Old 10-08-2008, 11:48 PM   #1
Guy Jinbaiquerre OP
Monorail Conductor
Guy Jinbaiquerre's Avatar
Oddometer: 1,222
Question Ground clearance on F650/800GS?
I have checked the BMW site as well as Google to no avail, so here goes:
Does anyone know the ground clearance, using normal-height suspension settings, of the F650GS (parallel twin version) and F800GS?
IBA # 42657
96 Honda XR250 Baja
09 BMW R1200GS Adventure ・ 09 KTM 990 SMT (sold) ・ 97 Honda X4 ・ 95 Kawasaki ZZR400 (sold)
Guy Jinbaiquerre is offline   Reply With Quote
Old 10-09-2008, 01:47 AM   #2
PuraVida
Oddometer: 33
I couldn't find any clearance specs either on my F650 when it arrived, so I measured:
Unsprung: 24cm (9.4")
Settled under its own weight and panniers: 19.5 cm (7.7")
The 800's seat is 6cm (2.4") higher with an identical frame, so you can probably add that to the 650's dimensions for reasonably accurate clearance measurements.
PuraVida is offline   Reply With Quote
Old 10-09-2008, 10:28 AM   #3
levity
nano-Adventurer
levity's Avatar
Oddometer: 1,088
Originally Posted by PuraVida
... Settled under its own weight and panniers: 19.5 cm (7.7") ...
PuraVida's # is about right. Here's what a buddy measuered on his F650GS with the MoTech skidplate, unladen (~7.5"):
My F800GS sits about one inch higher to the BMW skidplate (unladen; minimal preload to set 30% rear sag = 2.6"; forks raised 5mm).
Yes, the 800 has ~1.8" more travel but some of this (~0.5") is lost in setting sag, some raising the forks.
levity is offline   Reply With Quote
Old 10-09-2008, 06:03 PM   #4
Navaho
Navaho's Avatar
Oddometer: 1,043
Measured my F650twin today - 8". Same clearance as an '08 KLR650.
I did a comparison recently for the thumper crowd:
Wet Weights:
2005 KLR650 = 413#
2008 KLR650 = 428#
2009 F650GS = 438#
2007 DR650 = 367#
Suspension Travel:
2007 KLR650 = 9.1/9.1
2008 KLR650 = 7.3/7.9
2009 F650GS = 6.7/7.1
2007 DR650 = 10.2/10.2
Ground Clearance:
2007 KLR650 = 9.4"
2008 KLR650 = 8"
2009 F650GS = 8"
2007 DR650 = 10.4
Navaho screwed with this post 10-09-2008 at 06:15 PM
Navaho is offline   Reply With Quote
Times are GMT -7.   It's 05:03 AM.
