Old 08-31-2010, 12:34 AM   #136
Xskydiver
Xskydiver's Avatar
Oddometer: 256
After having a "no start" problem from a vacuum line coming off the canister I decided to bite the bullet and pull the whole thing off. After reading everything I could find about it I pulled the canister and capped off the electronic valve. Then I decided to see if I even needed to keep the valve. I unplugged it from the harness and the bike fired right up. There was no service light or any other indication it was unplugged. I removed the valve and capped the T fitting between the throttle bodies. There was a nice little rubber band type wire tie right near the harness plug so I put the plug into it to keep it from flopping around. As for the vent line, routing it to the bottom of the bike where it will go under water on a regular basis seemed dumb considering that it sucks air into the fuel tank. I unplugged the long section of hose and just left the check valve tied to the subframe where it was. I figured having it inside the plastic will keep it reasonably clean and dry unless the whole bike goes under in which case I will have bigger problems.
Xskydiver screwed with this post 12-05-2010 at 01:43 PM
Xskydiver is offline   Reply With Quote
Old 03-28-2012, 03:41 PM   #137
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,485
Laugh how to remove!!
http://www.advrider.com/forums/showthread.php?t=500968
my pictures shows the flow direction wrong... the check will stop a vacuum (free flow to tank) from occurring but will allow a 5 psi pressure buildup (out from tank is limited).
Before:
AFTER......
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass screwed with this post 08-28-2012 at 06:16 PM
HighTechCoonass is offline   Reply With Quote
Old 05-24-2012, 05:58 AM   #138
JRWooden
Oddometer: 4,249
I had a chance to look at an F800R the other day ....
If this bike has a canister it is certainly not in the same location... it's tucked up under the seat or somewhere ...
I only had a couple of minutes to look before the guy that owned it came back and he was late so didn't have time to dink around ...........
Old 08-25-2012, 09:13 PM   #139
petzi-baer
Oddometer: 184
It's gone or moved on the 2013 gs as well
Petzi baer
petzi-baer is offline   Reply With Quote
Old 08-25-2012, 11:28 PM   #140
itsatdm
itsatdm's Avatar
Oddometer: 4,859
Anybody see a US version? We are the only ones that have them.
Old 08-25-2012, 11:35 PM   #141
JRWooden
Oddometer: 4,249
Take a look here: http://www.webbikeworld.com/BMW-moto...s/bmw-f-800-r/
scroll all the way down to the "comments" section.
The new F700GS and F800GS may have a diminished fuel capacity..............
We need someone with a new bike to pop off the seat and see what's there .............
I have not paid attention to the published fuel capacity of the new models ... is it different?
Old 08-25-2012, 11:51 PM   #142
itsatdm
itsatdm's Avatar
Oddometer: 4,859
Could be I guess, though on our bikes the canister does not intrude on the tank size. The R version canister is located differently and I don't know the tank size of the older US models.
Maybe all that new and improved stuff increase the mileage
Old 08-26-2012, 09:12 AM   #143
JRWooden
Oddometer: 4,249
Yeah... that's the ticket ... 80mpg...
I wonder if the new GS have "adopted" the tank from the R model?
Even if true, that canister does not seem like it would displace more than a quart of fuel at the most ....
Old 10-05-2013, 06:37 PM   #144
Full Power
Oddometer: 1,472
With regard to the 2013 model F800gs:
CharcoalCanister looks to be about 20 fluid ounces in volume. black plastic can, one 8mm drain port at bottom one each 6mm and 8mm top ports.
The entire motorcycle seems to have been built up around the charcoal can. It is at the approximate center point of the bike, and seems to be unremovable, although it occupies the PERFECT spot for a large canister style fuel filter.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Times are GMT -7.   It's 12:29 PM.
