Old 10-15-2008, 12:27 PM   #1
swolf OP
swolf
Oddometer: 51
800gs 650gs modulating brake lights
Wondering if anyone has installed or thinking about installing modulating brake or running tail lights?
I friend of mine had them on his vstrom and you couldn't help but notice him!
http://www.hyperlites.com/unikits.html#about work on the vstrom but might not look great on the 800. Any other sources?
Thanks, swolf
swolf is offline   Reply With Quote
Old 10-15-2008, 12:37 PM   #2
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 917
I'm installing the 16 LED dual function Hyper-Lites on mine. These are the same ones I had on my R1150RT. Ron at Hyper-Lites and I had a pretty good discussion on how to do the install. If you are purchasing new, you will not have any problems.
Upgrading from an older design, give Ron a call to discuss what is needed.
Mike
1999 BMW R1200C
2009 BMW F800GS
WANTED: Kawasaki ZRX 1200R
CrazyMike is offline   Reply With Quote
Old 10-15-2008, 01:08 PM   #3
markymcd
markymcd's Avatar
Oddometer: 882
Are these "Hyper-Lites" different from the LED tail lights on the new F650/F800?????
McD
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 10-15-2008, 01:18 PM   #4
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 917
McD
The Hyper-Lites I am using are two additional modules of 16 LED's each that are mounted on either side of my license plate. The dual function enables a red running lite with bright flashing LED's when stopping. The ones below do not show the dual function (running lights) and are only 8 LED's per module.
Mike
1999 BMW R1200C
2009 BMW F800GS
CrazyMike screwed with this post 10-15-2008 at 01:24 PM
Old 10-15-2008, 01:21 PM   #5
swolf OP
swolf
Oddometer: 51
CrazyMike, will you share some of the instal info? I'd love to put them on put don't see any great spot to stick them. It would be a bonus to show a few images if possible.
Thanks, swolf
Old 10-15-2008, 01:33 PM   #6
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 917
Thanks, swolf
I can send you the F800 installation instructions (it has pics, too) Ron sent me after we discussed the installation, just PM me your email address and I'll send you the pdf document. If you don't have a F800, YMMV.
There are a couple of options regarding mounting:
  1. Use supplied double-sided tape to stick flashing brake modules to the rear tail light or reflectors on either side of the license plate
  2. purchase the license plate bracket when you purchase the HyperLites.
I went with option 2 because it was the easiest method to go from bike to bike as I knew I would eventually be selling my RT.
Mike
1999 BMW R1200C
2009 BMW F800GS
Old 10-15-2008, 04:09 PM   #7
Dave92029
Oddometer: 557
Wicked The Best BMW tail light ever
I must admitt to being Very surprised by this topic, because I am really positively impressed by the LED tail light on my F650GS. It is the Best factory tail light I have seen, so I am really surprised that we are discussing modifiying it.
I guess everything can be improved... BUT
I think I'll spend my limited resources improving other things about the bike for the time being.
Dave
Escondido, CA
IBA #43
2013 Vespa 300ie S GTS
2014 G650GS
Dave92029 is offline   Reply With Quote
Old 10-15-2008, 04:19 PM   #8
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
The thing about the Hyperlights is that they flash when you apply the brakes. They're not a steady light like the brake lights are, and unlike brake lights, are almost impossible to miss. If you ever get behind a bike with them, they really get your attention. Even a cell-phone wielding, make-up applying, day-dreaming nimrod will notice you. Cheap insurance, if you ask me.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 10-15-2008, 04:54 PM   #9
1LIFE2LIVE
1LIFE2LIVE's Avatar
Oddometer: 1,060
Thumb Hyper-lites
David
+1;
FLASHING BRAKE HYPER-LITES GET NOTICED & I am quite sure have saved numerous users from getting rear ended from the dim rods mentioned above!!
I installed them on my bike before even leaving the dealership.
1LIFE2LIVE is online now   Reply With Quote
Old 10-15-2008, 04:57 PM   #10
swolf OP
swolf
Oddometer: 51
+1 on this.
Spoke with the guys who sold me my 800GS and he said "I have heard the Hyperlites give a constant "Brake Failure" warning on the Canbus BMW bikes. We'll need to find out if this is still the case. If it is, you will never know if your ABS is working or not."
Thoughts?
Old 10-15-2008, 05:10 PM   #11
CrazyMike
***42***
CrazyMike's Avatar
Oddometer: 917
+1 on this.
Thoughts?
Yeah. Don't link it to the CANBUS like the previous models.
HyperLites have a specific method of tapping into the CanBus system so you don't get that error. Basically, you draw power from an accessory circuit that does not affect the brake circuit. The sensing wire can still connect to the brake circuit as the current draw is transparent to the CanBus. That way, you will not get the error.
Mike
1999 BMW R1200C
2009 BMW F800GS
Old 10-16-2008, 07:07 AM   #12
Dert Gerl
Oddometer: 205
Glad to hear it! I talked to the local dealer about this just a few weeks ago and the lead tech said that he didn't think they would work with the electrical system.
2005 KTM 400exc
Dert Gerl is offline   Reply With Quote
Old 10-16-2008, 09:10 AM   #13
F800 Rob
MotoInsight
F800 Rob's Avatar
Oddometer: 1,052
Hi swolf,
You can also go with one of these:
http://www.run-n-lites.com/prod-LiteBlazer.asp
Rob
As of September 6th 2013, all Motorcycle Insight sites list above have been sold to and are operated by LM Cycle Supply. Please see the official announcement here.
F800 Rob is offline   Reply With Quote
Times are GMT -7.   It's 02:08 PM.
