Old 10-14-2008, 08:09 AM   #1
CrazyMike OP
***42***
CrazyMike's Avatar
Oddometer: 929
F800GS/F650GS Electrical System Capabilities
First of all....I am not an electrical engineer, but I like to think that I have a basic understanding of how electrical systems work.
There are several small discussions out there regarding the capacity of the BMW F800/F650GS electrical system and my goal here is to draw those discussions into one thread. Hopefully, this will create a single thread that describes current (read amperage) capabilities of the accessory plugs (a known trait of the BMW CanBus system), the available room to add accessories, and the capabilities to increase the available capacity of the system (either through aftermarket/optional alternators, alternator modifications, or reducing the draw of the standard systems).
The motorcycles currently have 400W alternator. (I expect the alternator size to grow over the next few years just as it has on other BMW models. Hopefully, those alternators will be direct bolt-on replacements for the current alternator.)
Questions:
  • Does anyone know what the standard system draws? (Obviously this will be affected by a couple of the features on each motorcycle; ABS and heated grips.)
  • What capacity is available to add accessories such as additional lighting, heated accessories, etc.?
  • Can we increase the available capacity of the system by upgrading to HID lights or other methods, thereby reducing the lighting draw and increasing overall capacity?
  • Is it possible to have a motor shop rewind the alternator to increase the alternator output?
  • Can someone provide the allowable current capacities of the accessory plugs (the BMW plug next to the ignition, the GPS pigtail and the alarm system pigtail)?
Obviously, there will be other questions so please ask at will.
I ride year round and want to make certain that the accessories that I run will not overload the electrical system of the motorcycle. If the total does overload the system, what combinations can I run to prevent overloading the system?
The accessories I am or want to run are:
  • GPS (Garmin Zumo)
  • Heated clothing (currently Gerbrings jacket and G3 gloves)
  • Additional front lighting (TBD)
  • Additional rear lighting (Dual-function 16 LED Hyper-Lites)
The accessories my F800GS has are:
  • Heated Grips
  • ABS
LET ‘ER RIP!!!
Mike
1999 BMW R1200C
2009 BMW F800GS
WANTED: Kawasaki ZRX 1200R
CrazyMike is online now   Reply With Quote
Old 10-15-2008, 04:24 AM   #2
JRWooden
Oddometer: 4,289
Hmmmmmmmm I don't know either.... one thing I have heard is that the standard DIN plug on top of the tank is limited to 5 amps (70 watts or so) at which point the CANBus shuts off power -- so most heated clothing might (?) have to be connected via alternate means....
The aftermarket grips seem to be roughly 35W .... so that might be a good working number for the factory grips as well...
Some of the clothing could draw big wattage ... very dependent on details it appears...
You could try "working backwards" and see if you could stay under say a 300W "budget" ... I can't imagine that the bike its self uses more than 100W not counting the heated grips??? (that's a guess) ;-)
Jim
JRWooden screwed with this post 10-15-2008 at 05:05 AM
Old 10-15-2008, 07:23 AM   #3
MonsterJ
I have motopsychosis
Oddometer: 262
400W doesn't sound like a whole lot to me. What was BMW thinking? I'm kind of curious to see what the bike pulls in stock form as well. When I get some time this winter I'm going to use some equipment from work to determine total draw. I'll post up my findings when I do.
FWIW, here's a couple formulas to help figure out current and power.
E = I x R
P = I x E
E = Voltage, I = Amperage, R = Resistance, P = Watts
-Nooner
Temple, TX -> Cape May, NJ -> Mobile, AL -> ECity, NC -> Kodiak, AK -> Mobile, AL -> Sacto, CA -> Cape Cod, MA -> New London, CT -> San Francisco, CA -> Juneau, AK (summer of '13) -> where to next?
MonsterJ is offline   Reply With Quote
Old 10-15-2008, 10:11 AM   #4
robhar54
robhar54's Avatar
Oddometer: 476
That is true. I just ordered one of these from Powerlet Products. It's a replacement for the CAN-BUS-powered outlet next to the ignition. You use the same hole, and it gets wired directly to the battery.
http://www.powerletproducts.com/shop...kit-12/164/690
I'm also going run an PKT-001-48 SAE cord...
http://www.powerletproducts.com/prod...uty-15-amp/107
...back from the battery to under the back part of the seat, and tap one of these into my panniers, for charging stuff:
http://www.powerletproducts.com/prod...connector/286/
Rob in Seattle
Adventure Bikes: Rivendell Saluki + Rawland rSogn
robhar54 is offline   Reply With Quote
Old 10-15-2008, 11:43 AM   #5
CrazyMike OP
***42***
CrazyMike's Avatar
Oddometer: 929
Thumb Lo and behold
Believe it or not, our MOM does tell us the wattage requirements of some of the components on the motorcycle:
Page 129 confirms the electrical rating of the onboard socket is 5A.
