Old 10-10-2008, 09:15 AM   #1
Kbike OP
Mountain Adventurer
Kbike's Avatar
Oddometer: 235
How to weigh your motorcycle
An easy way to get a fairly accurate weight is grab your bathroom scale, don't tell the wife, and roll the rear wheel up on it, then the front, and add the two weights for the total. To protect the scale use a 2x6 to roll the bike up on first, then onto the scale.
My KLR weighs 230 on the rear
and 185 on the front for a total of 415, and my WR450 is 259 total. Close enough for anything I need to do.
http://kbike.smugmug.com
KTM525EXC, KTM990, WR450F, WR250X
Kbike is offline   Reply With Quote
Old 10-10-2008, 11:11 AM   #2
Lumpyboy
Oddometer: 19
? No way that will be close to accurate -- one tire on the scale and one on the ground, and then switching. Simply too much weight in the middle of the bike will be unaccounted for.
Better way is to put your scale on top of a lift stand or jack and then lift the entire bike up on the stand.
Current bikes: '10 KTM 200 XCW, '10 KTM 690 Duke, '08 KTM 690E, '07 WR450 supermoto and dirt trims (street legal)
Recent bikes: '09 KTM 400 XCW, '08 YZ450 supermoto, '05 CR500AF, '05 BMW F650 Dakar (wife's), '05 KTM 200 EXC, '05 KTM 400 EXC, '06 RM250, etc.
Lumpyboy is offline   Reply With Quote
Old 10-10-2008, 11:16 AM   #3
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 1,702
It will work, with good accuracy. They weight big trucks and aircraft like this all the time.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 10-10-2008, 11:49 AM   #4
threadkiller
threadkiller's Avatar
Oddometer: 1,367
LMAO!!!!!
threadkiller is offline   Reply With Quote
Old 10-10-2008, 12:37 PM   #5
webhank
Oddometer: 29
my way
i like to weigh myself on the bathroom scale and take note of my weight - then pick up the bike, hold it over my head, take note of that weight, then subtract my weight from the combined weight of me and the bike.
i am wicked strong.
Sorry, couldn't resist.
You could also go to a materials yard, around here they have them for landscaping materials etc - they have large drive on scales that will weigh the whole bike at once.
webhank is offline   Reply With Quote
Old 10-10-2008, 01:01 PM   #6
jeiff
Oddometer: 224
So where would the "weight in the middle" be borne when both wheels are on the ground?
Kbike's method works. But the wheel that is not on the scale should probably be leveled up to the scale height for better accuracy.
Joe
jeiff is offline   Reply With Quote
Old 10-10-2008, 01:02 PM   #7
Hamon
I just like riding
Oddometer: 272
Man, don't you get it? The problem with this method is you have all the weight of the tires, wheels, and suspension underneath the horizontal line that is the top of the scale that will never get weighed..
Some people think they're physics majors or something..
Two wheels and half a brain.
http://advrider.com/forums/showthread.php?t=355243 <- BC to ON and back: KLR650
http://advrider.com/forums/showthread.php?t=485653 <- Inuvik 09: KLR650 and DRZ chronicle
http://advrider.com/forums/showthread.php?t=762691 <- 3 months of moto fantasticity
Hamon is offline   Reply With Quote
Old 10-10-2008, 01:48 PM   #8
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,645
Sheesh, if you're THAT concerned about accuracy, just do a stoppie that comes to rest on the scale.
It takes a little practice.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 10-10-2008, 02:25 PM   #9
Lumpyboy
Oddometer: 19
The one scale method usually isn't that accurate b/c people are not careful enough to make sure that the weight of each end of the bike is transmitted to the middle of the scale and not the edge of the scale as each end is weighed (the comment above about leveling up is important). That was my point. Only accurate way to do it is to slip the scale onto your bike stand. And in addition, bathroom scales are often not accurate if that's what your using. Best to use a shipping or medical scale.
Old 10-10-2008, 02:36 PM   #10
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 2,606
thats like weighing yourself one foot at a time & adding it up
i'm under 20 lbs
plugeye is offline   Reply With Quote
Old 10-10-2008, 02:44 PM   #11
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,352
i'm under 20 lbs
no it isn't. You can controll how much weight you put on one foot by shifting your body. The bike can't, it's a rigid system. This method is accurate, even without leveling the other end. The amount of weight shifted by being out of level that little bit is negligible.
Bathroom scales are accurate enough for this. Just make sure the wheel is in the center of the scale. If it's accurate enough to weigh you, it's accurate enough to weigh a bike.
Many bathroom scales have a 250-300lb max though, so if you think the bike will weigh over 550lbs or so, I would suggest trying another method.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx
You can be Han Solo, and I can be another Han Solo...
Old 10-10-2008, 03:16 PM   #12
dentvet
Oddometer: 997
more questions than answers
this is fun.
1. two bikes weigh 300# each, one is a short cruiser, one is a tall dirt bike. lay them both over and put the handlebar end on the bathroom scale. Which is heavier, which is easier to pick up?
2. put a sealed box with a pound of flies on your luggage rack. Start the engine to disturb them, making them all fly around inside the box. weigh bike. As the flies die and fall to the bottom of the box, does the bike get heavier or lighter?
not trying to hijack a thread with a good description of a handy technique. sorry
(I'm thinking the handlebar weight might actually be a useful piece of info)
dentvet is offline   Reply With Quote
Old 10-10-2008, 03:24 PM   #13
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 3,942
[quote=dentvet
2. put a sealed box with a pound of flies on your luggage rack. Start the engine to disturb them, making them all fly around inside the box. weigh bike. As the flies die and fall to the bottom of the box, does the bike get heavier or lighter?/quote]
This was a problem brought before me & my fellow students in grade nine, only it was a cargo van full of 1000 pounds worth of chickens. At the weight station, the driver would get out & beat the sides of the van with a club, causing the chickens to fly around so he could cheat the scales. So did it weigh less? LMAO
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is offline   Reply With Quote
Old 10-10-2008, 03:59 PM   #14
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,352
What do you know about leverage?
Old 10-10-2008, 04:02 PM   #15
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,352
As sealed box will stay the same weight. A box with a mesh floor and lid will get heavier as the flies die.
Times are GMT -7.   It's 10:39 PM.
