,13,17
Cruztools kit has 8,10,12,13
Adventure designs has 8,11,12,13,17
do I now need a size 11 spanner and can I get rid of the 10 or should I have both or neither
anyone used these two sizes on the bike ?
Not really sure. But you might as well carry the 8, 10, 11, 12 and 13. (I just bought the 17/24 axle wrench mentioned on here.). I suspect 11 is more popular on our bike, but my 10mm wrench has been the most popular one used by far, generally speaking (not on the bike).
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is offline   Reply With Quote
Old 07-23-2010, 01:01 PM   #154
ride2little
Oddometer: 1,938
Thumb Wadsworth Mini Ratchet Set
as for tool kits, I bought this one (years ago) to get in the nooks and cranny's of previous bikes. And it's one of my most used kits. Its good for all but the big stuff, such as tire changes.
Wadsworth Mini Ratchet. The link is an example from a specific seller, but you can search and some will pop up.
VERY durable, very versatile and has everything I have needed so-far (hex, torx and screw driver. Even has a 1/4" adapter for sockets (sockets not included). Comes in a case which fits under the seat where the Canbus terminates.
Contains:
  • 3 tools, 44 bits, 3 removable bit caddies (yellow for metric bits)
  • Stainless steel drive handle with 12 degree ratching action
  • Ratchet extension
  • Bit end cap for thumb pressure
  • 12" hex bits: 0.50", 1/16", 5/64" 3/32", 7/64", 1/8", 9/64", 5/32", 3/16", 7/32", 1/4", 5/16"
  • 8 metric hex bits: 1.5mm, 2mm, 2.5mm, 3mm, 4mm, 5mm, 6mm
  • 9 slotted screw bits: No. 0 through-4, 5, 8, 10-1/4
  • Phillips bits: P0, P1, P2, P3, P4
  • 8 "6 Spline: bits: T9, T10, T15, T20, T25, T27, T30, T40
  • Reed & Prince bit: 1/4", 1/4" socket adapter
Lifetime warranty (USA)
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
Old 07-23-2010, 02:39 PM   #155
ride2little
Oddometer: 1,938
Wrench Socks
Okay, just ONE more thing.
I made some anti-clinging devices .
See below.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
Old 07-23-2010, 02:56 PM   #156
yellow zebra
yellow zebra's Avatar
Oddometer: 138
anti-CLINGing devices
OR
anti-CLANGing devices???!
coiner of the phrase: Parallel Universe!
yellow zebra is offline   Reply With Quote
Old 07-23-2010, 03:34 PM   #157
AlanI
Oddometer: 201
This thread makes for an interesting, if not confusing, read. So many variables and quite a lot of personal preferences - it's a minefield of information. However, what I haven't come across as yet is any mention of the contents of BMW's optional tool-kit. Yes I know it's pricey - what BMW item isn't - but does anyone actually own one, can list what's included and is it as comprehensive as the ADVdesigns offering?
AlanI is offline   Reply With Quote
Old 07-23-2010, 05:20 PM   #158
The Texican
n00bish
The Texican's Avatar
Oddometer: 17
OR
Silly....he doesn't want them to "cling" when he removes them from the dryer.
The Texican
09 BMW F800GS
08 Yamaha XT250
Colt - The first point and click interface.
The Texican is offline   Reply With Quote
Old 07-23-2010, 05:30 PM   #159
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,684
Clanr to cling
No...this way you have a spare tube as well....just bring extra glue!
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 08-17-2010, 08:23 PM   #160
selecus
selecus's Avatar
Oddometer: 80
Full credit to Pete O Static....
This was a fantastic idea; I did the same as Pete, surprised how much i could stow under the seat.....works brilliant, thanks bud, well done! I used a couple things I had laying around but bought just about everything at princessauto.com. I have a few exess bits here; the pic is also missing my tire irons, tube patches and loctite...but hey, it all fits easily...total came to about $35 CAN, not bad....
selecus screwed with this post 08-17-2010 at 08:58 PM
selecus is offline   Reply With Quote
Old 08-18-2010, 08:37 AM   #161
tipler
tipler's Avatar
Oddometer: 92
Great set up!
Here's one thing I always carry and it gets used a lot: Magnetic Pick Up Pen.
As the name suggests, it takes up vitrually no space and is really handy to have around, especially at night for some reason. Good for everything from pulling the wrenches/sockets out of the places I've stored/wedged them, to getting at that dam bolt you just dropped into that impossible to access place.
$1.00-ish at Princess Auto
tipler is offline   Reply With Quote
Old 12-06-2010, 09:20 PM   #162
Effisland
Effisland's Avatar
Oddometer: 266
Originally Posted by itsatdm View Post
The 800 fasteners are just about all Torx vs hex or Allenhead.
So to work on the bike you need the following:
snip
24mm Drain plug.
My oil plug sure looks like a torx. Maybe you are talking about an older model? I am trying to figure out what # torx it is......
2010 BMW F800GS
Effisland is offline   Reply With Quote
Old 12-06-2010, 09:45 PM   #163
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
Thumb Ya mon
Originally Posted by tipler View Post
Great set up!
+100 I use mine all the time.
__Clum Z.
Bucko is offline   Reply With Quote
Old 12-09-2010, 11:10 PM   #164
DolphinJohn
Caveman
DolphinJohn's Avatar
Oddometer: 3,934
I don't think it's a torx, unless they made a major change.
The oil drain on these bikes is on the side of the engine on the port side, not underneath.
(at least it is on my '09, and I haven't heard mention of a change).
_________________________________
My Ride Reports
DolphinJohn is offline   Reply With Quote
Old 12-10-2010, 07:45 AM   #165
Motoriley
Motoriley's Avatar
Oddometer: 2,684
Over torxed
I heard that there is a new part number since the old 24mm were prone to stripping. Can anyone confirm that?
Times are GMT -7.   It's 05:07 AM.
