Old 10-06-2008, 05:39 PM   #1
mookymoo OP
Mookish Mook
Oddometer: 4,396
Stretching the KTM 690 Enduro
A few are starting to pop up near where I am on the 2nd hand market for quite low prices.... I took one for a brief test-ride which re-kindled my desire to replace my XR250 (its way too small for me).
So, the only gripe I had was Id really like it to be a few inches taller. I can achieve some of that extra height via the seat, but what I am curious about is how much is there to be had in lengthening the suspension?
Has anyone tried?
mookymoo screwed with this post 11-11-2008 at 01:24 PM
mookymoo is offline   Reply With Quote
Old 10-06-2008, 07:29 PM   #2
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,135
You will get 300mm out the fork with no drama ( apart form paying for it )
the read may be a bit harder as you have a couple of options
with lever ratio's on the linkages and extending the shock , which eve way it will need a revalve, and the rear master cylider might get in the way
Mudguts screwed with this post 10-06-2008 at 07:37 PM
Mudguts is offline   Reply With Quote
Old 10-06-2008, 08:53 PM   #3
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,312
you can only get it to 275 mm ,the master cyl get in the way ,for the forks you need a new dampening rod for make theme 275 or 300 mm
trailtrick is offline   Reply With Quote
Old 10-07-2008, 08:23 AM   #4
Lumpyboy
Oddometer: 33
No complaints from me on the steering sweep. Just like older KTMs really (my '05 200 is similar). No big deal.
Send your suspension to Javier (Trail Trick). He'll fix it up good for you.
Current bikes: '10 KTM 200 XCW, '10 KTM 690 Duke, '08 KTM 690E, '07 WR450 supermoto and dirt trims (street legal)
Recent bikes: '09 KTM 400 XCW, '08 YZ450 supermoto, '05 CR500AF, '05 BMW F650 Dakar (wife's), '05 KTM 200 EXC, '05 KTM 400 EXC, '06 RM250, etc.
Lumpyboy is offline   Reply With Quote
Old 10-07-2008, 10:10 AM   #5
pete40
Life Behind Bars
pete40's Avatar
Oddometer: 1,313
You reckon? I think the amount of steering lock sucks big time. All my other KTMs have heaps more than this piss poor effort. It catches me out every time I jump on it after just getting off something else.
pete40 is offline   Reply With Quote
Old 10-07-2008, 10:48 AM   #6
WoovsHoovs
RUN SILENT
WoovsHoovs's Avatar
Oddometer: 3,830
Javier??
Hola!!!!!!!!
WoovsHoovs is offline   Reply With Quote
Old 10-07-2008, 10:49 AM   #7
WoovsHoovs
RUN SILENT
WoovsHoovs's Avatar
Oddometer: 3,830
No adjustment?
or do like I did on old KX's and file the stops for woods work-careful of interference though
Old 10-07-2008, 11:22 AM   #8
Lumpyboy
Oddometer: 33
You reckon?
I do. Definitely no real difference compared to my '05 200 EXC. My '07 SX bikes clearly turn much better. But, other than when turning around on dead end trails, I really don't notice much to be honest. YMMV.
Old 10-07-2008, 11:56 AM   #9
mookymoo OP
Mookish Mook
Oddometer: 4,396
There isnt much to discuss about the steering lock (I regret mentioning it now).
My main question is about the height & suspension (as a means to achieve that height)...
Old 10-07-2008, 11:59 AM   #10
mookymoo OP
Mookish Mook
Oddometer: 4,396
Thanks for that info
Will have to have a look to see what you mean regarding the master cylinder... but I believe you. I guess its no coincidence the new 690ER is 275mm...
Old 10-07-2008, 12:05 PM   #11
mookymoo OP
Mookish Mook
Oddometer: 4,396
Ouch. I see what you mean.
Bugger.
Old 11-08-2008, 04:00 AM   #12
DirtJack
DirtJack's Avatar
Oddometer: 1,606
Javier,
Would it be possible to make a 25 mm or 50 mm threaded extension to the dampening rod to allow extension of the forks to 275 or 300 mm?
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 11-08-2008, 06:14 AM   #13
mookymoo OP
Mookish Mook
Oddometer: 4,396
From what I can see, though, the 690 Rally has the master cylinder in the same place?
Old 11-08-2008, 07:06 AM   #14
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Ever ridden a snow machine? Hmmmmm.......
Just say'IN
crankshaft is offline   Reply With Quote
Old 11-08-2008, 08:57 AM   #15
mookymoo OP
Mookish Mook
Oddometer: 4,396
Ahem ....
Times are GMT -7.   It's 06:55 PM.