Page 130 details the wattages for the bulbs. If my math is correct, the motorcycle lighting system consumes 115 watts of power with the high beam on and 60 watts with the high beam off. Turnsignals consume 20 watts (10 front/10 rear) unless you are running LED turn signals.
So what does the rest of the CanBus consume? ABS? Heated Grips?
Mike
1999 BMW R1200C
2009 BMW F800GS
Old 10-15-2008, 11:59 AM   #6
CrazyMike OP
***42***
CrazyMike's Avatar
Oddometer: 929
Rob, I like your ideas.
I received my Centech AP-1 fuse block today. Anyone out there have any good pics of their AP-1 installation on their F800/650twinGS? My immediate plan for the fuse block is to supply power for my heated clothing (gloves - 27 watts, jacket liner - 77 watts) ...once the weather gets cooler. Eventually, I plan to add aux lighting.
Still trying to figure out what the system can handle....
Mike
1999 BMW R1200C
2009 BMW F800GS
Old 10-15-2008, 01:21 PM   #7
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,394
Maybe someone can tell me if the following is a silly solution to that question:
I had planned to purchase and install a voltage meter before a single electrical farkle was installed. I'm thinking of something similar to that shown below, but maybe not so fancy. My theory was that if the alternator was not able to keep up with power demand as accessories were added, the voltage meter would show a value less than that shown when no accesories were installed.
Granted, this won't tell you the answer until you've exceeded the limit, but it bypasses a whole bunch of research and head-scratching beforehand.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 10-15-2008, 01:38 PM   #8
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,796
Rob in Seattle
why not use the extra cutout space on the right side of the key, and have two plugs?
Originally Posted by wxwax
Yes, but everything you've ever posted in the basement indicates that you're certifiably crazy, so you don't count.
"Another road remains, but it provides no more. It can only take us away"
]I)Money is offline   Reply With Quote
Old 10-16-2008, 09:07 AM   #9
F800 Rob
MotoInsight
F800 Rob's Avatar
Oddometer: 1,052
There are two threads on F800Riders.org that should answer your question:
http://f800riders.org/forum/search.php?searchid=259360 -- Overview
http://f800riders.org/forum/showthre...ght=alternator -- Specifics in post 2
There is also a complete writeup of how to add an additional power outlet on the GS in the F800 Riders Hall of Wisdom:
http://f800riders.org/HoW/showentry.php?e=29&catid=6
As of September 6th 2013, all Motorcycle Insight sites list above have been sold to and are operated by LM Cycle Supply. Please see the official announcement here.
F800 Rob is offline   Reply With Quote
Old 10-16-2008, 09:13 AM   #10
CrazyMike OP
***42***
CrazyMike's Avatar
Oddometer: 929
Originally Posted by Rob Alan
Rob,
This link does not work for me.
George has shown us a wattage value that is too much (175W) which is great, but how much can we use before supply is overpowered by demand?
I've already used this one to wire up my Zumo. Thanks.
Mike
1999 BMW R1200C
2009 BMW F800GS
CrazyMike screwed with this post 10-16-2008 at 09:32 AM
Old 10-16-2008, 09:21 AM   #11
F800 Rob
MotoInsight
F800 Rob's Avatar
Oddometer: 1,052
Rob,
Sorry - http://f800riders.org/forum/showthread.php?t=8539
Old 10-17-2008, 06:14 AM   #12
JRWooden
Oddometer: 4,289
The engine computer and fuel injectors & fuel pump consume "something"... but I've got no good idea how much...
I can't imagine the ABS system drawing enough to worry about on a "steady state" basis...
See my other append on the heated grips... maybe 35W?
Jim
JRWooden screwed with this post 10-17-2008 at 06:25 AM
Old 10-17-2008, 06:24 AM   #13
JRWooden
Oddometer: 4,289
I believe your theory is correct!
Nominal voltage (if the alternator is keeping up) should be on the order of 13.5V or higher...
I was going to get one of these - simple and small
http://www.cyclegadgets.com/Products...sp?Item=BOVOLT
but i notice that the light stays "green" all the way down to 12V which is not good........ so still looking....
Jim
JRWooden screwed with this post 10-17-2008 at 06:32 AM
Old 10-17-2008, 12:44 PM   #14
Bayner
Oddometer: 1,609
Most electricians and auto technicians have inductive amp clamps that will tell you exactly what you want to know, all you need is access to the positive battery cable. No disconnecting wires required.
Bayner is offline   Reply With Quote
Old 10-17-2008, 05:22 PM   #15
TheCowboy
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
I used a Gerbings Accessory Socket ($25.00) wired directly to the battery and the spare hole cut-out on the right side of the ignition key. Runs my Gerbings jacket and G3 gloves no problem - toasty warm on these now cooler fall days here in Minny-Sota.
Cowboy2
TheCowboy is offline   Reply With Quote
Times are GMT -7.   It's 06:39 AM.
