Old 10-29-2008, 04:25 PM   #76
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,390
Originally Posted by FINNDIAN
looks like the 140 is street legal.
MFE 99 SUPER EXPLORER
bis 170 km/h - Das Langstrecken- Profi mit Einsatzschwerpunkt Straße, leichtes Gelände und Schotterpisten. Sicheres Fahrverhalten und hohe Kilometerleistung runden seine Vielseitigkeit ab.
Dimension /mmInchLoad/Speed Index
140/80-1870 R
150/70-1870 R NHS
NHS = (not for higway use)
Keine Straßenzulassung
Congradulations,
Pic from 5 minutes ago !
"The BSC was strong in that one, had to get out !"
dlrides is offline   Reply With Quote
Old 10-29-2008, 04:27 PM   #77
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,390
Originally Posted by DakarBlues
WHere can I procure this tire (front and rear) in the U.S.
it reminds me the Metzeler Sahara but with a more convincing tread pattern.
If the walls are strong, then it would be a winner since this is the main grievance against Metzeler Sahara.
THanks
Not a Heindenau !
Old 10-29-2008, 04:29 PM   #78
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,390
Originally Posted by JOKER650
MEFO 99 Explorer Rear Tire
  • Great gravel and road tires
  • Long wearing
  • Handles well on paved roads
  • Rated top speed 118 MPH (190 KPH)
  • Dot and E Code Approved
Old 10-29-2008, 04:56 PM   #79
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,705
I think some people may actually still be trying to add something constructive to this thread, not just play your silly guess the tire game.
Mixing gas and haulin' ass.
Matchmaker of Homes and People
traveltoad is offline   Reply With Quote
Old 10-29-2008, 05:52 PM   #80
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,390
Old 10-29-2008, 06:10 PM   #81
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Originally Posted by dlrides
i'd have to agree with traveltoad, its getting old mate.
though its not a tyre that interests me, the D908RR is the ultimate IMO.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 10-29-2008, 06:54 PM   #82
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,705
Right back at you. Go start your own thread and let this one continue as it was intended.
Old 10-29-2008, 07:18 PM   #83
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,390
Just pulling some chains, calm down !
Tire threads are like oil threads, what works for one, may not work for another. The type of riding determines the tire. Most 950's have approximately a 4.25 width rim (except 04-05), so the 140 cross section tire on the wider rims, do not perform well on twisty pavement. That leaves terrain type, choose what suits your riding.
Old 10-29-2008, 07:35 PM   #84
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 2,300
and the tire is......
Florida Lime is offline   Reply With Quote
Old 10-29-2008, 07:49 PM   #85
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,390
Old 10-29-2008, 07:51 PM   #86
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Sounds like he wants to keep them to himself.
Moving along...
Old 10-29-2008, 08:38 PM   #87
Soronery
Soronery's Avatar
Oddometer: 16
Yanks!
Yep, a 140/80 tire molded and designed for a 2.5 rim is going to work really great stretched out on a 4.25 rim. Uh-huh. Unless you want to turn, only problem. Put a SE rear wheel on with a high side profile dirt tire and itll work as designed. ALOT of bad advice here in this thread. MT-21s, Deserts, etc. These dirt tires are made for 2.15 to 2. rims. Just WTF are you thinking? You will have NO corner. These tires will spread out like holy crap on that wide stock rim. 950 rear is made for a low profile rear tire and only 3 I know of will fit properly. Conti TKC-80, Scorps, and ?????????????? Made by Heidenau at the behest of us over at LC8.org Weve been begging them for some time to make this size yet its oddly still not available over here. It will be sold as a K60 Heidenau once it makes our market.
Soronery screwed with this post 11-05-2008 at 06:59 AM
Soronery is offline   Reply With Quote
Old 10-29-2008, 08:44 PM   #88
dlrides
1:1.618
dlrides's Avatar
Oddometer: 5,390
Originally Posted by Soronery
Yep, a 140/80 tire molded and designed for a 2.5\\\\\\\" rim is going to work really great stretched out on a 4.25\\\\\\\" rim. Uh-huh. Unless you want to turn, only problem. Put a SE rear wheel on with a high side profile dirt tire and it\\\\\\\'ll work as designed. ALOT of bad advice here in this thread. MT-21s, Deserts, etc. These dirt tires are made for 2.15 to 2.5\\\\\\\" rims. Just WTF are you yanks thinking? You will have NO corner. These tires will spread out like holy crap on that wide stock rim. 950 rear is made for a low profile rear tire and only 3 I know of will fit properly.
+ 1
Old 10-29-2008, 08:46 PM   #89
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Old 10-30-2008, 02:27 AM   #90
Grumpy old Man OP
Grumpy old Man's Avatar
Oddometer: 293
May I ask, who started this Tread and what did he try to intend?
I guess the Author had certainly NOT intendet a discussion board about pro and contras of Tires for the LC8 or even be rude to each other. I guess he simply wanted to puit a summary together with all the Tires there are for the LC8. I also guess, that to discuss them, he was thinking, that the users, or whatever you wannw call them, will have the sence to take out the Infos they need and then open a new tread to discuss the tire there intrested in.
Hey , but what do I know? Im only guessing...
Dualsport>Adventure>Touring>Testcenter - Get the Best at MMD ADVENTURES SWITZERLAND
KLiM Technical Riding Gear / KRIEGA / ENDURISTAN and lots more.
Grumpy old Man is offline   Reply With Quote
Times are GMT -7.   It's 02:17 AM.
